Old Jul 15, 2010, 07:24 PM
SoarWest is offline
Find More Posts by SoarWest
Trex 700, Gaui X5, 450DFC
SoarWest's Avatar
United States, AZ, Queen Creek
Joined Apr 2010
Lets get real here people, obviously the system can only report back ground speed! Unless you want to install a full pitot system (ie: air pressure measuring at the front of the plane), all you can get from a GPS is ground speed.
SoarWest is offline Find More Posts by SoarWest
Old Jul 15, 2010, 07:25 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Straight and level...ground speed = air speed for a model.
Originally Posted by teryn1 View Post
that is not true
Have you even thought about this?
going4speed is offline Find More Posts by going4speed
Old Jul 15, 2010, 07:26 PM
teryn1 is offline
Find More Posts by teryn1
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
you need to get static and total pressure from some kind of measurement system. Typically, a Pitot-static probe is used.
Originally Posted by zero2444 View Post
Yeah your right...........it didn't occur to me the GPS would give you ground speed.
So if your flying flat and level it would be accurate.
But if your doing maneuvers you would not get a accurate speed reading.
What would you need to get airspeed.?
teryn1 is offline Find More Posts by teryn1
Old Jul 15, 2010, 07:28 PM
teryn1 is offline
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
What about wind? yes, you probably didn't think about that...right? airspeed includes the wind speed ; GPS does not.
what about climbing and diving as someone pointed out?
Now, adding things up, you are starting to see that ground speed and airspeed can be very different.
Old Jul 15, 2010, 07:32 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
toy airplanes guys....toy airplanes
Manta1 is offline Find More Posts by Manta1
Old Jul 15, 2010, 07:37 PM
3DHS 'native'
USA, TX, Spring
really worried about wind pushing a 30" model? I'm not.
Old Jul 15, 2010, 07:38 PM
3DHS 'native'
USA, TX, Spring
AIRPAAIIN!!! **what I said as a kid**
Old Jul 15, 2010, 07:47 PM
zero2444 is offline
Find More Posts by zero2444
Mcminnville, Or USA
Joined Jul 2009
These Telemetry addons are going to be pretty cool.
You will essentially have the planes dashboard readings on your transmitter.
We are lucky Hitec had the vision to try to bring these features to the RC community.
I dont think JR or Futaba had telemetry in the works anytime soon prior to the release of the A9.
zero2444 is offline Find More Posts by zero2444
Old Jul 15, 2010, 07:56 PM
Dirt Brakes is offline
Find More Posts by Dirt Brakes
Nice, but watch this... oops.
Northern Ohio
Joined Jan 2010
About time
Just came home to a bit of a surprise. Not only did my lipos come in from Hobbypartz, my free Hitec rx's also arrived.
What are the chances on the same day. Who cares very cool.
Didn't get that free hpp-22 I was hoping for tho.... Still holding out hope Hitec will make it right. hint hint
Bill
Dirt Brakes is offline Find More Posts by Dirt Brakes
Old Jul 15, 2010, 08:03 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Be happy you got free Rx's, unlike the rest of the world
My LHS, by local they are ~600km away! , www.wattsup.co.nz , are hooking me up with a loaner A9 while mine gets dealt to by the either a local or korean exorcist. A good dunking in holy water will prolly fix it I think.
Goooood service
jackosmeister is online now Find More Posts by jackosmeister
Old Jul 15, 2010, 08:15 PM
vhoward1122 is offline
Find More Posts by vhoward1122
AMA # L576
vhoward1122's Avatar
United States, OR, North Bend
Joined Sep 2006
Originally Posted by CAT Power View Post
The LXYPW7 HTS-FUEL Fuel Gauge Sensor 26.99 is Glow Fuel Only Correct ?
Incorrect. The fuel sensor mounts on the outside of the tank. The tank needs to be mostly transparent as it is an optical sensor. It will only show you full, 3/4, 1/2, 1/4, and empty.
vhoward1122 is offline Find More Posts by vhoward1122
Old Jul 15, 2010, 09:51 PM
mando is offline
Find More Posts by mando
BlueGrass Rules
mando's Avatar
United States, IL, Dahlgren
Joined Nov 2003
Calling on the PC geeks...when I try to download and install the new HPP22
program I'm gett'n a "meter.ocx or one of it's dependencies not correctly registered: a file is missing or invalid" error message. AV is turned off, and I've deleted the first load and reloaded with the same prob. Any suggestions?
Thanks......
mando is offline Find More Posts by mando
Old Jul 15, 2010, 09:53 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
What difference does the size of the model make? Wind affects all flying things. Whether it's a 30" model or a 747, the absolute effect of wind is the same. But a 20 km/hr breeze is a big deal for a 30" model. So not sure what point you are making.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jul 15, 2010, 10:01 PM
-S- is offline
-S-
Find More Posts by -S-
-S-
Just one more..... Just one...
United States, TX, Henderson
Joined Jan 2010
Thanks......
Mando,
Although I'm not familiar with the hitec specific problem, (Still waiting on a battery) I run into this a lot at work with various applications.
if it was a application not related to Hitec here is the link I would follow to register the .ocx file.
http://support.microsoft.com/kb/146219
Not knowing your windows version or skills I'll explain best I can.
Click START - RUN
in the box type Regsvr32 meter.ocx
In theory that should do it, if not you may have to change to the directory that has the meter.ocx file in a command prompt window.... PM if needed.
Hope it helps. -S-
-S- is offline Find More Posts by -S-
Old Jul 15, 2010, 10:10 PM
mando is offline
BlueGrass Rules
mando's Avatar
Joined Nov 2003
Originally Posted by -S- View Post
Mando,
Click START - RUN
Hope it helps. -S-
My skills are limited , and I'm running W7 32 bit.......Thanks...
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
