You can upgrade the hpp-22 firmware? Or do you mean interface software?
Latest blog entry: smacked the beeeeg slick
Joined Jun 2007
) with the same Auto setting and check the current more thoroughly. And this protection diode, where is it located on the PCB. Perhaps it is burnt out too. In that case I would like to replace it, so if somebody knows the specs for it please let me know... |
Again an advice for work with the HPP 22 programmer:
- connect the USB-cable directly into the PC's socket, don't use an USB-Hub, that will make the connection more stable. I found out on the "hard way": my connection was via hub - I needed some try-outs with transmitter switch on and off before I got connected to the program - with the direct connection no more problems like that. Udo |
Diggs |
Mcminnville, Or USA
Joined Jul 2009
It would seem if it didn't have a constant charge mode it would not work at all as a auto peak detect charger. As far as the diode for the A9, I think I saw a picture of it a while back but I don't really know anything specific about the diode. I would think if you blew the diode your radio would not work till it is replaced. |
Going - Well, remembering this is my first time :-) I'm at work so I can't verify, but I opened the software, went the HELP -> and hit UPDATE. (no other devices plugged in)It connected to the Internet downloaded an update and told me it was good, I'm assuming it was the HP22 I updated :-) -S- |
Russian Federation, Sakha, Yakutsk
Joined May 2006
BTW... Anyone in need of a good neckstrap balancer for the A9 can go here:
http://www.espritmodel.com/index.asp...D&ProdID=12505 I love mine...
Mcminnville, Or USA
Joined Jul 2009
That means Hitec has another round of receivers ready to go. |
| Thread Tools | |
| For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition | freedomflyer | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Aug 07, 2006 04:15 AM |
| WANT! Hitec Flash 5 Transmitter! | jocappy | Aircraft - Electric - Airplanes (FS/W) | 1 | Jun 13, 2002 10:04 AM |
| Wanted >= 4 channel Hitec (or compatable) Transmitter | OverHeadCam | Aircraft - Electric - Airplanes (FS/W) | 3 | May 28, 2002 10:56 AM |
| FS Hitec Prism 7X Transmitter | mt_100 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 20, 2002 07:30 AM |
| WTB: Hitec Flash 5 Transmitter | stevevanwagner | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 20, 2002 10:29 PM |
