Old Jan 04, 2013, 02:08 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Aurora 9 - 110/230 Vac charger
Originally Posted by The Tug View Post
I use this battery and the IR readings are similar so i'm very happy with it,been runnin it
for about a year, hily recomended.On this subject of batteries another member has a new A9 with the stock battery which i have never used,
when you plug in the wall wart charger after a period of time the red indicator light goes out as if it were no longer charging,however the
battery came off reading 100%.Is something new going on here opposed to the old school chargers where you had to unplug it to stop it???
don't say read the manual lol.
Aurora 9 - 110/230 Vac charger Charge Plug & adapter sizes.
...[Red LED Does Not Change to Green simply dims out whilst charge continues same rate].
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Jan 04, 2013, 03:00 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Originally Posted by 4*60 View Post
Somewhere on here I believe AT? Pointed out Hitec cable is a slightly different end than the standard and therefore the connection can be intermittent. Actual shape and dimension(s) were different.
My hpp22 lead for the Aurora is exactly 3.5mm not 3.2mm. I'd thought hitec would use a lead that was reliable for updating the transmitter as if it failed it will brick it.
I would say that either the connector contacts have worn out and the connector needs replacing, or the connector has cracked a joint and come loose. Alternatively the cable lead may have a damaged plug - usually happens around the plugs cable strain relief area.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Jan 04, 2013, 03:38 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Yikes, I forgot that the firmware updates happen via the trainer port. Looks like I will be opening the TX up to take a closer look at it after all.
jtaylor996 is offline Find More Posts by jtaylor996
Old Jan 04, 2013, 03:55 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
No,I give up on getting my point across. Back to building!
Here are the photos showing difference in plugs!!!!
http://www.rcgroups.com/forums/showt...2#post18026862
4*60 is offline Find More Posts by 4*60
Old Jan 04, 2013, 05:13 PM
Registered Crasher
Joined Feb 2011
Cross wired? You mean like pins on the connector going to the wrong place? That's not possible... it worked for a year before this. It's connected as per AT's instructions (just plug it into the interlink, T. Pupil mode...).
Old Jan 04, 2013, 07:19 PM
4*60 is offline
most exalted one
Joined Aug 2002
Registered Crasher
Joined Feb 2011
I measured the plug on the interlink, it's 3.46mm, so it is definitely not undersized.
I took apart the other end on the interlink cable (the short side with the female 1/8" plug) to check the pins from the interlink. It appears that there is 5v coming out on pin 6. However, the pics online for futaba trainer cables show this as being used for ppm out. I'm guessing they are just repurposing this pin.
So all I have to do now is figure the ppm pinout that works with the 5ch minima. Unfortunately, that's not in the manual (nor is a description of which pin is pin 1). Simon?
Since the connector on the interlink is completely reusable, this is looking like its going to be a very clean, elegant, cheap solution to wirelessly connecting the A9 to RealFlight! I'll take pics as I go.
Old Jan 04, 2013, 07:22 PM
Registered Crasher
Joined Feb 2011
I hear you, 4*60. However, the interlink cable I'm using is the larger 3.5mm size.
Old Jan 04, 2013, 09:26 PM
Registered Crasher
Joined Feb 2011
Ok, so far I've figured that pin 6 is something else. I needed to tap the 5v from the USB directly, and wire it into pin 1 on the futaba connector (which is not normally used, so it should be safe). This happens inside the interlink, but took all of 60s to do (I didn't even power down or unplug the interlink to do it).
So now I get the RX to boot, after binding it in the PPM mode already using an RX. However, it's not showing up in the list in realflight yet. Any ideas?
I have lots of pics so far, but I'm not posting them until I can do a write up on a working setup.
Edit: Changed pin numbers to match Alan's diagram.
Old Jan 04, 2013, 10:23 PM
Justapoke is offline
Find More Posts by Justapoke
The Netherlands
Joined Jun 2012
Originally Posted by grimbeaver View Post
Don't buy that crap. I had a friend try one. Very very bad lag with Phoenix and RF6/6.5 just crash at start up if you have one connected.
Your friends needs a new peecee, that "crap" works just fine for me with RF and Phoenix!
Justapoke is offline Find More Posts by Justapoke
Reply With Quote  (Disabled)
Old Jan 04, 2013, 10:49 PM
A.T. is offline
Joined Aug 2002
I needed to tap the 5v from the USB directly, and wire it into pin3 on the futaba connector
Pins (including 6) on a Futaba Mini Square plug are labelled on attached picture.
extracted from, other pictures relating to Aurora 9 plugs and Futaba are also available, down to post 15:
. Hitec Aurora 9 - Trainer / Buddy system Master & Slave function Set-up. - & Data Transfer A9<>A9 etc.
- Also covers Eclipse 7 Pro & other Hitec RCD transmitters
Alan T.
Old Jan 04, 2013, 11:01 PM
Registered Crasher
Joined Feb 2011
Thanks Alan. It's worth noting that after digging around in the interlink, only pins 2&3 are connected inside the box (and there are only 2 wires going to the sub board). See attached pics for getting 5v out to pin 1:
Description: Name: ImageUploadedByTapatalk1357362030.417784.jpg
Description:
Old Jan 05, 2013, 12:57 AM
crackup007 is offline
Find More Posts by crackup007
Israel Montoya
crackup007's Avatar
Joined Jan 2007
noise on the screen of Aurora 9
Hi! Is this noise normal on the screen of Aurora 9?
Aurora Pantalla (0 min 55 sec)
crackup007 is offline Find More Posts by crackup007
Old Jan 05, 2013, 01:23 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
It is if your battery needs to be charged
hone1er is offline Find More Posts by hone1er
Old Jan 05, 2013, 01:35 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Its a breach in the MATRIX. Start looking out for agent Smith
Maxthrottle is offline Find More Posts by Maxthrottle
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
