NESail EZ400 Mods
I had to strengthen several things that broke: 1- Battery hangers 2- Landing gear mount 3- Motor/GB mount For all this, I used poplar hardwood (Lowes) because balsa does not have the strength. I also added strength (1/4" square dowels) to the bubber-band pins holding the wing down, but they had not broken - just looked small with everything else that broke I also drilled holes in the MPJet GB to allow the Sp400 some air. Mine was getting very hot. This sounds bad (and I was a little disappointed), but now that it's done, I really like the plane - for what it is. I use mine primarily for a camera platform. It goes high fast and floats well. Takes a major thermal to keep it up, however. Be sure there is "washout" in the wingtips, or it will stall. Back to the mods: See http://www.rcgroups.com/forums/showt...hlight=400+hot for the gear box vents. I have replaced the GB with a 4:1 ball bearing and use a 11X7 prop. Mine came with a 3.51:1. There is a picture at http://www.rcgroups.com/forums/showt...hreadid=103830 showing the other mods - but not too clear. I put holes in the G10 motor mount and screwed/glued it to the back of the wood - then glued the wood to the carbon tube fuse. I also added a wood "saddle" and a tie-wrap to keep the motor from vibrating and backing out of the GB (it did once) and I balanced the prop. The Bat Hangers are the same shape as stock - but made of 1/4" square dowel. The LG mount is a 2-piece "clamp" that I dremeled the wire LG into. Then clamped it on the tube with 4 screws and glue. I did it this way because I had already glued the motor mount on and needed a way to clamp the LG on without threading it onto the tube. If you are interested, I will take additional closeups tomorrow to show you the details. It could save you some time. Let me know if you want them I am very interested in how you do with the same elements - whether they break and how you deal with it. Tom |
