Old Oct 05, 2010, 12:10 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
[QUOTE=JoeR;16217526]
Originally Posted by Rickochet View Post
Me too, plus I still use 72 mhz some. I have the Spektrum DM8, Spectra 2.4 and 72mhz modules for my Optic 6 that does ok but I would like to upgrade to the Aurora.
I know the 72 mhz module is soon to come out for Aurora but does anyone know if there are any plans to be able get a Spektrum module to fit the Aurora? QUOTE]
That would be a question for the Spektrum people. I hope they do because I have a few of the micro aircraft and would rather use my Aurora to fly them.
...that is a question to go ask Spektrum. I can't imagine Hitec will be making a module to use the gear from a different brand any time soon. With the PPM stream available from a pin on the back of the radio, it wouldn't be hard to connect a PPM based Spektrum module (like the module Spektrum made for Futaba radios).
...in fact, I may do just this so I can fly my micro-4Site with the A9 also
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Oct 05, 2010, 01:04 PM
thedood is offline
Find More Posts by thedood
USA, TX, Coppell
Joined Nov 2009
Smoked my Aurora 9
I'm not sure how to post. If I'm doing it wrong apologies in advance.
I've been watching this thread for many months. Went out and got myself a Aurora 9, love it. Except the battery. I waited for about a month of charge cycling, and the battery never got to hold a charge for more than one trip to the field. So, I got a lipo, worked great. Went 4 or 5 times to the field between charges.
Until today. Charged up the lipo (outside the transmitter), went to plug it in and I think I may have done it upside down. Dang. It let the smoke out .
Is this even worth sending back to have work done on it? Probably needs a new main board. Should I just go and buy a new one?
I'm so bummed out
-thedood
thedood is offline Find More Posts by thedood
Old Oct 05, 2010, 01:33 PM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
I'm so bummed out
-thedood
I'll bet it's cheaper to get it repaired. I would send it back and let them look at before you buy a new A9. Next time use a polarized connector so you cannot plug it in backwards.
gquiring is offline Find More Posts by gquiring
Old Oct 05, 2010, 01:37 PM
thedood is offline
USA, TX, Coppell
Joined Nov 2009
Funny thing is the connector IS polarized. I didn't get it plugged in. It's that square
plug with the raised slots on it. The contacts must be very near the end, because since the
rails didn't line up, I had to flip it over. That was too late, damage was already done.
Old Oct 05, 2010, 02:33 PM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Originally Posted by DanielCalvo View Post
I need your help with the HPP-22 software. I changed the locale settings to English (United States) in the "Regional and Language Options" in the control panel. Then I installed the HPP-22 software v1.03.
When I try to open the program, I have the following error:
"Failed to load control winsock from MSWINSCK.OCX. Your version of MSWINSCK.OCX may be outdated. Make sure you are using the version of the control that was provided with your application"
and the program exits. There is nothing I can do to open the program (at least, anything I know).
Mike et all, can you help me to know what's going on? Am I doing anything wrong?
By the way I'm using Windows XP Professional. Thank you very much.
Curiously, I'm getting the same error after installing 1.04 (but not before uninstalling the old version). Did you figure out what the issue was?
Bigster is online now Find More Posts by Bigster
Old Oct 05, 2010, 02:36 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
I'm not sure how to post. If I'm doing it wrong apologies in advance. I've been watching this thread for many months. Went out and got myself a Aurora 9, love it. Except the battery. I waited for about a month of charge cycling, and the battery never got to hold a charge for more than one trip to the field. So, I got a lipo, worked great. Went 4 or 5 times to the field between charges. Until today. Charged up the lipo (outside the transmitter), went to plug it in and I think I may have done it upside down. Dang. It let the smoke out . Is this even worth sending back to have work done on it? Probably needs a new main board. Should I just go and buy a new one? I'm so bummed out -thedood
A rare but usually relatively small cost repair.
Please refer to Hitec Warranty & Service.
Damage/parts required may differ from TX to TX, so costs are usually advised before any charge is incurred,.
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Oct 05, 2010, 02:46 PM
xsubsailor is offline
Find More Posts by xsubsailor
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
[QUOTE=theKM;16217749]
Let me know if it works, I've been holding on to me JR 9503 for all my bind n fly stuff, I would gladly sell it if one of the off the shelf spektrum modules work with the A9
xsubsailor is offline Find More Posts by xsubsailor
Old Oct 05, 2010, 02:53 PM
A.T. is offline
Joined Aug 2002
I need your help with the HPP-22 software. I changed the locale settings to English (United States) in the "Regional and Language Options" in the control panel. Then I installed the HPP-22 software v1.03. When I try to open the program, I have the following error:
"Failed to load control winsock from MSWINSCK.OCX. Your version of MSWINSCK.OCX may be outdated. Make sure you are using the version of the control that was provided with your application" and the program exits. There is nothing I can do to open the program (at least, anything I know).
Mike et all, can you help me to know what's going on? Am I doing anything wrong? By the way I'm using Windows XP Professional. Thank you very much.
Aurora A9 - Firmware Update V1.07(1) & HPP-22 V1.04 - 01Oct10.
(inc PDF update enhancements, inc set failsafe via HPP-22 & how uninstall V1.03 before new install.)
Using WinXP Pro on Desktop and WinXP Home on a Laptop, no problems encountered.
how to solve MSWINSCK.OCX problem may assist.
Regards
Alan T.
Old Oct 05, 2010, 03:49 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I'm so bummed out
-thedood
I am guessing you somehow got the battery polarity backwards and smoked a diode inside which is there to protect this very thing. I did this on a Hitec Optic 6. I sent it to Hitec and they fixed it for under $25 and had it back to me very quickly. Your situation may be different but I would ship it to Hitec for a repair estimate.
Rickochet is offline Find More Posts by Rickochet
Old Oct 05, 2010, 04:54 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I'm so bummed out
-thedood
Send it back, it will be cheaper.... Replying before I have read other responses, but I know from a buddy and his optic that it is cheaper to send it back.
Diggs
Diggs is offline Find More Posts by Diggs
Old Oct 05, 2010, 07:04 PM
zero2444 is offline
Find More Posts by zero2444
Mcminnville, Or USA
Joined Jul 2009
I'm so bummed out
-thedood
Its too late to help now........But if I were to use a lipo for my tx I would cut the wire and connector off the stock battery pack and use a deans connector on the end that goes to the lipo. Use the stock connector into the tx with a male deans on the other end of the wires coming off the tx. Then you can plug any lipo pack you have on hand that fits inside the tx.
It would also make it hard to short anything.
Sorry about your misfortune...........one good A9 bites the dust.
zero2444 is offline Find More Posts by zero2444
Old Oct 05, 2010, 07:12 PM
thedood is offline
USA, TX, Coppell
Joined Nov 2009
Thanks! I'll do that on the next one. That connector that is on it is keyed, but, apparently, it doesn't really do the trick. Especially for me, my eyes aren't what they used to be. I simple tried pushing (the braille method). I knew it would only go on one way. I didn't know it would go on enough the wrong way ! Lessons are always expensive :-) I'm filling out the paperwork to send it back now. I'll post how it turns out, if it's worth repairing or whatever. I hate to dig out my old dx7...change radios...reset up...arrgghh...
Old Oct 05, 2010, 07:16 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
This is the very first thing I did to my A9. I pulled the stock pack, and cut the leads off, installed a deans and have always flown on a 2S lipo pack. It is a great way to prevent getting the polarity wrong.
Diggs
Old Oct 05, 2010, 07:32 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm going to use an XT60 plug, since Turnigy/Zippy Flightmax 2200mah 20C Lipo's, come with them already fitted, for $8.79.
beenflying is offline Find More Posts by beenflying
Old Oct 05, 2010, 08:40 PM
dxflyer is offline
Find More Posts by dxflyer
SF Bay Area, California
Joined Apr 2010
This is what I did. Hope this helps. I used deans since I have it lying around. Perfect fit. This is a 2200Mah battery. Also I did not want to keep unplugging the white connector, eventually that will wear out.
dxflyer is offline Find More Posts by dxflyer
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
