Joined Aug 2002
If you have a Hitec RCD Optic 6 Sport charger then plug is same and charger will work with an Aurora 9. Output: TX 7.2VDC / 80 mA for a 1300 MAh pack Only difference will be, if your Optic 6 Sport has the 600MAh pack, twice the time to charge - easy to proportion the times. Alan T. Alan's Hobby, Model & RC FAQ Web Links |
I also just ordered a cheap UK to EU plug converter from Dealextreme. That way I could use both chargers. dx.com SKU: 13525 |
Canada, ON, Georgetown
Joined Aug 2012
I'm just testing out the A9 and 9 ch receiver before hooking up everything in my plane and have a dumb question. When I set up a model and transmit I'm hooking the battering (4 AA cells) to the receiver. Red lights are on but receiver voltage showing on the transmitter still says zero volts. Does not matter if I use the batt or SPC connection on the receiver. Trasmitter shows firmware version 1.8. Not sure of which firmware is in the module. Any ideas or do I have to connect a lipo as source battery. Thanks all.
Joined Aug 2012
USA, CA, Pismo Beach
Joined Oct 2007
Joined Aug 2002
All new systems have ID-Setup completed at time of packaging/receipt. Transceiver voltage will not show on the A9's screen until: 1. The link has been completed correctly. 2. If no separate SPC lead is connected to the Power Pack, the SPC plug must be inserted. 3. "(4 AA cells)" Fresh Alkaline AA or fully charged NiMH/NiCD with voltage (under load) above 4.5v. There are now three different methods of completing the ID_Setup, depending upon which firmware is in the A9, module and transceiver, please refer to: . AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure for ........Aurora 9, Spectra 2.4Ghz Module <> Optima Transceiver or Minima Receiver. At the top of the page is a link to a quick reference page for the latest firmware, full page shows the different procedures for earlier combinations. If you have an HPP-22, suggest the firmware in your A9, Module and 9ch be checked and updated: . Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use ..(includes Screenshots & Current Firmware Versions for all related Units). ex Hitec USA Support Forum Sticky: Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers & Telemetry - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated} Alan T. Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F) |
No problems. |
Joined Aug 2012
Thanks A.T. I had read through all that but was not working. Found out the Rx was not bound.
Updated all the firmware though: Tx: 1.08(1) - 1.09 Rx: 2.02 - 2.02 Module: 3.01 - 3.01 Voice: 1.03 - 1.04 All working perfectly now, thanks very much. Step 2, Install in glider, set up, learn more and go fly
Does anyone know if this battery would fit in the A9?
http://www.hobbypartz.com/98p-3500-2s1p-2222-tx.html According to my measurements, it's just a hair big, but a ruler isn't the most precise thing out there, and it seems like it was made for the A9. |
Joined Oct 2007
That battery looks like it would almost fit - except for the connector which impinges on the width dimension (45.77 mm) and the balance connector has to also fit into the cavity. And frankly I am suspicious of the precision expressed by those dimensions (100th's of a mm?); lets face it, the reality of LiPo's is they are not precision sized objects.
It's tempting but I don't think it will fit. |
| Thread Tools | |
| For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition | freedomflyer | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Aug 07, 2006 04:15 AM |
| WANT! Hitec Flash 5 Transmitter! | jocappy | Aircraft - Electric - Airplanes (FS/W) | 1 | Jun 13, 2002 10:04 AM |
| Wanted >= 4 channel Hitec (or compatable) Transmitter | OverHeadCam | Aircraft - Electric - Airplanes (FS/W) | 3 | May 28, 2002 10:56 AM |
| FS Hitec Prism 7X Transmitter | mt_100 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 20, 2002 07:30 AM |
| WTB: Hitec Flash 5 Transmitter | stevevanwagner | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 20, 2002 10:29 PM |
