Old Jul 16, 2010, 07:27 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by rino View Post
The latest A9 are coming with shorter sticks. I liked the previous lengths much better."
Really? They modified this on the newer Auroras? Why?
Diggs
Diggs is offline Find More Posts by Diggs
Old Jul 16, 2010, 07:29 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
Mine has "short" sticks but they are easily extended: I like them.
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Jul 16, 2010, 07:42 PM
zero2444 is offline
Find More Posts by zero2444
Mcminnville, Or USA
Joined Jul 2009
What are the differences between the old sticks and the new sticks.
The length of the metal part on my sticks are 1 inch exactly.
Which seems about right for me.
zero2444 is offline Find More Posts by zero2444
Old Jul 16, 2010, 07:43 PM
Joined Sep 2009
I have no idea, but yours sound like mine-to extend them, you merely unscrew them, and then turn a set screw thingy.
Old Jul 16, 2010, 07:49 PM
zero2444 is offline
Mcminnville, Or USA
Joined Jul 2009
Your sticks are 1 inch too.
My A9 sticks are shorter than my Futaba tx. I had to take the tips off the Futaba, they were too long.
Old Jul 16, 2010, 09:05 PM
iAdam is offline
Find More Posts by iAdam
Downtown Minneapolis
USA, MN, Minneapolis
Joined Feb 2009
Wow this radio is AWESOME!!!
Well folks, after moving up from my trusty DX6i's I must say that this is one heck of a fine radio. The programming makes this thing actually fun to use! Only wish wasthat the back button was a bit bigger, and the switches have a weak feel with some side to side action, but Those are my only complaints!
Should have a model in the air my next weekend, waiting for Finless to detail some helis setup, which could ust some expansion. But I have a question.
What point in the transmitter voltage do you stop flying in terms of percent? I am giving the stock battery a good shot. Charged for 20 hrs before turning on, and currently cycling battery down a few times before flying with it. Do you stop flying at 20%? more? even less?
Thanks folks, awesome radio, feels and works just so well.
iAdam is offline Find More Posts by iAdam
Old Jul 16, 2010, 09:17 PM
zero2444 is offline
Mcminnville, Or USA
Joined Jul 2009
If you set the back light to go off at 10 seconds it really extends the battery time.
Cycling the battery was a good idea.
I am getting four plus hours per charge.
If you look at the battery meter there is a line. I cutoff at that line whatever percentage that is.
The touch screen and programming is brilliant on this radio.
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I charge at 70% There is a bar on the graph that shows the recommended low end of the charge state I believe.
going4speed is offline Find More Posts by going4speed
Old Jul 16, 2010, 10:42 PM
-S- is offline
-S-
Find More Posts by -S-
-S-
Just one more..... Just one...
United States, TX, Henderson
Joined Jan 2010
Spektrum eliminated!
Woo Hoo!
Thanks to some good folks here I'm up and running but still waiting on my warranty battery.
I have the simple planes converted fine, not playing with fancy stuff till I understand the basics.
QUESTION - Now that I have the capability of putting the Aileron servos on separate channels, Other than for Flaps is there a good reason or is it preferred to still use the "Y" cable.
I can't think of any reason to need the extra channel right now I have 3 more than I ever did before!
I think flaps would be cool, and as easy as the set up has been so far (Only had to RTFM once) I'd imagine I can figure it out.
Anyway, I my name is -S- and I was a Spectraholic, I have not flown DSM2 in 6 days
Woo Hoo! -S-
-S- is offline Find More Posts by -S-
Old Jul 16, 2010, 10:53 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
he said RTFM!!!! pass S tha jar!! you a mechanic?
Manta1 is offline Find More Posts by Manta1
Old Jul 16, 2010, 10:54 PM
3DHS 'native'
USA, TX, Spring
what is the reason the radio has to ask if we want to transmit? I thought it was posted on here before but I dont remember.
Old Jul 16, 2010, 10:58 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by -S- View Post
Woo Hoo!
Woo Hoo! -S-
The advantage of using separate channels for ailerons is being able to subtrim each one independently. And, you don't have to make or purchase a Y-cable It also makes it easier to reverse just one servo if needed. Not normally needed, but in some models the position of the servo is determined by the mounting position, like in some glider wings. Using a Y cable makes it impossible to use the TX to reverse just one servo.
Other than that, I see no problems with the Y.
Diggs
Old Jul 16, 2010, 10:59 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I believe the purpose for this is to help prevent flying with the wrong model selected. It forces you to look at the TX after powering up to confirm which model is selected.
Diggs
Old Jul 16, 2010, 11:05 PM
-S- is offline
-S-
-S-
Joined Jan 2010
OOPs, yup I did sorry habit... I Used to be one "back in the day" and I got sick of getting dirty so I moved into computers
Old Jul 16, 2010, 11:06 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I knew it,thats auto tech lingo..rtfm..lolol i need to get out of this bus too.it has destroyed my hip.
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 05:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 11:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 11:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 08:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 11:29 PM
