Mod Podge
On a recent trip to the local Michael's craft store, I picked up a container of Mod Podge - "water-based sealer, glue, and finish for all surfaces" for about $6. The label says it can be used for sealing puzzles, decoupage, paper mache, and a host of other craft projects --- sticks to all sorts of surfaces - most notably >>> FOAM! Comes in gloss and satin finishes, plus a variety of specialty formulas for fabric, outdoors, glow-in-the-dark, sparkles, and "hard coat" (which I did not see in stock - but might work even better for planes).
I tried a little last night on one of my planes to see how it works. I have a 90% packing-tape covered FFF wing, but the wingtips are not covered with tape due to their compound curves -- there's jut no way to tape them and make it look nice. The Mod Podge looks like thick Elmer's white glue, but smells like there might be other ingredients (smells more like wood-glue than white glue). It goes on white, self-levels (somewhat) and dries clear in about 15-20 minutes - cleans up with a wet rag if you need to start over. I used a foam brush to apply the MP and the first coat went on a bit "streaky" (a bristle brush might apply smoother) but leaving the part to dry in a horizonal position helped it to level out. Also, I may have put that first coat on a bit too thick... the instructions say to use 2-3 thin layers but my first coat went on a bit thicker due to the texture and porosity of the foam. It really soaks into the foam on the first layer and leaves a slightly textured surface due to microscopic bubbles formed while brushing. You will want to sand lightly after the first coat, but subsequent coats go on smooth. A watered-down first coat might be easier to apply. The net result was that the wingtips look great now. The finish is a bit rubbery and pliable - not hard and brittle. You can still dig a fingernail into the foam if you press hard enough, but the "glazed" surface is much more resilient to hanger rash and could probably stand up to the punishment of repeated belly landings -- if you are so inclined. I think that with a layer of packing tissue you would dramatically increase the sheer and tensile strength of FFF without much added weight. Speaking of which: I didn't weigh anything to see how much it adds, but my guess it that it's comparable to an epoxy and FG covering... not much. So now that I know it works, I have a few other planes in the hangar that might get Mod-Podged... |
http://www.rcgroups.com/forums/showt...3#post11062573
Post #12 here shows a little guy covered in tissue paper ran thru a printer. Doped on with WBPU. Tissue does make it really strong. I played around with hinging with it also. It also makes really good hinges as the tissue stay's flexible. I'd like to hear how the Mod stuff works out. |
