Old Jan 29, 2013, 02:22 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Originally Posted by bastun View Post
I admit - "satellite" is wrong term.
Yes, that kind of receiver I'm waiting for. Almost all FBL units support Spectrum satellites and SBUS. And Spectrum satellite is cheaper than full receiver and that makes even more sense in using FBL.
BTW: why Spectrum satellite is so cheap in comparison wit full receiver ?
About the same price when you need two to get diversity... but compact and works great for helis, not to mention all the top FBL systems use em. I just hope with the "new radio" Hitec takes this into consideration.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jan 29, 2013, 02:32 PM
bastun is offline
Find More Posts by bastun
Longmont, Colorado, United States
Joined May 2002
Like any company, they will charge as much as the market will accept.
I agree here.
But "technically speaking" satellite is not the "full receiver" (neither just antenna). Am I right ? In my understanding satellite makes just part of the "job", the rest does main receiver or FBL module. Correct me if I'm wrong.
bastun is offline Find More Posts by bastun
Old Jan 29, 2013, 04:32 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I agree here.
It would probably be accurate to say satellite is "just the radio". It receives the radio signal and passes it on to a receiver core (be it a full receiver or fbl controller) where it is interpreted and split into individual servo signals.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 29, 2013, 04:51 PM
bastun is offline
Joined May 2002
Satellite does not interpret signal, split it and etc.
That means it is a simpler unit, potentially cheaper. What's true ?
Old Jan 29, 2013, 04:56 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
I agree here.
A satellite receiver is the same as every other receiver, except it only outputs the servo data as digital data. Hence its basically a standard receiver without the code to drive the servos. Code to drive servos is pretty easy to do. In fact I wouldn't be surprised if the code for the satellite is the same code as what is in the receiver, just a section of it disabled to not output the servo pulses.
With the old 35/36/40/72MHz receivers, you could increase sensitivity, reduce noise, etc, etc by using more filtering and better quality components - making it more expensive. If your running a 8/9/10/etc channel model, chances are its going to be expensive and more likely need that extra performance - thus justify the extra cost.
However on 2.4GHz most of the filtering and decoding is done on the RF chipset which is common across the complete radio manufacturers product line. There are still chips that can increase the sensitivity of the receiver (and make it a full-range, rather than park flier), but these are in the <$1 price range. So the cost difference in manufacturing between a 4 channel receiver and a 8/16/etc channel receiver is minimal. The price difference is just marketing.
Now there is additional costs involved between making a telemetry and a non-telemetry receiver (type approval costs + additional parts), so this difference will make a small price difference in development costs. Also telemetry would require more processing/more memory/etc, so may require a more powerful microcontroller to do the processing - hence pushing up the cost.
As an example, you can take a Optima 6 receiver and probe the servo output pins and get channels 7/8/9 out of it. Even the data port is still there exposed and working - as shown in other threads. Hence the manufacturing price difference between the Optima 6/7/9 receivers is the extra antenna cost, extra pins and different plastic case.
Before people start commenting about how this is ripping people off, you'll find this is done all the time in products - TVs/Cars/etc/etc. Good example off the top of my head, is that BMW uses the 2.0l petrol engine tuned to the same performance as a 1.6l/1.8l/2.0l engine - depending what the ECU has been programmed to. You can get a low tuned version and have the ECU reprogrammed for more performance.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Jan 29, 2013, 04:59 PM
Radio? Screwdriver!
Joined Aug 2011
The Spektrum satellite's still interprets and processes the signal exactly how a standard servo driving receiver would. But instead of packaging it up and sending it out as servo pulses, it packages it up into digital data to send over the serial line out on the connector.
Si.
Old Jan 29, 2013, 06:11 PM
bastun is offline
Joined May 2002
I see. Satellite does almost all the job, has all hardware and software as a full receiver. Price - only marketing issue.
I'm waiting for Hitec Rx with Spectrum satellite or/and Futaba SBUS output.
It will make FBL installation simpler and cleaner.
Or Hitec may introduce its own data format and send data in this format. I think FBL manufacturers will support third format.
BMW is not alone. VW does the same with its engines.
Old Jan 29, 2013, 06:16 PM
Joined Oct 2011
I kinda hope they get into the Gyro business and build a heli gyro/Rx combo... I'm not holding my breath, but it would be a nice addition to the "new TX".
Old Jan 29, 2013, 06:24 PM
bastun is offline
Joined May 2002
Or build gyro/Rx around existing FBL system (like Spectrum did with Beast).
Old Jan 29, 2013, 06:27 PM
Radio? Screwdriver!
Joined Aug 2011
Well the Toy Fair opens in around 8/9 hours time, so we should find out soon!
Si.
Old Jan 29, 2013, 06:48 PM
bastun is offline
Joined May 2002
I realized where I got idea that satellite is not full receiver: it's smaller than typical Spectrum Rx. How wrong I was.
Old Jan 29, 2013, 07:27 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Si.
Über alles.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Jan 29, 2013, 07:30 PM
Joined Oct 2011
Si.
Very interested
Old Jan 30, 2013, 03:34 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by A.T. View Post
Hitec Servo Nomenclature:
HS = Hitec Servo. HS - ***^^ = Analogue. HS - ****^^ = Digital.
HS - 3*HD = New Patented Gear Train (Ultra Nano Servo)
HS - 3**, 6**, 7** = Standard Nylon Bearing (case or nylon or oilite insert) and Gears.
HS - ***BB = Ball Bearing
HS - ***BH = Deluxe, High Voltage, Ball Bearing Servo
HS - ***HB = Standard Karbonite Gears, Ball Bearing
HS - ***MG = Standard Metal Gear
. HS - 5646WP = Water Proof, not just water resistant - Featured
. HS - 5086WP = Water Proof, not just water resistant - Featured
HS - 5***HB =Standard Digital Karbonite Gear Train
HS - 5***HV = High Voltage Standard Digital
HS - 5***MG = High Torque Metal Gear Servo
HS - 5***MH = HV Premium Digital Metal Gear Micro Servo
HS - 6***HB = Digital High Torque Karbonite Servo
HS - 7***TG = High Torque Titanium Gear Coreless
HS - 7***TH = High Speed HV Coreless Titanium Gear Servo
HS - 7***MG = High Speed Metal Gear Coreless Servo
HS - 7***SH = High Torque HV Coreless Steel Gear Servo
HS - 8*** = TH etc as above. High Response (25T spline & 3mm horn screw)
HSG - 5***MG = Gyro & Tail Rotor
HSG - 8***BH = HV Ultra Premium Heli Rudder Servo
HSM - 7***TH = Mega Torque HV Magnetic Encoder Servo
HSR - ****HB = HMI Standard Robot Servo
HSR - ****CR = Continuous Rotation Robot Servo
HSR - ****SG = HMI Premium Robot Servo
HSR - ****TG = HMI Ultra Premium Robot Servo
. Servo - Hitec MG & Resin Horn Screw sizes
. Servo - Horn arm Spline Count and Inter Brand Compatibility
Hitec RC Ball Bearing Sizes and part numbers for all Hitec servo as at 12Nov12
Micro Servo Ball Bearings:
. 7mm OD x 4mm ID x 2.0mm width = MR74 (e.g. HS-45HB = MR74)
. 8mm OD x 5mm ID x 2.5mm width = MR85 (e.g. HS-56 & HS-65 = MR85)
Universal Servo Ball Bearing = #58471
. 10mm OD x 6mm ID x 2.5mm Width = MR106 (e.g. HS-5245MG = MR106)
Big Ball Bearing = #58473
. 14mm OD x 8mm ID x 3.5mm Width = MR14 (for HS-805BB & HS-815BB)
24Jan2013
Attached new Servo Chart for 2013 - now also includes servo nomenclature.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
[Right click RCG attachments and open in new window.
Button bottom right of IE screen (or _+icons Firefox Toolbar) enables viewing size increase up to 400% for easier reading.]
E&OE
Updated with copy of new servo chart dated 24 Jan 2013, which now includes nomenclature.
Hitec 2013 Servo Chart also attached here for convenience
Alan T.
A.T. is offline Find More Posts by A.T.
Old Jan 30, 2013, 03:45 AM
Justapoke is offline
Find More Posts by Justapoke
aRCee Moron
Justapoke's Avatar
The Netherlands
Joined Jun 2012
Any news on the Aurora? Servo's are nice but this is the Aurora thread.
Justapoke is offline Find More Posts by Justapoke
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
