Old Jan 27, 2013, 02:15 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Anyone know if this battery would fit in the A9? http://www.hobbypartz.com/98p-2600-2s1p-2222-rx.html.
3Daddict is offline Find More Posts by 3Daddict
Old Jan 27, 2013, 02:24 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by copperbricks View Post
Does anyone know if this battery would fit in the A9?
http://www.hobbypartz.com/98p-3500-2s1p-2222-tx.html
According to my measurements, it's just a hair big, but a ruler isn't the most precise thing out there, and it seems like it was made for the A9 .
Originally Posted by 3Daddict View Post
Anyone know if this battery would fit in the A9? .
A9 Battery compartment measurements, with information on Lipo also, are provided:
Aurora 9 - Battery Installed ex Factory is part #54128 "TX NiMH battery (6 cell) Pack (Flat Type)
for AUR (RA9) 7.2v / 1300 MAh" (not an Eneloop 2000)..
.... Includes notes on Battery Compartment Size, Alternate Batteries and 2S Lipo Capabilities for Aurora & Optima RX.
Compare sizes and in need email retailer for confirmation of fit.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Jan 27, 2013, 06:00 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
I THINK that will fit.
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Jan 27, 2013, 07:24 PM
gvdl1 is offline
Find More Posts by gvdl1
Guy
Canada, ON, Georgetown
Joined Aug 2012
Ok it would seem I'm a total NOOB here. All new firmware, installed in glider and everything working fine. Started trying out different mixes and all working. Did Camber mix with a switch and a slider no problem. Then I went back later to set Camber and nothing, won't work on a switch or a slider. Now I can get Landing to work but not Camber or Launch. I went through everything and I have no other active mixes. Earlier I did set flight conditions but I have since deleted them all. Tried rebinding no change. I'm finding this really weird.
I pretty sure I'm just missing most likely some small thing but beats me as to what it is. Any ideas out there?
gvdl1 is offline Find More Posts by gvdl1
Old Jan 27, 2013, 07:40 PM
Greywing is offline
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
This wont fit either. The length and width are OK but it's too thick.
Greywing is offline Find More Posts by Greywing
Old Jan 27, 2013, 09:03 PM
Reegor is offline
Find More Posts by Reegor
USA, CA, San Diego
Joined Apr 2007
battery - get an Eneloop
If you are getting a better TX battery, I highly recommend an Eneloop NiCad, made by Sanyo. They are plug and charger compatible; just stick it in and use the stock Aurora charger. They last for weeks with minimal discharge; can be left plugged in without overcharging. They don't have high C, but we don't need it for the TX.
Here are two sources.
http://www.cheapbatterypacks.com/pro...Flat-pack.aspx
http://www.electrodynam.com/store/product278.html
This one, at least, has the proper plug already on it.
These are both 2000 mAh, so you get a bit less run time than a LiPo, but the increased safety and decreased hassle are worth it, hands down. Also that it STAYS charged, when it is not in use.
Reegor is offline Find More Posts by Reegor
Old Jan 27, 2013, 10:18 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
I think I used this. I like the price of these. 2 A 9. Four lipos.
4*60 is offline Find More Posts by 4*60
Old Jan 27, 2013, 10:24 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
You don't need the 30C. The 20C ones are cheaper and have worked for me for over two years:
http://www.hobbyking.com/hobbyking/s..._2S1P_20C.html
Edit: Both out of stock. Must be due to all of the A9 owners buying them.
beenflying is offline Find More Posts by beenflying
Old Jan 27, 2013, 10:34 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
From experience the best you can do is just reset all and start fresh. Setup your flight modes first and decide what you want to do in each mode. I had similar behavior in the past and figured that starting from scratch goes faster than trying to figure everything out.
Highfly! is offline Find More Posts by Highfly!
Old Jan 27, 2013, 10:37 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
+1 20C worked great and fit well
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Jan 27, 2013, 10:39 PM
Craig Downer is offline
Find More Posts by Craig Downer
Joined Mar 2012
I would delete the model and start over. You will save yourself a lot of time if you haven't already.
Craig Downer is offline Find More Posts by Craig Downer
Reply With Quote  (Disabled)
Old Jan 27, 2013, 10:45 PM
Joined Mar 2012
firmware version 1.09 ele>cam mix
Wrong wrong wrong, had a pmix messing things up.
Old Jan 27, 2013, 10:50 PM
Joined Mar 2012
Duplicate post, which was wrong to begine with.
Old Jan 28, 2013, 12:05 AM
A.T. is offline
Joined Aug 2002
. Aurora 9 - Programming Problem? - Parameters must be set in correct ordere.g. V_tail, see chart.
Several examples of Glider setups under the Glider/Sailplane section and:
Aurora 9 - Template Index: Acro, Glider, Helicopter, Rock Crawler, Tanks, Simulator.
within the Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
Old Jan 28, 2013, 02:48 AM
4*60 is offline
most exalted one
Joined Aug 2002
Lipos still in stock at international warehouse.
BTW...Eneloop are not nicads as mentioned above. Therefore if not using stock tx charger use nimh setting.
Perhaps that post should be changed!!
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
