My first jet looked like this...
1.Take some thin styro plates and glue them together. 2. Cut them to the desired shape; delta preferable. 3. Hook the fan somewere at the aft. 4. Predict the CG. 5. Off to the flying field and loads of fun to be experienced, especially when you find out that the calculated CG is a matter of resin or should I say trail and error. 6. Brass spent: fiver or so... IŽll send you a plan if youŽre interested. |
Joined Aug 2002
Thanks FANMAN.
That's a wonderful airplane, did you build it yourself? But what I meant was if you can tell me some formulas you must know when you want to design an electric foam jet(using 1 MiniFan 480). Like where the CG should be(in general, sport flyers, the CG is between 30%-70% of the fuselage, right?) ; how long should be the fuselage, if you know an exact wingspan and wing area ; what kind of tail wings you build for it, and depends on what. I want to know stuff like this, you know. The design you attached for me has landing gear, so I suppose that you use a gas engine for it, or kind of 2 MiniFans or 1 MiniFan. But what I want to use is a MiniFan 480 and a Graupner speed 480 race motor. Therefore, what I reaally need to know is the basic ides, for a foam jet. Thank you all. Florin777 |
Joined Aug 2002
Thanks FANMAN.
That's a wonderful airplane, did you build it yourself? But what I meant was if you can tell me some formulas you must know when you want to design an electric foam jet(using 1 MiniFan 480). Like where the CG should be(in general, sport flyers, the CG is between 30%-70% of the fuselage, right?) ; how long should be the fuselage, if you know an exact wingspan and wing area ; what kind of tail wings you build for it, and depends on what. I want to know stuff like this, you know. The design you attached for me has landing gear, so I suppose that you use a gas engine for it, or kind of 2 MiniFans or 1 MidiFan. But what I want to use is a MiniFan 480 and a Graupner speed 480 race motor. Therefore, what I reaally need to know is the basic ides, for a foam jet. Thank you all. Florin777 |
Get the book
In the back of Model Airplane News there is a book entitled `Basics of RC Aircraft design' which I consider the book for anyone thats just beginning. It has percentage values and formulas on how to compute things like surface areas of ailerons, tail feathers, wing position, etc. After you get a good few designs under your belt, you may actually be able to pass the book on to someone else
![]() For a mere $20 it will get you started in the right direction......... |
Joined Aug 2002
Actually I am not in hurry.
![]() I am also working on a model, Sig Riser 78. It's a 2m sailplane, my first model. I also have a 3 channel for it, all I need is right here. It was made for slow flight, 2 channel for rudder and elevator. But I am going to put a Fuji r/c .15 engine on it, and that's gonna be really nice I think. I will do some modifications, like do the wings stronger, modificate the nose for the engine. The Fuji .15 is a very powerful, so I won't have problems with it. It can fly the 2m glider. But still, I think ducted fans are the best, even if I did not fly any of them, I just saw some videos. ![]() Florin777 |
A book will help as would a plan or a kit. The CG is based on mostly on wing plan form, but can also be influenced by portions of the fuselage.
It isn't hard to design and build something but getting it to fly well can require some tweeking even if you have a book or a "pro". As far as basics, make sure the fan can breath and exhale easily. Do a search on: FSA (fan swept area) Outlet area (tail pipe diameter) CG calculation You should come up with something. The actual airframe depends on the mission. Fly fast? Maneuverable? Scale? ROG (roll on ground) takeoff? Handlaunch? Bungee launch? Flight duration? These are just a few of the question that I ask myself before I start a project. 100watts/lb minimum is what I like but that again depends on your taste, flying skills, and the amount of space you have to fly. Don't give up!
Joined Aug 2002
Can someone help me with an electric motor? I would need a Graupner speed 480BB race or a Graupner speed 480 race ; even a cobalt 400.
![]() I need for the MiniFan 480. I do not want a brushless setup for 2 good reasons... - brushless motors are very expensive - if you put a brushless motor in MiniFan, that's gonna be for high speed jets, but me, as a beginner, I am looking to built the jet using the Graupner 480 race(or the BB version). Florin777 |
| Thread Tools | |
| Whoops! G3 - How do you paint your own design ? | Purple Baron | Simulators | 14 | Feb 23, 2005 03:15 PM |
| How do you have your transmitter setup? | f2racer | Beginner Training Area (Aircraft-Electric) | 6 | Sep 11, 2001 08:08 AM |
| How Do You Charge Your Nimh Packs? | OCModels | Electric Plane Talk | 10 | Jun 23, 2001 11:37 PM |
| How do you like your Lite Stick? is it worth getting? | mrebman | Parkflyers | 23 | Jun 21, 2001 04:55 PM |
| How do you weigh your planes? | Red Baron 47 | Parkflyers | 20 | May 11, 2001 08:10 AM |
