Old Dec 18, 2009, 11:57 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
You're right, I guess my monobloc was actually 1 1/2 and the total width was 2". I used two pieces of 3/4" blue glued together for my monobloc. I can't remember if it was my 33 or my 42 that I widened the monobloc and had to change the width of the top and bottom fuse pieces. I wish I could find some of that 2" sheet around here for my railroad mountains!
JohnsPop is offline Find More Posts by JohnsPop
Old Jan 13, 2010, 04:38 AM
Acer_racer is offline
Find More Posts by Acer_racer
New York
Joined Nov 2009
This theard is one of the interesting and useful ones......
Thanks to everyone who are have posted here.......
Acer_racer is offline Find More Posts by Acer_racer
Old Jan 19, 2010, 08:51 PM
Kamov is offline
Find More Posts by Kamov
Kamov's Avatar
CA
Joined May 2007
Hello all
i bought a foam core board 20" x 30" and the paper coating really peels easy off it which is good
is there a BB plans i can use on just one foam board this size which one ??
the foam core is around ~4.5mm
Kamov is offline Find More Posts by Kamov
Old Jan 20, 2010, 11:28 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
I'll bet you can make a 33" Blubaby from one sheet, with the exception of the monobloc (though you might get enough bloc layers to get a good monobloc too from the scraps. For sure a 24 can be made!
You will get lots of help if you ask the questions in the actual BluBaby thread, it's way more active than this one. This one is mostly for reference.
springer is offline Find More Posts by springer
Last edited by springer; Jan 20, 2010 at 11:29 AM. Reason: add recommendation to BB thread
Old Mar 09, 2010, 04:12 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Tony is god
rotagen is offline Find More Posts by rotagen
Old May 24, 2010, 07:41 AM
rubeuhh is offline
Find More Posts by rubeuhh
Joined May 2010
Wich 3s lipo do I use in the 42inch bb?
rubeuhh is offline Find More Posts by rubeuhh
Old May 24, 2010, 07:48 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Best to ask that question on the Blu Baby thread, you'll find some recent example and the same question recently asked over there:
http://www.rcgroups.com/forums/showt...81556&page=953
Jack
jackerbes is offline Find More Posts by jackerbes
Old Mar 21, 2011, 01:55 PM
bigtruck169 is offline
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
nice collection of Homemade
bigtruck169 is offline Find More Posts by bigtruck169
Old Apr 26, 2011, 05:10 AM
yarrumevets is offline
Find More Posts by yarrumevets
Angry Bird ...
yarrumevets's Avatar
Sydney, Australia
Joined Aug 2007
BB42: A good powertrain for a heavier construction is ...
Turnigy Park 480 motor (http://www.hobbyking.com/hobbyking/s...dProduct=14396), swinging a 10x5 propeller, with any 20A or larger ESC, powered by 2200 mAh 20C at 3S
yarrumevets is offline Find More Posts by yarrumevets
Old Jun 16, 2011, 06:00 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Thought I should list my setups on the BlueBaby 24 and 33s that I've built.
BB24 with UC wing
Motor: E-Flite Park 250
Propeller: GWS 7x6 SF
ESC: TowerPro Mag8
Servos: Blue Arrow 3.7g
Battery: 450 and 600 mAh 2s
BB33 with UC and KFm2 wing
Motor: Suppo or Turnigy 2204-14 1400 Kv
Propeller: GWS 9x4.7 SF
ESC: Any 10A
Servos: HXT 5 or 9g
Battery: 900 mAh 2s
Ken
dz1sfb is offline Find More Posts by dz1sfb
Old Feb 23, 2012, 12:28 PM
Daz393 is offline
Find More Posts by Daz393
Depron Daz
Daz393's Avatar
United Kingdom, England, Basingstoke
Joined Feb 2012
Newbee needs advice on BB
Hi everyone.
This will be my first foamie build, ever, and was wondering if I can use PVA glue like Titebond white as I don't have any PU at home?
Also, I cannot find this pink or blue foam in my area of the UK, and could only get normal polystyrene in 1/4" thick white sheets as used for insulation, although I managed to get 2" thick sheet as well to make the monoblock. The 1/4" sheets are strong but I worry that they will snap whenI roll for the wing. Will a hairdryer assist me in rolling?
Many thanks, and I will have loads of Q's as this is my first ever plane.
Regards
Daz
Daz393 is offline Find More Posts by Daz393
Old Feb 23, 2012, 01:58 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
Originally Posted by Daz393 View Post
Hi everyone.
Regards
Daz
have a look at robotbirds site youll find some foam sheets there.
they do epp sheets and geldipac like depron but not as brittle..
dazza44 is offline Find More Posts by dazza44
Old Apr 13, 2012, 09:38 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Bump!
Advise the administrator now please if you would like to see this thread become a sticky thread.
Jack
Old Apr 13, 2012, 06:13 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Plans and commercially available Tony approved kits.
The Blu-Baby 33 Classic is the straight up recreation of the one that started it all. A couple of exceptions are that it has a 1.5" wide fuselage for better finger access, and an engineered internal structure that rivals or exceeds the monoblock setup. All parts are CNC cut of the same material, which is now Model Plane Foam.
Here is picture of the prototype classic kit assembled.
In connection and with similar modifications is the Blu-Baby 33 Trike, which as the name implies is a tricycle landing gear version of the original, and comes with the optional swept fin. It to is manufactured fromt the same foam, which is white in color.
This is a picture of the prototype Trike kit.
Ken
Latest blog entry: Mini H Quad Project
Old Apr 13, 2012, 06:18 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by jackerbes View Post
Bump!
Jack
Thank you for suggesting this Jack. For some reason I thought it already was. I even went back to look.
So I have,
Ken
Discussion 2.4 Diversity RX's ... where are they all ! chancesAU FPV Talk 27 Feb 08, 2009 04:07 PM
Discussion Nitro Planes, Where Are They? N707JLK Vendor Talk 0 Feb 20, 2007 08:09 PM
Multi engine park flyers - where are they? Nic Parkflyers 9 Nov 05, 2002 03:27 AM
Where are they?? Jim Walker Power Systems 7 Oct 22, 2001 03:29 PM
