Old Mar 11, 2002, 05:36 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Measuring Thrust
Are there any devices that are moderately inexpensive and readily available to measure thrust?
drbird is offline Find More Posts by drbird
Old Mar 11, 2002, 06:26 PM
Daren is online now
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Any moderately accurate spring scale will work. You can either hang it nose up from the tow hook (if bungee launched) or nose gear (if retractable) and check the weight without thrust, then run it up to full throttle and see how much lighter it gets and figure the difference to get your thrust. Or, you can hang it nose down and see how much heavier it gets to figure thrust.
As a last resort, you could place it nose down on a postal scale, run it up and check the weight difference. All are accurate enough for our purposes. Remember, these are all static thrust which is not what the jet will get once the fan unloads in the air.
Tailpipe velocity is a different story. Dan and I are lucky enough to have access to an airspeed indicator which has been adapted for this purpose.
Daren
Daren is online now Find More Posts by Daren
Old Mar 11, 2002, 06:30 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
How do i get a "how to" to make that device?
Old Mar 11, 2002, 06:36 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
make something like this out of foam, should pivot easy and thrust line to pivot pivot to scale should be the same distance. I also calibrate it by pushing the motor forward with a postal scale, and reading the digital scale at the same time.
dave morris is offline Find More Posts by dave morris
Old Mar 11, 2002, 07:00 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
For thrust measurement it's enough to hang the plane from the ceiling of your garage with two wires. The deflection from the vertical will give you the thrust, you don't need a scale (In any case upside down placement on a kitchen scale will only work if the there is no front intake).
For efflux speed measurements we use a $2 electric motor hooked up to an ordinary voltmeter. It needs to be calibrated, otherwise it will give you only relative speed measurements:
http://aeneas.ps.uci.edu/edf/fan/p8300058.jpg
It's accurate enough to measure small deviations from uniform speed throughout the fan diameter.
Herb is offline Find More Posts by Herb
Old Mar 11, 2002, 07:12 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
that is a good idea but what is the votage compared to thrust - i mean how would you calibrate in order to measure thrust?
Old Mar 11, 2002, 09:41 PM
Tim H. is online now
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
I just took a pic of how I did it. I'm using a digital scale I picked up from Walmart. Put a piece of foam on the scale, place airplane's nose on the scale, zero out the scale (gets rid of the aircraft wieght), throttle up and read scale. My F-18 is putting out 1lb. 9oz of thrust (25oz.) Not too shabby. All up wieght of airplane is 36oz. .7 thrust to wieght. 1 to 1 would be great!
Tim H.
Tim H. is online now Find More Posts by Tim H.
Old Mar 12, 2002, 03:52 AM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Originally posted by russ6421
I have been thinking about the samething, but what I wondered is if you took a good scale made some type of open platform made up of some type large screen. Mounted the EDF to blow down would you get a correct reading when you adjust scale to 0.???????
Do you mean like a "wind catcher" that would measure the thrust coming out?
Old Mar 12, 2002, 10:05 AM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
Some type of open mesh that wouldn't restrict the airflow. I think what I should have said is would blow up and put a downward thrust on the scale.
russ6421 is offline Find More Posts by russ6421
Old Mar 12, 2002, 11:20 AM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Dave Ms rig looks the best. You dont want to measure the force of the air as there will be losses from divergence?? What you want is how much thrust can the fan put into the airframe.
With Dave's rig like he said the moment arms must be = so the distance from the axle of the fan to the piviot and then from the pivot to the scale contact point must be the same, calibrating it with two scales like he said it the way to go, then you can change the moment arms to account for any loss from the mechanics.
Its also as cheap and simple as you could want, his is made from foam.
I too use the in jet, nose on scale but there are fluxuations as you try to hold the jet up plus you are to far from the fan moment arm at the nose, the ideal way to do that would be to make a foam cradle that grabs the wings and sits on the scale.
Measurent of the fan thrust inside and outside of the plane is usefull to see your ducting losses but ohter than that, its the thrust in the plane that is the most relivant I think, again this is only staic thrust, but thats the best we have,,,,, .
JasonJ is offline Find More Posts by JasonJ
Old Mar 12, 2002, 11:50 AM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
I saw a device a while a go that was just a small box that had a very thin ducted fan like setup and them a meter under it - it was basically used to measure wind velocity - I wonder if that device would work or if it would even be accurate?
Old Mar 12, 2002, 01:24 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thrust=weight * tan (angle). So 45 degrees deflection -> thrust = weight etc.
Old Mar 12, 2002, 01:31 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
The motors with the fans on the end - the thrust of the EDF blows the fans and rotates them creating a current which can then be measured - is that right?
Old Mar 12, 2002, 01:37 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
is that right?
(rpm of sensor probe microfan) proportional to (efflux speed) ;
also (voltage out) proportional to (rpm of sensor probe).
Thus measured voltage is lclose to linear in efflux speed. Static thrust can also be measured locally, it is proportional to the rpm^2 or measured voltage^2 .
Old Mar 12, 2002, 02:59 PM
crashman is offline
Find More Posts by crashman
Seattle, WA
Joined Jan 2002
Herb,
I think your math is a little off. Thrust would equal weight at 90 degree (the motor would be hovering). At 45 degree, the thrust would be 71% of the weight. I think you forgot to account for the tension in the string that is supporting some of the weight.
It has been a while since I did static analysis, but I think it goes something like this (see attached image):
horizontal components
t * cos a = s * sin a
s = t * cos a / sin a
vertical components
w = s * cos a + t * sin a
combining to replace s
w = t * cos a * cos a / sin a + t * sin a
w = t * ( cos a * cos a/sin a + sin a )
w = t * ( ( cos a * cos a + sin a * sin a ) / sin a)
t/w = sin a / ( cos a * cos a + sin a * sin a)
Using this equation, at 0 degress t/w = 0, at 90 degrees t/w = 1, at 45 degrees t/w = .7071.
Tony
crashman is offline Find More Posts by crashman
measuring thrust phoneman High Performance 1 Sep 17, 2003 01:41 PM
Measuring Thrust... Racebelly Electric Ducted Fan Jet Talk 1 Jul 11, 2003 02:27 PM
Measuring thrust and different between 280BB & 300 SkynetAir Electric Ducted Fan Jet Talk 1 Mar 11, 2003 01:52 PM
Who(Whom?)is measuring thrust?How? AirBornOne Power Systems 0 Feb 11, 2003 09:34 PM
Measuring Thrust? drbird Electric Ducted Fan Jet Talk 0 Mar 08, 2002 01:31 AM
