Old Mar 14, 2009, 04:38 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Looks like we are singing from the same hymn sheet on this one.
Carving wood is not half as hard as people think it is. I've got even a big prop down to 2-3 hours. As long as its accurately cut and laminated..
Old Mar 19, 2009, 01:55 PM
cmcilwee is offline
Find More Posts by cmcilwee
cmcilwee's Avatar
Northern Ireland
Joined Apr 2006
Hi Seamus,
Took me a little while to get here....very impressed with your progress, keep it up!, watching from the side-lines, not much I can advise with, but will try!
Cliff
cmcilwee is offline Find More Posts by cmcilwee
Old Mar 22, 2009, 12:35 PM
xairflyer is offline
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Glad you found it Cliff, keep an eye out for some pram/bicycle wheels for me 14" ideally 36 spokes.
I can get the 9" tail wheel from herbie wheels but the biggest he does is 11", I have asked him about 14" but he would have to make them specially which would be very expensive.
xairflyer is offline Find More Posts by xairflyer
Old Mar 22, 2009, 03:10 PM
cmcilwee is offline
cmcilwee's Avatar
Northern Ireland
Joined Apr 2006
Hi Seamus,
Have you tried Halfords?......I could nip down to the one in Coleraine for you??
Or....could keep a eye on the papers for secondhand prams, the "oldish, trditional type pram".
I"ll keep an eye for you.
Cliff
Old Mar 23, 2009, 08:34 AM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
xairflyer
Glad I found this. You may be interested.
Posting deleted due to lack of interest.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Mar 24, 2009, 07:16 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Got a nice block of pine to start carving up my tailpost, going to be one of those jobs where 3/4's of it will be on the floor
I have been 'Training' the longerons to bend at the rear by holding them together with clamps for the past week or so.
Old Mar 27, 2009, 07:12 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Have my tailpost done eventually just needs a bit of final sanding and then staining. Took me two evenings of cutting and carving, but worth it in the end, would'nt do it again though
Had to start of with the large block so I could get the grain directions right for max strength especially for the side pieces that hold the longerons together under tension.
I first sawed out the basic shape, then drilled my hole for the rudder hinge support, then it was a matter of carving away till done. Love the grain and will look great when stained up.
Amazing amount of shavings & saw dust on the bench and floor when finished.
I still have to cut a matching curve in the end of the longerons and then glue in a piece of tube to make the half bearing shell for the rudder hinge.
Old Mar 30, 2009, 08:17 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
I have the 2 shell bearings made to fit onto the tailpost, wondering what would be the best glue to use aluminium to the wood, some epoxy's are better than others.
Old Mar 30, 2009, 08:50 AM
Cherokee Flyer is offline
Find More Posts by Cherokee Flyer
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
I think what ever glue you use would be helped by a pin in the bearing like a car has.
Nice work by the way!!
L.
Cherokee Flyer is offline Find More Posts by Cherokee Flyer
Old Mar 30, 2009, 05:22 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
thoroughly de grease and use polyester or JB weld, or if you must use epoxy, stove for an hour in an oven at 100C or so (200F)
Old Mar 30, 2009, 06:16 PM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
I had thought about polyester resin, also have some JB weld types like stick metal for good etc. I suposed the best bet is to try a few on some off cuts.
Old Mar 31, 2009, 03:25 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Just a thought . . .
As well as the gluing media (whatever you decide on) a small flat headed brass screw in the center with its head recessed in a flare so it does not touch the rudder axis.
I am sure you had your reason to use aluminum as a rudder hinge bushing.
Not the usual material for bushings.
Are you providing for an alemite?
Zor
Old Mar 31, 2009, 03:56 PM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Yes like the idea of a small screw countersunk into the shell.
Aluminium was used because I had some tube the exact size required, the rudder dos'nt move very far and the dowl (hinge pin) on the rudder will also be wrapped in thin brass or copper shim.
Also many of the types did'nt have anything, the rudder was just held on by the straps around the tailpost.
I want it to look right, you can't tell from the pictures of the fullsize what material the shells are made from.
Old Apr 03, 2009, 06:16 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Needed some eyebolts for the bracing on the top rear steering cross member, so I turned some up out of brass. They are threaded 3mm, easy to make once you make the first.
Old Apr 16, 2009, 08:22 PM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Tail section now about complete, just have to trim down the excess thread from the 'U' bolts and touch them up with some black paint.
Aluminium half shell bearings were glued on with hysol and held in place with a CS head brass screws as suggested by Zor.
After I sanded the end of the longerons to match the curve of the aluminium I glued them in place with Aliphatic Resin along with a gusset of wood as the fullsize.
When the varnish was dry I added in the remainder of the rigging wires which has made the structure now very solid.
Note
Picture of the fullsize tail section is very yellow due to the light
1/2 scale FF WINGO!! Summer Foamies (Kits) 39 Nov 11, 2004 09:40 PM
1/2 Scale Bike meangreenie Motorcycles 4 Jan 11, 2004 06:08 AM
Maidenflight 13m ASW22 (1/2 scale) FlyingFlorry Slope 14 Nov 08, 2003 05:38 PM
1/2 Scale Air-Bike Ultralight bobandris Scale Kit/Scratch Built 6 Aug 27, 2003 09:11 AM
Bluecor 1/2 Scale Kadet Seniorita Matt Chester Foamies (Kits) 15 Feb 28, 2003 10:21 PM
