Old Mar 14, 2003, 01:07 AM
apcopresta is offline
Find More Posts by apcopresta
Los Angeles
Joined Dec 2002
brushless esc + brushed motor?
probably a stoopid question but:
is it possible to use a brushless esc w/ a brushed motor? i would rather buy one esc now and be able to upgrade to a brushless motor later.
does a brushless esc contain the timing circuitry for alternating the current to the coils in the motor, or is that circuitry part of the motor?
--tim
apcopresta is offline Find More Posts by apcopresta
Old Mar 14, 2003, 03:45 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Not possible. A brushed ESC just varies the two wire power source to a motor using simple PWM. A brushless ESC is powering three individual coil circuits using 3-phase AC. It's a completely different beast even though the final effect (varying motor speed) happens to be the same.
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Mar 14, 2003, 11:22 AM
Los Angeles
Joined Dec 2002
thanks for the reply.
why are brushless motors so expensive then? it sounds like all the timing circuitry is in the esc, and i imagine they are simpler mechanically than conventional motors.
--tim
Old Mar 14, 2003, 11:53 AM
(aka Cliff Lawson)
Joined Oct 2001
Well brushless ESC's are more expensive than brushed ESC's because there's usually about 3 times as many expensive FETs in them.
Brushless motors are more expensive than brushed because (a) the economies of scale production - the speed 180/280/30/400 motors we use are really intended for stuff like electric toothbrushes, cordless drills, etc - Mabuchi make them by the tens of million and we cream a few hundred thousand off the top. (b) the mechanical design means hat the armature coils can be wound on machines
For brushless meanwhile they are, on the whole (a) a "niche" product only made for a few tens/hundred thousand aero modellers around the world (probably 50% of them read Ezone!!) and (b) the coils are in the "jacket" around the motor. These have to be hand wound by a single tribe of Amazonian virgins in remote village in the foothills of the Andes (and they don't come cheap!)
Cliff
PS That last bit is not ENTIRELY true
For Sale 3 hs-56, 25a Brushless ESC, 400LF motor, Telebee H/H Gyro UPGRADE the 4 in 1 Z400Flyer Aircraft - Electric - Helis (FS/W) 3 Jan 02, 2006 12:48 AM
Sold Walkera #35 6ch radio, rx/esc, brushed motor and gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 13 Oct 22, 2005 05:24 PM
FS ESC brushed motor type FlyTime Aircraft - Electric - Airplanes (FS/W) 0 Nov 10, 2004 06:07 AM
brushless esc and brushed motors? lightnin62 Power Systems 4 Aug 07, 2004 03:03 AM
Help! Brushless ESC's and motor compatibility? brianchristie Power Systems 5 Dec 16, 2003 03:43 PM
