Old Oct 05, 2010, 08:58 PM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Originally Posted by dxflyer View Post
This is what I did. Hope this helps. I used deans since I have it lying around. Perfect fit. This is a 2200Mah battery. Also I did not want to keep unplugging the white connector, eventually that will wear out.
Exactly what lipo is that? I am waiting for my A9 to be delivered and need to get a lipo....
Dead is offline Find More Posts by Dead
Old Oct 05, 2010, 09:00 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
My understanding is you can use either of these:
http://www.hobbycity.com/hobbycity/s...idproduct=6540
http://www.hobbycity.com/hobbycity/s...idproduct=8933
beenflying is offline Find More Posts by beenflying
Old Oct 05, 2010, 09:14 PM
Play Dead!
Dead's Avatar
Joined Jul 2003
Originally Posted by beenflying View Post
So can I assume correctly that the heavier oneis likely more robust as far as longevity?
Old Oct 05, 2010, 09:22 PM
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I am using a pair of these. One goes in the TX, the other waits till the pack gets low so I have a backup.
Diggs
Diggs is offline Find More Posts by Diggs
Old Oct 05, 2010, 09:24 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by dead View Post
The Turnigy packs usually has more protective plastic for the ends of the cells and use better silicone wire for the balance lead.
Old Oct 05, 2010, 09:34 PM
SF Bay Area, California
Joined Apr 2010
I actually used the blue lipo from hobbypartz. $10 and free shipping. Delivered in 3 days.
dxflyer is offline Find More Posts by dxflyer
Old Oct 05, 2010, 10:48 PM
Happy2ndChildhood
Don McGill's Avatar
London Ontario
Joined Aug 2005
I also use the identical lipos that Diggs posted a link to and am happy with them.
Thought I would mention since I complained here last time I tried, that the site was down. I upgraded the firmware on Aurora and module tonight (for first time) with no problems on Windows7 64 bit system. Also backed up models to pc. Seems issues with firmware servers have been sorted out.
Don McGill is offline Find More Posts by Don McGill
Old Oct 05, 2010, 10:52 PM
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
As a TX pack these are over kill, (20C, LOL) but I would go with the lighter one.
If you could get one in 1C it would be fine.
mikeruth is offline Find More Posts by mikeruth
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
Since 1.07, how do you reset your timer?
stickybeatz is offline Find More Posts by stickybeatz
Old Oct 05, 2010, 11:07 PM
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
Hold your finger on timer for a few seconds
xsubsailor is offline Find More Posts by xsubsailor
Old Oct 06, 2010, 01:11 AM
cje0114's Avatar
Carteret, NJ
Joined Feb 2006
A fromeco 2 cell 2600mah Li-Ion fits just fine in the A9 with room to spare. Just make sure to take the foam pad off of the battery cover, and use a little velcro to keep the battery in place.
cje0114 is offline Find More Posts by cje0114
Old Oct 06, 2010, 07:12 AM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Diggs
Diggs,how long do you go between charging with this pack?If you are flying steady,say 8 flights per day on a weekend of flying?I can charge my stock pack before a weekend of flying and go all weekend before needing a charge.3-4 days of flying or using the tx a good bit.Thats not too shabby I think.Do the lipos last that much longer?
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Oct 06, 2010, 09:12 AM
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
I go about 3 weeks on my 2200 lipo without recharging, I did like everyone else solder the stock connector to a deans. Easy no worry flying
Old Oct 06, 2010, 11:16 AM
Minnesota
Joined Sep 2003
I have been tying to set up my HPP-22 software, but am having some problems.
The program will install properly, but when I try to start the program I get the first error message.
I am installing the program on a computer with a Vista 32 operating system.
When installing the program I am running the installation file as administrator, and I have the "User Account Control" turned off.
I registered the comdlg.oxc file, as pointed out in the error.
Greg
OldRookie is online now Find More Posts by OldRookie
Old Oct 06, 2010, 12:29 PM
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
My flying has been so sporadic this year, it is really hard to say. Several days flying is not a problem. Plus it will sit for weeks without use and remain charged and ready to go. I just got the second pack because it was less than $10 and it is always nice to have a spare handy. I hate not having a TX pack ready. Although, I have several smaller 2S packs that I could use while the main pack is charging if needed.
Diggs
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
