Old Feb 10, 2009, 06:28 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Build & Fly -- Groovy 90 3A
This won't be a ready this weekend build; though it won't take too long to get it airworthy: http://www.airborne-models.com/html/...p?ProductID=77 .
It will be a longer wait for good weather for the maiden; so the build will be paced based on the forecast.
Got from LHS today, everything looks really good; here's the weights:
fuse 25
wings 22
eleva 6
rudder 2
Tot oz 55
3# 7oz
That's lighter than I would have expected -- off to a good start.
Rest of the harware is typical, so RTF won't be bad.
3 things I plan to do:
Add some wood in the landing block area; will use nylon rather than steel bolts
Glue fiber glass cowl parts together
Likely cover the tuned pipe tunnel.
More about the power set-up later.
jrb is offline Find More Posts by jrb
Old Feb 10, 2009, 08:58 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
A bit more onfo:
Radio:
TX - JR 9303
RX - JR R700
Servos - JR DS-821 (4)
UBEC (HV)
ESC - Jeti Adv 77 Opto ( http://www.hobby-lobby.com/jetiblue.htm )
Motor - Scorpion 4025-16 ( http://www.innov8tivedesigns.com/pro...roducts_id=215 )
Battery A123-xS1P @ 40amps WOT:
Most likely 10S via Dewalt 36v, with leads solder to tabs -- w/15x8 & 9#.
But, may also look at 8S (2*4) -- w/16x10 & 8.5#.
Will also use my "standard" arming/charging arrangement as shown here:
Charging is via a MasTech 5020, 7minutes at 20amps; will have about 7 minutes of flight time too.
Old Feb 10, 2009, 09:38 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
More thoughts:
Will likely servos per manual; maybe just a bit aft if easy.
Also, the configuration of Elevator allow this plane to be transported in a show/rifle type case -- maybe I can fly down to BNA next fall with it checked to bring it to the AirFoiler's E Fly-In!
Old Feb 11, 2009, 07:15 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here's the Stab/Elav arrangement that should allow them to be easily removed for transport:
Old Feb 11, 2009, 07:59 AM
viva_peru is online now
Find More Posts by viva_peru
Oakland township, Michigan
Joined Jun 2005
Jrb,
I have the 50 sized Groovy and it is a good flier; however, it ended up being a little heavy for its size. It came in at 6 lbs for a plane with a wing area of 530 sq in. I did not make any changes to it, except for those needed to mount the electric motor and battery. The attachment of the landing gear is weak and although I have not had any problems, all the landings have to be done gingerly. I would consider replacing it with a one piece unit if at all possible. These two piece landing gears place very high loads on the bolts, if the two halves became one, the loads on the bolts would go down considerably, making the landing gear much sturdier.
Good luck,
Teo
viva_peru is online now Find More Posts by viva_peru
Old Feb 11, 2009, 08:27 AM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Jim,
It looks like you have a fine looking new project. I'll be watching this thread with great interest. This would be a great bird to bring to Tullahoma .
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Feb 11, 2009, 09:56 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Thanks Ed!
Must be cost Yeo? Though its one piece on their .60 Velox; since I have one of those, I'll see if its gear could used -- just doesn't have the funny slant toward the back (don't really like it anyway).
Old Feb 11, 2009, 10:44 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Not cost?
Either set is $50 as a part .
Old Feb 11, 2009, 03:44 PM
Joined Jun 2005
Jrb,
It seems that either way, they still get you. I think the reason why the two piece assemblies have become popular has to do with packaging; they are probably easier to fit in the box. I believe that the gear is slanted towards the rear in order to get the main wheels closer to the CG; that allows the plane to rotate more easily during takeoff and landing. My biggest gripe with this arrangement is that it actually results in higher loads at the bolts that if the landing gear were one piece. I do not have a scanner, but if I were to sketch the forces it would be easy to visualize what it is that I mean (by the way, I am an enginerd).
Teo
Old Feb 12, 2009, 06:53 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Agree Teo!
Plenty of room for either 8 or 10 A123s; just like on the Velox the fusealge is wide open with the long hatch/cockpit and split wing w/tube.
The forward servo is the stock position for the rudder; looks like I could put it aft of the Elevator servo -- could even do it after build if needed.
The elevator is done via two music wires in tubes; don't plan to go to two servo in the tail unless really needed @ 1st CG check.
Here's a shot of the pipe tunnel. the forward end under the bottom cowl section will proved great motor cooling. Towards the aft end is a hardpoint that could easily be opened to give an exit point for battry/esc cooling. So I doubt I will "cover" the trough.
Old Feb 12, 2009, 07:02 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Full shot of hatch -- from firewall back.
Will even hold big packs: two TP8000-3S4Ps
Old Feb 12, 2009, 07:30 PM
MorrisM is offline
Find More Posts by MorrisM
MorrisM's Avatar
Oklahoma City
Joined May 2004
Jim, Thanks for the under the hatch pics. Looks like you made a good choice for E conversion pattern plane. Looking forward to the build.
Morris
MorrisM is offline Find More Posts by MorrisM
Old Feb 13, 2009, 04:17 AM
flyyyer is offline
Find More Posts by flyyyer
Guntalingen, Switzerland
Joined Sep 2004
Originally Posted by viva_peru
Jrb,
Good luck,
Teo
So does my girlfriend. Hers is spot on the advertised weight for the glow version, i.e. 2350g or 5.2lbs. On 4s LiPo it's a great, easy, stable flyer. The gear did cause us some concern too, we reinforced the mounts and replaced it with an old wire gear that was lying around. We also did not mount the spats.
Lorenz
flyyyer is offline Find More Posts by flyyyer
Old Feb 13, 2009, 08:27 AM
Joined Jun 2005
Lorenz,
I am just a little curious as to how your girlfriendīs Groovy ended up so light. I am using an AXI 4120/18 and a 5S pack for power. In order to get the plane to balance correctly I am also using a receiver pack. What is she using for power? I would also mention that your extremely lucky to have a girlfriend who shares the same interest.
Teo
Old Feb 13, 2009, 08:29 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
RX pack aft of CG Teo?
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
What ever happened to the EDF design/build/fly contest. OCModels Electric Ducted Fan Jet Talk 2 May 13, 2002 04:10 PM
Zagi? SoSlo2? Tilde? . . . what is the most economical to build & fly? CheeseWing Parkflyers 0 Sep 07, 2001 10:01 PM
Anyone Build / Fly /Own an ACT ME-163 Smifta Foamies (Kits) 4 Jul 26, 2001 04:51 PM
AIAA/Cessna design,build,fly Travis Electric Plane Talk 6 Apr 24, 2001 05:58 PM
