Much easier on the neck and back. |
Joined Jul 2010
aurora 9 fail?
hello .. I have an aurora 9 and then update the software and everything else ... pita module are always two beeps followed by a pause all this very fast ... wearing the blue and red LED flashes quickly. That's according to the manual of the receiver low battery but instead on the screen gives me a correct measure for a pack of four elements ... osea I have configured the notice 5.3 to 4.4 volts. using the hpp22. but still nothing. still whistling it as you can solve? what happens?
Germany
Joined Jan 2010
Also, there are many other things which are not realized yet. A question to Mike: What improvements are planned for V1.08 and when will it be published, can you estimate? |
Joined Aug 2002
Battery pack and style in use e.g. old 4cell NiMH/NiCd? Many 4 cell NiMH may show good volts whilst little load applied but as soon as servos are exercised will drop momentarily, long enough to trigger a warning of a bad/discharged pack. Similar problems have been reported when user has failed to save the desired battery alert setting after loading Module V2.0. Hitec 2.4Ghz Systems Upgrade Manual refer section "SPECTRA 2.4 v2.00 Low Battery Warning (LBW) Function" After Spectra Pro has been upgraded to V2.0, select/save the 4 & 5 cell configuration if SPC is not being used. (Aurora can adjust on screen later) Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated] Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
| Thread Tools | |
| For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition | freedomflyer | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Aug 07, 2006 04:15 AM |
| WANT! Hitec Flash 5 Transmitter! | jocappy | Aircraft - Electric - Airplanes (FS/W) | 1 | Jun 13, 2002 10:04 AM |
| Wanted >= 4 channel Hitec (or compatable) Transmitter | OverHeadCam | Aircraft - Electric - Airplanes (FS/W) | 3 | May 28, 2002 10:56 AM |
| FS Hitec Prism 7X Transmitter | mt_100 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 20, 2002 07:30 AM |
| WTB: Hitec Flash 5 Transmitter | stevevanwagner | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 20, 2002 10:29 PM |
