Old Feb 07, 2009, 12:31 AM
MTEXX is offline
Find More Posts by MTEXX
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
Build Log
GIANT 8.5-Foot Long Su-37 (242% Steve Shumate design)
Hi All-
My buddy and I were admiring my Steve Shumate Su-37 as it nears completion. He's been wanting to do a REALLY big plane. So we had an idea... scale the Su-37 up drastically.
My 100% build log is here: http://www.rcgroups.com/forums/showthread.php?t=996012
The 100% plans are designed around 6mm depron foam. We measured the pink home insulation foam as 14.5 mm. Do the math- that's 242%. I sent the templates to a local document printing company who printed the 12 foot x 7 foot plans (3 pieces of paper). I picked them up 2 hours later for 16 bucks. Test fits confirm that the scale is exactly right. Nice and tight tabs and slots.
And so the story begins.
I hope you all enjoy. Please don't throw your jaw out of socket when you see some of these pics View at your own risk.
CREDITS
This is arguably the MOST ADVANCED and MOST SCALE sculpted-foam parkjet on the market.
The design is by Steve Shumate, who is known as jetset44 here.
Free plans available at: http://www.parkjets.com/su-37.html (please send him a paypal if you use his plans)
jetset44: http://www.rcgroups.com/forums/member.php?u=10050
Sukhoi Su-37 Super Flanker Park Jet (3 min 50 sec)
The inspiration is from RCPowers' Su-37 project featuring working canards and high-alpha mode. I also plan to install 3 gyros. Hence, all delta mixing is done on board.
RC Su-37 Aerobatic STUNTS (7 min 28 sec)
Thanks to Steve Reed. We're building this together in his shop 5 nights a week. Thanks for the interest and support
-Micah
STATS (RTF, ESTIMATED):
Under construction
Scale vs manned aircraft: 12.5%
Scale vs original plans: 242%
Span: 72.6" = 6'
Length: 100" = 8.3'
Wing Area: 1698 in2 = 11.8 ft2
Mass: 12.86 lbs
Wing Loading: = 17.44oz/ft2
Thrust: 18 lbs
Thrust to Weight: 1.25 : 1
Power Out: 1310 W
Power Loading: 101.8 W/lb
Flight Time: 7.5 min minimum
MTEXX is offline Find More Posts by MTEXX
Old Feb 07, 2009, 12:38 AM
MTEXX is offline
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
First, I taped the paper together like you would with any tiled plan. Fortunately, I only had to deal with 3 sheets of 36" paper.
The plans scaled at 242% are 12.1' x 7.25'.
My nearly complete 100% Su-37 is centered for, mmm, scale!
Old Feb 07, 2009, 12:43 AM
MTEXX is offline
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
I rough cut the templates out on the driveway, just enough to make them manageable.
Tonight, I cut out the stabilator, canards, v-stab and lamination and the wings.
Due to the size, I will engineer removable wings and likewise cut the fuse/wing template.
BUILD TIMER
3 hours
Old Feb 07, 2009, 12:50 AM
MTEXX is offline
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
Tonight I also cut out the canards, stabilators, v-stabs and v-stab lams.
I edge-reinforced the stabs with 1/2" square balsa stock. They each took a 36" piece perfect. Unfortunately, that's all I had! I believe this is a prelude to the scale I'm embarking on... I used 5-minute epoxy on the leading edge which later delaminated. Then decided to go with hot glue. It really speeds things up.
I also routed the v-stab reinforcement using a dremel and laminated the v-stab assemblies with 5 minute epoxy.
BUILD TIMER
8 hours
Old Feb 07, 2009, 01:02 AM
UBILDIT is offline
Find More Posts by UBILDIT
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
This is...
This is going to be good... I can just tell. Good luck...
Subscribed..
Bo
UBILDIT is offline Find More Posts by UBILDIT
Old Feb 07, 2009, 02:02 AM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
HOLY MACKERAL!!! Wow, this is gonna be good. I can't wait to see how it turns out!
Man, the photos on original scale model on top of those huge plans is AMAZING...
Steve
jetset44 is offline Find More Posts by jetset44
Old Feb 07, 2009, 02:39 AM
MTEXX is offline
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
Hi again Steve - Quite a popular set of plans you have!
I shaped the stabilators using a 1/3 sheet sander and 60 grit paper. My doctor will be happy to know that my lungs are PINK just like they should be. **cough**. Needs respirator...
I then wiped them down with denatured alcohol.
I applied a thin layer of lightweight spackle to fill in any gouges, nicks dings etc. I'll let this set up overnight.
BUILD TIMER
9 hours
Old Feb 07, 2009, 11:58 AM
wilmracer is offline
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
I cannot wait to see this come together. This same idea has been bouncing around in my head, but I just don't have the space.
Have you guys thought about how you're going to launch her? Retracts?
wilmracer is offline Find More Posts by wilmracer
Old Feb 07, 2009, 01:51 PM
MTEXX is offline
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
hiya wilm. most likely hand launch / belly land. I haven't decided on the power system yet, but it will have a comparable thrust-to-weight ratio.
Old Feb 07, 2009, 04:13 PM
Joined May 2007
hand launching a 7ft long plane
I can't wait to see that!
Old Feb 07, 2009, 04:42 PM
MTEXX is offline
Flying Wing Freak
MTEXX's Avatar
Charlotte, NC 28210
Joined Feb 2004
... 8 and a half feet
Old Feb 07, 2009, 05:19 PM
nego_0 is offline
Find More Posts by nego_0
nego_0's Avatar
ya i want to see video of that!!
nego_0 is offline Find More Posts by nego_0
Old Feb 07, 2009, 08:15 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
I'm trying to get a visial on the size of the bungee launcher needed here... walt
Waltjg is offline Find More Posts by Waltjg
Old Feb 07, 2009, 10:33 PM
Joined May 2007
I hope you have He-Man for a launcher
Of course you will have a better thrust to weight ratio than I do with mine... I'll be following this one closely. Actuallt I'm in NC all the time... I would love to see this one fly in person.
Old Feb 07, 2009, 11:36 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
"We're gonna need a bigger box...."
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
New Product 6mmFlyRC Profile Sukhoi Su-37 with Simple Thrust Vectoring (with plans) tomhe Pusher Prop Jet Models 400 Jul 08, 2016 01:03 PM
Build Log Su-37 with Thrust Vectoring and Working Canards (Steve Shumate design) MTEXX Pusher Prop Jet Models 40 Mar 20, 2009 03:24 PM
Discussion SU-35 or any twin EDF with thrust vectoring dash8pilot Electric Ducted Fan Jet Talk 11 Jul 21, 2008 07:32 AM
Wanted Looking for an EDF SU-35 with thrust vectoring dash8pilot Aircraft - Electric - Jets (FS/W) 0 Jul 15, 2008 07:24 PM
Mini Vertex with thrust vectoring! RCAV8R13 Foamies (Kits) 9 Nov 04, 2003 07:55 PM
