London
Joined Dec 2006
YGE Brushless Controllers
I recently started using A YGE 18 controller in my Maxir helicopter and I'm having good results with it. The latest V3 firmware includes a govenor that seems to work really well. I thought it would be good to create a thread here to share tips and knowlege about how to get the most from these controllers. Heino from YGE kindly gave me permission to post the English instructions here too. Enjoy.
EDIT: Should probably provide a link to the YGE website www.yge.de for more info.
I understood the manual that you'll have to re-enter gov store mode after any change to the timing or PWM frequency, because it changes the "effective" kV of the ESC-motor combination.
What I'd do is to set those parameters, turn off the governor, enter gov. store mode and "train" the governor again to the new kV. When doing so, the I/P constants reset to default, but I didn't notice anything about timing or PWM frequency. |
Yep, that's what I did. But maybe something went wrong. Will try again....
Belfast / Dublin
Joined May 2004
i run a smaller YGE in a shock flyer - but it is very good - great power, runs cool, and above all, it weighs half of what other ESC's weigh
they're not cheap but quality is tops - a test in one of the german model magazines (might have been FMT) listed Kontronik as slighlty more efficient, but YGE as providing the highest power output to the motor for a given set-up |
some more "YGE" research after reading
http://www.rc-heli.de/board/showthre...t=79558&page=9 - Changing governor store mode sets the PWM frequency back to 8 kHz, but you can then change it (before spinning up in Gov Store mode). Apparently, a lower PWM frequency is preferred in governor mode (reduces losses). - The "effective" kV learned in Gov Store matters when powering up the heli in flight mode: Initially, the PI controller is disabled, and the ESC works as an ordinary non-governed ESC. At some point, the control loop is turned on. Now if the programming in gov store doesn't match the actual setup, it is possible that the first thing the PI controller does is go full throttle to meet the target headspeed. Depending on circumstances, this can be quite abrupt. |
| Thread Tools | |
| jeti brushless controllers... | exowatt | Sport Planes | 2 | Mar 13, 2002 01:49 PM |
| Jeti Brushless Controllers | Jim Phelps | Electric Ducted Fan Jet Talk | 24 | Mar 05, 2002 12:03 PM |
| Brushless controllers | pgleesonuk | Electric Heli Talk | 7 | Jan 22, 2002 03:17 AM |
| Brushless controllers | pgleesonuk | Electric Heli Talk | 4 | Dec 06, 2001 11:40 AM |
| Aveox new and smaller brushless controllers | shelby | Electric Plane Talk | 0 | May 16, 2001 09:18 PM |
