Old Nov 12, 2012, 01:39 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Originally Posted by A.T. View Post
1. Yes, antenna orientation can cause issues, especially if against CF frame. Please refer to "Helicopter Notes" under
. Optima Transceiver & Minima Receiver - Installation RX & BODA Antenna FAQ.
2. Aurora 9 - Programming Problem? - Parameters must be set in correct order e.g. V_tail, see chart.
. Aurora 9 - Programming Chart will assist. See also:
. Aurora 9ch - Video - Helicopter Set Up - Finless Bob's Review, Tips and how To - Series.
(also full of many handy pointers for Acro and other users).
. Bob's Video Library Index.pdf
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Thanks for the help on the antenna placement... forgive me but I can't figure out the Flight condition programming you supplied to get rid of the twitch I was getting with Flight Condition setup for hold.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Nov 12, 2012, 04:10 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
Hi friends, please help me:
I am using my Optima 6 receiver in my T27 Tucano (4 channel). I put navigation lights on the wing, and would like to choose one available channel
to turn it on and off. Since the led has two wires (red and black) it didnīt worked. I put the conector on the 5š port, in the receiver. To test If I did right the configuration, I plugged a servo, and it worked properly.
am using this led here:
http://www.hobbyking.com/hobbyking/s...th_Switch.html
Any ideas?
Thank you!
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Nov 12, 2012, 04:21 PM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Luis, your A9 will not turn on lights without a receiver operated switch. Turnigy makes one, but I have to find it.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Nov 12, 2012, 08:10 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
I plugged a servo, and it worked properly. am using this led here: Any ideas? Thank you
Switch is supposed to be incorporated, but from user feedback
"bought this kit thinking it would be switched from a spare channel on the tx.
It doesnt. Basically it is two DOUBLE leds. when the switch is in one position,
there is a faint light ring around the main LEDs. Bit like a BMW 5 series angel lights.
Looks cool but not bright enough really. When the switch is moved to the other position,
the main LEDs come on which are pretty bright. I guess you install this and if you want to
fly with lights, you just just power on before your flight. which is fair enough.
I also bought a Turnigy rx controlled on/off swich which can be used with this if you need.
Both are pretty good value for money so cant complain really."
The electronic switch will operate the same as an ESC as per
. EPA, ATV, Dual & Triple Rates, Expo Differences & Caution includes ESC / BEC Set Up.
Plug into Ch5, then either reduce the trim of that channel to minimum or expand EPA both sides to 120%.
Make sure switch is activated - go to channel, select Ch5, allocate switch and on/off positions.
Alan T.
A.T. is offline Find More Posts by A.T.
Old Nov 12, 2012, 08:13 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
What's the verdict on the Hobbyking compatible RX reliability? I've been looking at the Aurora 9 and want to use it with helicopters.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 12, 2012, 08:24 PM
A.T. is offline
Joined Aug 2002
Two of several recent threads, users express satisfaction:
. New $22 Hitec 2.4ghz receivers from HK.
. HobbyKing releases Hitec 2.4 Compatible Receivers
Alan T.
Old Nov 12, 2012, 09:03 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
The HK Minimas do a great job of filling a few gaps (PPM, RSSI, micro) in the Hitec receiver lineup. I'm using PPM on an Atom 500 (with SK540), DJI 450 quad (with KK2.0), wireless phoenix sim, and micro traditional on a Radjet 420, profile foamy, and mugi evo sloper.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Nov 12, 2012, 09:05 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
If only "they" didn't come from you know who....
Are you listening, Hitec?
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Nov 12, 2012, 09:36 PM
vhoward1122 is offline
Find More Posts by vhoward1122
AMA # L576
vhoward1122's Avatar
United States, OR, North Bend
Joined Sep 2006
Actually, these rx's aren't built by Hobby King. Just sold. Altitude Hobbies also sells them.
vhoward1122 is offline Find More Posts by vhoward1122
Old Nov 12, 2012, 09:38 PM
Greenland
Joined Mar 2012
Got a link?
I'd be delighted to buy from Altitude!
Old Nov 12, 2012, 10:13 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
+1. Yes, finally having PPM is great, and they even redirect the upper channels to the outputs as well, so you can still have retracts and switchable lights etc.
beenflying is offline Find More Posts by beenflying
Old Nov 12, 2012, 10:15 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by JohnathanSwift View Post
Got a link?
http://www.altitudehobbies.com/frsky...tible-receiver
Old Nov 12, 2012, 11:05 PM
Joined Dec 2011
It's actually a FrSky RX running Hitec compatible firmware. Rumor is that they licensed it from a member here who reverse engineered the Hitec protocol and wrote a Hitec compatible firmware for FrSky RX's but nobody is talking.
Old Nov 12, 2012, 11:33 PM
A.T. is offline
Joined Aug 2002
Full details were made available under the first link provided post #22671 above
- read relevant posts 20, 21, 22 & 23.
Alan T.
Old Nov 13, 2012, 11:14 AM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
It is pretty sad that we have to get simple and innovative features from another source. It's amazing how slow Hitec's new product development is.
JoeR is offline Find More Posts by JoeR
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
