Old Mar 08, 2013, 08:56 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
[QUOTE=Tovin;24359313
The reason I am curious, because all build in BEC mostly are switch mode.
I'm using a linear BEC with continuous 5A output.
The question does connection of both negative will affecting the power chain with unwanted current noise?[/QUOTE]
Tovin, I am not an electrical engineer, but I think you wouldn't want to constrict the system down to one negative. The more it is grounded the less noise it should make right? I have successfully build RFI shields out of copper and grounded them to the negative(it's on my blog). I wouldn't worry too much about it and you could put a Feral filter in the line too to control RF noise.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Mar 08, 2013, 02:41 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Fly2High View Post
Mike,
Will the Maxima 6 and 9 be single antenna, BODA or dual antenna?
Are they top or end pin?
What is the min/max voltage they will work at?
Is the case on the 9X thinner (less deep) than the Aurora 9?
best of success with the new line!!!!
Frank
Two releases added yesterday to Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
copied hereto will answer those questions.
together with two extracts from the Hitec 2013 catalogue.
Maxima has the same reboot voltage as the Minima = 2.6v.
No module, A9X case is thinner.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Last edited by A.T.; Mar 10, 2013 at 01:02 AM. Reason: add extracts from catalogue
Old Mar 08, 2013, 02:55 PM
sailorman33 is offline
Find More Posts by sailorman33
Joined Dec 2008
Firmware upgrade using Windows 8
Can I run the firmware update from 1.08 to 1.09 on a Windows 8 computer?
sailorman33 is offline Find More Posts by sailorman33
Old Mar 08, 2013, 02:57 PM
A.T. is offline
Joined Aug 2002
Originally Posted by Tovin View Post
Just to confirm the SPC connection for using external BEC, which not necessary to connect the negative BEC wire.
Since the negative BEC wire is already connect from the ESC via build in BEC connection.
UBEC (aka SBEC & Switchmode Regulator) must have negative wired to system.
Please refer to schematics attached:
. Optima Transceiver (RX) - EP Models Use SPC Port for RX Power Supply (BEC only is unreliable) & correct Battery Telemetry.
. Optima Receiver - SPC connection & Lead Detailed plus Optima Current Draw/Amps[/url
ex Hitec USA Support Forum Sticky:
& Telemetry
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Old Mar 08, 2013, 03:12 PM
A.T. is offline
Joined Aug 2002
No recorded instance of an HPP-22 problem with Win8 to date.
Whilst not used under Win8 myself, from using other items on PC running Win8,
can not see any reason why there would be any difference to that under Win7.
. Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use
& Telemetry
Alan T.
Old Mar 08, 2013, 07:47 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
One area this A9 TX is very weak in is data transfer. I had an issue with my TX not transferring models correct to another A9 and also not connecting to a PC via the 22 box. I sent it in for service and they replaced the entire internal electronics and also the display. Guess what? it still does not transfer in either mode. We have switched cables, 22 units and other PC's Now I get the throttle curve keep changing on my Sbach that nearly caused severe damage to a $15000 turbine jet. The very first time after getting it back I selected my Sbach and connected the bats. Went to taxi and the thing hit full power and shot towards this jet. I had only given a little throttle to get it moving. I checked everything out and found the throttle curve was now 100% with a couple of stick notches.... no wonder. So changed that and saved it. Next day it did the exact same thing. It keeps changing every time I want to use it but only the next day?
acesimmer is offline Find More Posts by acesimmer
Old Mar 08, 2013, 11:38 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Obviously it needs to go back to get it right. Exorcism?
4*60 is offline Find More Posts by 4*60
Old Mar 10, 2013, 10:59 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Alan T: I wish Hitec would revise schematics/drawings in transmitter manuals and Optima receiver instruction sheets showing CLEARLY how to hook up add-on switch-mode BEC's to power the servos and SPC jumper to separately power the receiver. Include + and - polarity symbols at SPC plug and receiver, etc. This is vey important for electric powered models which are a large part of the model airplane hobby nowadays.
I'm still not convinced that the SPC plug connection providing motor battery power to receiver is any more (or less) reliable than using the output of an add-on switch mode BEC to power both receiver and servos. If a connector comes loose or power wire breaks anywhere in the circuit, you lose control. If add-on BEC fails you lose control. Make sure splices of SPC and add-on BEC pigtails to ESC power wires are well soldered and supported with heat shrink tubing, and DO NOT plug SPC connector into Optima receiver with reversed polarity. Symbols on receiver are small, hard to see.
E-Challenged is online now Find More Posts by E-Challenged
Old Mar 10, 2013, 11:38 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Well I just ordered a few Minima 6S from Tower. They are going in the Crack Yak and Crack Wing I have coming. Going to be curious to see the antenna. I'm guessing they will be same length as the ones on the 6E/6T just not have the boda on them?
grimbeaver is offline Find More Posts by grimbeaver
Old Mar 10, 2013, 02:41 PM
A.T. is offline
Joined Aug 2002
Please check your A9 module has latest firmware as under:
. Optima Receivers - Light Weight. Optima_6 LITE Transceiver, Minima 6E, 6T & 6L Lite Micro Receivers...
.. Minima are compatible only with Spectra Module V3.01 or higher. Caseless Weights for 6 & 7ch Optima Transceivers.
Different ID-Setup procedure since 30 October 2012: - quick reference.
. Hitec AFHSS ID-Setup (Bind) Spectra Module V3.01(0), Optima Transceiver 6, 7 & 9ch V2.02(0) & Minima Receivers
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers
& Telemetry FAQ
_ Setups & Tips
Alan T.
Old Mar 11, 2013, 07:50 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
Originally Posted by The Tug View Post
I have tried Optima 7a 6 Lite and Minima with the same result,on Mr Mayberry's suggestion i shall now borrow a 9 channel and give it a try as the manufactuer of the winches used that setup and reported no problem however that sounds weird to me .
On that note yes i borrowed one and it makes all the difference.I range tested under sail with the 6 Lite and then did the same with the 9 channel and could get way further out before loss of control, in full power mode the winch was glitchy and on the 9 it was like butter you can literally feel the connectivity.I'm pretty shure this is the problem just amazed how much signal power is lost with this type of application,i did move the Rx to a different location to get the antenna as high under the deck as possible but the comparison was done using the same location.Thanks Mr Mayberry
Another question we install everything in a pot with a screw lid for waterproofing of the equip lipo's etc the antennas are a bit on the short side,i can get aftermarket antennas 60cm with the plug but not with the boda will they work or do i go back to square one and loss of range???
The Tug is offline Find More Posts by The Tug
Old Mar 11, 2013, 08:44 AM
bigbobed is online now
Find More Posts by bigbobed
Awsome 2.5D Pilot.
bigbobed's Avatar
United States, NC, Jackson Springs
Joined Nov 2003
Make your own. http://www.rcgroups.com/forums/showp...postcount=3176
bigbobed is online now Find More Posts by bigbobed
Old Mar 11, 2013, 10:14 AM
The Tug is offline
Barbados
Joined Jan 2011
Bigbobed thanks man,i've order'd two from HK, the FrSky ones only because they have the plugs installed for the circuit board and i have none.The BODA on the end is what i'm conserned about obviously in this application i cannot afford to sacrifice any range,i'm in the hope that longer antenna will allow for a more desired placement .Thanks Peter
P.S Here's what i am talking about
http://www.hobbyking.com/hobbyking/s...nna_60_cm.html
Old Mar 11, 2013, 03:16 PM
Ceeray is offline
Find More Posts by Ceeray
Finland
Joined Jul 2004
I have following problem:
F-15 with flaps and tailerons. Should I set it up like flying wing with 2 tail servos , 2 ailerons and 2 flaps? Or something else?
Another thing. I want to use 3 -way switch for flaps, not the slider. I do not like using sliders..
How I can change the middle point percentage of movement for 3 way switch? Now flaps come half down with middle setting and I want them to come down less for takeoff flaps.
Thanks!
Ceeray is offline Find More Posts by Ceeray
Old Mar 11, 2013, 09:32 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Originally Posted by bigbobed View Post
I am confused. The 6 lite has a boda already. What is the point of making your own? Is it just to create a longer antennae with a boda on it so as too get the receiving portion of the antennae a longer distance from the RX?
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
