Old Nov 08, 2012, 12:50 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by joshet89 View Post
Looking for the best way to get get my flaps and ailerons mixed so I can switch between using the flaps as flaps or full span ailerons. I have all 4 servos into different channels on the O9, I just struggle with mixing in general so looking for a little help. Thanks!
. Aurora 9 - Flapperon - Flaps - Set up. (post #8 in this instance)
More "Flap" set up references available under Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Nov 08, 2012, 05:57 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
I'm unable to update my A9. I've done the following
Disable all security settings and firewalls
Completly remove HP-22 from program files
Download new HP-22 software
Follow instructions
All I get is the A9 radio screen with the options to download to radio or computer. It's skipping the option of updating the software. Currently showing ver 1.08 in the bottom right hand corner.
This is very frustrating.
Mike Freas is offline Find More Posts by Mike Freas
Old Nov 08, 2012, 06:08 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Flap Servo Slowdown
Just setting up a FlyFly DG1000 Glider with my A9 (in glider option).
However I'm just having a problem with the servo slowdown for the flaps.
I can get them to slowdown going up, but not down.
The tab on the menu screen won't go down to the 'down' section (only 'up').
No problem with any of the other channels (not that I'm slowing any of them down).
And yes I've been trying to access the tab with the flap switch fully down too.
Thanks for any advice!!
Goody63 is offline Find More Posts by Goody63
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Follow instructions
You're not selecting the upgrade mode. See this video at 4:00:
V1.07 Aurora firmware update (7 min 33 sec)
beenflying is offline Find More Posts by beenflying
Old Nov 08, 2012, 06:52 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
http://www.youtube.com/watch?v=TINzgHQNjiI
Old Nov 09, 2012, 02:43 AM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
j
I found that myself!!!....after quite awhile
4*60 is offline Find More Posts by 4*60
Old Nov 09, 2012, 11:33 PM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
GPS Telemetry
Maidened my FlyFly DG1000 Glider (EP) today with the Hitec GPS Telemetry Module fitted.
Gotta say what a huge advantage in finding thermals when you have the speed/altitude displayed in the "EZ" mode on the A9.
It was great watching the DG1000 climb from 700ft to 1000ft+ unassisted!!
I also found it quite easy to glance or look through the radio (to the glider) during the flight.
There was also no shortage of volunteers to call out the altitude when she was climbing up through a thermal!!
Anyway the maiden flight used only 4 minutes of lipo during a 25 minute flight.
Pretty good for a scale glider but no doubt greatly assisted to being able to refer to the telemetry data!!
Thanks Hitec!!!!
Old Nov 10, 2012, 05:42 AM
VideoKing is offline
Find More Posts by VideoKing
VideoKing's Avatar
United Kingdom, England, Kent
Joined Dec 2010
Thanks Hitec!!!!
Buy the voice unit and an earphone and then you wont need to take your eyes off the model.
VideoKing is offline Find More Posts by VideoKing
Old Nov 10, 2012, 07:18 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Yeah.....but would spoil the tranquility!!
Old Nov 10, 2012, 11:41 PM
S_YORAM1@BEZEQIN is offline
Find More Posts by S_YORAM1@BEZEQIN
Israel, Jerusalem
Joined May 2007
Simple question, probably was already answered in the thousands of posts here:
Can I use 2 batteries, one LiFe in the SPC port to power the receiver and one LiFe in one of the servo ports to power the servos?
The model is a gasser, not electric.
S_YORAM1@BEZEQIN is offline Find More Posts by S_YORAM1@BEZEQIN
Old Nov 11, 2012, 12:32 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
A couple of issues I am having with my system... with both a 500 and a 600 trex pro. With the 600 Optima 9 is up front... one antenna going on each side of the heli 90 degrees offset from one another. In a vertical line I spin to come down and the heli cyclic applies a quick negative and then a quick positive. The heli jumps and startles me for a second... any suggestions? Could the carbon frame cause this?
Second issue is happening with both... I have Normal, Idle 1, and Idle 2 all setup on a 3-way switch with "flight conditions" setup for each and all work great. Now I try to setup a Throttle hold... with a flight condition set for Hold I have a bad twitch (blades change pitch very quick and come back to the same pitch angle) that gets worse when further away from mid stick. Without flight condition and switch still programmed all works good (smooth when I hit hold). Tried changing hold switch with the same result. Curves are identical for all three condition above 0 degrees and only Normal is different below 0 degrees. "Idle 1" and "Idle 2" -12 to +12 and Normal -4 to +12 with pitch curves matching other then the negative side in Normal mode.
Thanks in advance
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Nov 11, 2012, 03:15 AM
A.T. is offline
Joined Aug 2002
Originally Posted by S_YORAM1@BEZEQIN View Post
Simple question, probably was already answered in the thousands of posts here: Can I use 2 batteries, one LiFe in the SPC port to power the receiver and one LiFe in one of the servo ports to power the servos? The model is a gasser, not electric. Thanks
Yes. The only drawback is that you will not be able to monitor what is happening to the voltage fluctuations under varying demand by the servos.
"For nitro/gas it is always best to use a battery that is known to be able to handle the servos used (or use dual packs if needed) and then the telemetry will show exactly what is going on as it will log the lowest voltage realized durring the flight to know how well it is performing in the specific application. The first thing I do before I fly is look at this screen (simply tap the battery icon to get there) and wiggle all the sticks as quickly as possible as see what the lowest voltage drops to. This is one hige advantage to the battery telemetry being built in. Most people have no idea how low a battery can drop to under load. - Mike Mayberry"
. Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout & Add Redundancy, even one for each servo.
Alan T.
Old Nov 11, 2012, 03:30 AM
A.T. is offline
Joined Aug 2002
Thanks in advance
1. Yes, antenna orientation can cause issues, especially if against CF frame. Please refer to "Helicopter Notes" under
. Optima Transceiver & Minima Receiver - Installation RX & BODA Antenna FAQ.
2. Aurora 9 - Programming Problem? - Parameters must be set in correct order e.g. V_tail, see chart.
. Aurora 9 - Programming Chart will assist. See also:
. Aurora 9ch - Video - Helicopter Set Up - Finless Bob's Review, Tips and how To - Series.
(also full of many handy pointers for Acro and other users).
. Bob's Video Library Index.pdf
Alan T.
Old Nov 11, 2012, 07:39 AM
Israel, Jerusalem
Joined May 2007
Alan T.
Thanks, I am using a 3200mAh LiFe for the servos and a 2000 mAh for the Rx. I do not mind a drop of servo voltage for several miliseconds as long as there is no reset on the receiver.
Old Nov 11, 2012, 09:19 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Aurora 9 RS calibration troubles
I just replaced a LS slider on my Aurora 9. After entering the factory menu and successfully calibrating the new slider I noticed my right slider only has range of 0-127 from the middle of the physical control to one extreme. My LS has a range of -127 to +127, 0 being the middle.
I had an extra slider on hand, and replaced the old RS exhibiting this odd behaviour. Well, the new slider does this too. I only have half the range according to the calibration screen.
Anyone know what this can be? It doesn't seem to register the lower range past the notch.
TheCure is offline Find More Posts by TheCure
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
