Old Aug 30, 2002, 05:22 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Depron Guided Mite
Hi,
that's my Guided Mite. It is ready finally. I've built my own actuators and glued them into the tail surfaces. Since my actuators weigh 1g each, there was no hope to get the CofG right. So I rebuilt the actuators as internal ones, axes crossed in the Ruijsink/Selman style. I've connected the ruder and elevator with 0.7mm CFK and small pieces of music wire (true music wire: a western guitar string of 0.4mm).
Motor is a KP00 with self-made BB gearbox 7:20 and a prop from my Micro Taxi. Rx is an ACT Pico 4uP (35MHz). I've exchanged the PIC processor on the board with one that drives two coils and a FET for ESC (thanks again, Graham!). I've also put a voltage booster (SOT23 charge pump) onto the rx board that provides the rx and coils with 5V/50mAh. So the space where the former standard plugs have been is now of some use! The antenna is from magnet wire now, and I've also exchanged the standard size crystal (huge and heavy!) with a GWS one (1g of weight gain). The rx is in the 5g range now, complete with coil drivers, ESC and DC booster.
Battery is one 140mAh LiPoly cell.
Now wish me low wind tomorrow! The little bird glides ok and is controllable, so it should work. All-up weight is 26,9g, so the wingloading is about 8g/dm^2.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Aug 30, 2002, 05:28 PM
jberg is offline
jberg's Avatar
Joined Feb 2001
And another pic
Here you can see the control horns. The actuators are glued to the inside of the fuselage.
So I am in the sub-ounce class finally!
Old Aug 30, 2002, 05:49 PM
aeronutz is offline
Find More Posts by aeronutz
Leicester England
Joined Jun 2001
Sure flyer
That will fly great - rudder looks a bit small from the angle in the photos?
Power to weight is very good, the other guys are reporting 20 to 30 minute flights from similar machines. Wheels should be good in the snow this winter (designed by Barny Rubble!?)
If only we had a similar size machine with ailerons ....
Maybe a 13" span Lazer 200? I wounder what one of those would look like if it was made from stick and tissue maybe?
Aeronutz news letter is on the way ....
Its going to be a great winter season for indoor fliers
Mark
aeronutz is offline Find More Posts by aeronutz
Old Aug 30, 2002, 06:07 PM
jberg is offline
jberg's Avatar
Joined Feb 2001
Re: Sure flyer
It is bigger than the original one, which looked too small to me (but my lightest plane so far has 48g).
I don't know Barny Rubble, but you are probably right! I've had not very much luck with Depron wheels up to now, so these were meant to be *sturdy* (which they are).
Anyway, thanks for your encouragement!
Yes, definitely! My next model will probably be an Aeronca C3, sized up from a Fiddler's Green plan. Or an even smaller Junkers F13 (my favourite, for being high-tech of its time, civilian, economic, and German).
Regards, Jochen
Old Aug 30, 2002, 07:14 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
looks like a winner!
I think Mark was thinking of the flintstones
Graham Stabler is offline Find More Posts by Graham Stabler
Old Aug 30, 2002, 11:18 PM
drliu is offline
Find More Posts by drliu
Living Room Aviator
drliu's Avatar
Joined Jun 2002
Nice Work Jochen! Best of all, if you ever get hungry flying your plane you can toast the wheels and make smores.
Let us know how the first flights go!
-David
drliu is offline Find More Posts by drliu
Old Aug 31, 2002, 01:33 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
Hey nice!
Can I have a bit of info about how you did the internal actuators? Photos maybe?
Trizza is offline Find More Posts by Trizza
Old Aug 31, 2002, 04:48 AM
jberg is offline
jberg's Avatar
Joined Feb 2001
Ah, that Barny! We know him as "Barney Geröllheimer" here.
Dave, my dictionary has to pass on "smores". Anyway, you all help me improve my English very much!
Trizza, here is a picture of the magnet and the diamond tool I have used to drill a hole in it:
Old Aug 31, 2002, 04:50 AM
jberg is offline
jberg's Avatar
Joined Feb 2001
And that is the complete double actuator, together with the modified receiver (with the DC booster still missing):
Old Aug 31, 2002, 09:23 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Jochen,
You may have the first oval wound actuator coils. Do you have any idea what their current draw is and how much force they generate? What do they pivot on? Brass or ball bearings, or other? Very nice building of equipment.
Smores are (I think, never having been a girl scout) toated marshmellows between chocolate bars of some sort.
As Mark says, this looks to be the best indoor season yet.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Aug 31, 2002, 09:33 AM
jberg is offline
jberg's Avatar
Joined Feb 2001
Gordon,
they are wound of 2x300 windings (each actuator) of 0.05mm magnet wire, have 200 Ohms and pull around 20 mA at the PIC outputs (which are at about 4.2V when using 5V as supply).
I have measured slightly above 1gcm of torque, so with my 5mm control horn I have about 2g at the pushrod.
The bearings are made of PVC tubes, these are originally inner bowden cables and are 2x1mm outer/inner diameter. The axle is 1mm carbon rod.
I like sweet things, especially chocolate, very much, but I doubt that I would like smores!
Regards, Jochen
Old Aug 31, 2002, 12:15 PM
drliu is offline
Living Room Aviator
drliu's Avatar
Joined Jun 2002
Jochen,
Can you tell us the weight of your actuators? They look very interesting.
My joke was to notice that the cute wheels on your plane look like marshmallows! yummy...
From my own experience:
Actuator (including magnet) weights
RFFS: 978 mg
Didel Nanobird (large, 30 ohm): 709 mg
Didel Nanobird (small, 50 ohm): 427 mg
Nick Leichty standard actuator (unwrapped): 200-220 mg
Of course weight means nothing unless your actuator is powerful enough (more on this later from Gordon, others, and myself).
-David
Old Aug 31, 2002, 12:26 PM
jberg is offline
jberg's Avatar
Joined Feb 2001
Dave,
the magnets are arount 0.4g, as are the coils. When the single actuators were ready they weighed about 1g. After connecting them to a double actuator and adding a little CA here and there to protect the delicate windings I came out at about 2.3g for the pair.
An interesting question would be how the optimum relation between copper weight and magnet weight would be, if you, say, set 1g of maximum weight and 4.2V/20mA as maximum power.
For instance, if it turns out that the torque is directly proportional to the magnet weight and directly proportional to the copper weight then the optimum of magnet weight times copper weight would be when both parts have 0.5g.
When we choose to work with 4.2V/20mA = 210 Ohm then we have to double the number of windings when we take a wire of double area to get the same resistance. Since the magnetic fiield is proportional to current times number of windings then it would be proportional to the square root of the copper weight.
A nice optimization task. Anybody willing to do some variation calculus?
I have a 0.1g scale (Soehnle) so there are no more precise numbers, sorry.
Regards, Jochen
Old Aug 31, 2002, 05:59 PM
Sticky Shepherd
Oxford/England
Joined May 2001
Jochen, doing a bit of maths on the old actuators has been on my todo list for quite a while. It is difficult as sometimes we want min weight for a given torque, sometimes the best torque per gram for a given voltage and current. I might have a play if I get bored of sunning myself. The difficulty is modelling the physical effects of coil dimensions etc. For example a smaller hole in the actuator should give more turns for a given resistance and do the outer turns on a larger coil contribute as much as inner ones, when does a coil get too big for its boots. All very confusing.
Last post for a while
Graham
Old Sep 01, 2002, 01:16 AM
Trizza is offline
Trizza's Avatar
Joined Feb 2001
Very interesting. Nice job!
What size are your magnets?
Where did you get the diamond tool?
You know somethings small when a 1mm carbon rod starts looking like a 3mm carbon rod in comparison to everything else
Profile Guided Mite plan Ralph B Scratchbuilt Indoor and Micro Models 7 Aug 02, 2004 09:01 AM
Lastest on Profile Guided Mite with DU system fill Scratchbuilt Indoor and Micro Models 17 Feb 19, 2002 03:23 PM
Profile Guided Mite joe price Scratchbuilt Indoor and Micro Models 4 Dec 04, 2001 02:39 PM
profile Guided mite finished! Paul Penney Parkflyers 6 Nov 30, 2001 04:38 PM
My profile guided mite Paul Penney Parkflyers 4 Nov 23, 2001 07:20 PM
