Old Aug 29, 2012, 11:53 AM
SoarWest is offline
Find More Posts by SoarWest
Trex 700, Gaui X5, 450DFC
SoarWest's Avatar
United States, AZ, Queen Creek
Joined Apr 2010
Eliott, I plan to update the document to include programming for Reflex and a clearer explanation of Flaps. Just busy this week with work... This weekend we are hoping to make a soaring trip to a very nice mountain flying site (Greens Peak in AZ) and perhaps I can get time to setup and test the additional features there.
SoarWest is offline Find More Posts by SoarWest
Old Aug 29, 2012, 12:15 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
SoarWest- Thanks for all your efforts... it is greatly appreciated!
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Aug 29, 2012, 01:03 PM
SoarWest is offline
SoarWest's Avatar
Joined Apr 2010
Mike (I tried sending this PM but your mailbox is full),
Thanks for the "thanks" on the document I've been working on. I keep adding to it which is why I provide a link instead of posting the material. If you see anything you feel I explained poorly or am doing "wrong" please let me know. Especially if you feel there's a better way to accomplish something.
There are some things that could be sent off to the guys updating the software such as the bug in the throttle triggered timer still counting time even when the throttle is disabled.
Dale
Old Aug 29, 2012, 03:24 PM
FlyerMika is offline
Find More Posts by FlyerMika
Joined Apr 2012
Originally Posted by FlyerMika View Post
Now I really wonder what I'm doing wrong with my flaps. A Pike Perfect with a 4 servo wing. I can set up the flaps to neutral using the endpoints or subtrims or both. The fully deflected flaps with the other endpoints. But how on earth do I get them move at the same rate? Somehow I always end up one of the flaps go down at a faster rate in the beginning and catch up later.
Another case of "I figured it out myself". First, the flaps on most planes are not "neutral" when they are even with the wing. They have much more down travel than up. So the only position where setting the subtrims makes sense is exactly at the midpoint of the throttle stick or whatever you use for controlling your flaps - wherever they are, they must be at the same deflection. Then set endpoints for the up and down deflection, up to be even with the wing, down to the max deflection. You can still get flap movement above the airfoil level with the mixes, just remember to set the travel limits to avoid overtravel if you have multiple mixes or happen to bring flaps down from an already cambered position.
Maybe this is completely obvious, but here it is, just in case someone else has been wondering how to get the flaps travel at the same rate.
Mika
FlyerMika is offline Find More Posts by FlyerMika
Old Aug 29, 2012, 04:09 PM
Hitec/Multiplex USA
Joined Sep 2000
One tip is that I will typically assign the flap channels to CT or in some cases NULL. I don't like to have direct control with LS, instead I'll use the mixing either FLAP CONT,CAMB MIX, Butterfly or Landing to control them. If using NULL the servos will be at their center but in most cases that is not neutral at the trailing edge unless there is the same amount of up travel as down. In the CAMP MIX you can use the OST to compensate for this or if you use CT you can just adjust it so that the trailing edge is at neutral.
Mike.
Old Aug 29, 2012, 04:20 PM
TheRealFrosty is offline
Find More Posts by TheRealFrosty
Call me Frosty
TheRealFrosty's Avatar
Lawton, Oklahoma - USA
Joined Sep 2004
good work. I suggest you eventually upload the document as a PDF document so that users without an Office type application can view it.
TheRealFrosty is offline Find More Posts by TheRealFrosty
Old Aug 29, 2012, 09:39 PM
skyrock is offline
Find More Posts by skyrock
The truth will prevail
skyrock's Avatar
Germany, NRW, Dülmen
Joined Nov 2009
Originally Posted by udogigahertz View Post
No.
Imagine, when fail-safe occurs, there is no more a connection between your radio and the model, the fail-safe-positions of your servos (and motor) are pre-programmed in the receiver, if connection failed, this positions will be reached - and that's it.
What you want, would require an additional computer-chip holding this program inside of your receiver in order to switch the motor on and off.
As far as I know, no radio system offer this - right now.
Udo
This is really no problem if you do it yourself!
Triggered by the fail-safe signal of your RX one can design a small ($5) electronic circuit in your model which exactly does what you want.
Juergen
skyrock is offline Find More Posts by skyrock
Old Aug 30, 2012, 12:33 AM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
Juergen
It would also be possible to flash a modified firmware that does this straight to the MCU on the ESC.
Legot is offline Find More Posts by Legot
Old Aug 30, 2012, 01:36 AM
SoarWest is offline
SoarWest's Avatar
Joined Apr 2010
TheRealFrosty: Very good idea to make the document available as a PDF file.
Having updated the Aurora A9 Sailplane setup document to include some additional clarity and information, I have posted it here as a PDF file. I will continue to update this as I work out new programming options.
AuroraA9eSailplanesetup.pdf
Old Aug 30, 2012, 07:16 AM
udogigahertz is offline
Find More Posts by udogigahertz
udogigahertz's Avatar
Deutschland, Nordrhein-Westfalen, Geilenkirchen
Joined Aug 2007
Juergen
@Legot:
Yes of course those are practicable solutions for that problem. But, I am afraid, that the one, who asked this question will not be able to solve the problem this way ...... because if so, He would not have asked this question.
Therefore, my answer to his question is still: No.
Udo
udogigahertz is offline Find More Posts by udogigahertz
Old Aug 30, 2012, 08:53 AM
coffeegeek is offline
Find More Posts by coffeegeek
coffeegeek's Avatar
Italy, Umbria, Perugia
Joined Sep 2006
Great Idea - Petition started
Originally Posted by BasTijs View Post
We should start a petition to get head tracking in!
The petition is here.
Make sure everyone gives a +1, even those just considering to buy an Aurora, and those who at present aren't interested in FPV.
Thanks to BasTijs, and to all who can support this change.
Coffeegeek
coffeegeek is offline Find More Posts by coffeegeek
Old Aug 30, 2012, 12:51 PM
VideoKing is offline
Find More Posts by VideoKing
VideoKing's Avatar
United Kingdom, England, Kent
Joined Dec 2010
Coffeegeek
The market size of potential buyers who need FPV facilities is tiny, those who want head tracking even smaller than tiny.
There are far more important things to improve on the A9, than FPV facilities I'm afraid.
Sorry but its true.
VideoKing is offline Find More Posts by VideoKing
Old Aug 30, 2012, 09:58 PM
Legot is offline
Legot's Avatar
Joined Nov 2009
If Hitec felt like it, they could easily add head tracking. They already have a 4 channel and 9 channel selective trainer, all they need to do is let the user choose the number and location of channels to pass through the trainer port.
Unfortunately, they don't seem to be terribly interested in getting an update out quickly, so Head tracking or not, we're all screwed.
Old Aug 30, 2012, 11:02 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Ugh. I went to adjust the stick tension tonight. One of the tension screws stuck on the end of the allen wrench and pulled out of the slot. The spring went loose. What a nightmare, took me like 40 minutes to get it fixed (with my wife's assistance)!
Why on earth are those spring sliders not captive in the tracks!?
jtaylor996 is offline Find More Posts by jtaylor996
Old Aug 31, 2012, 03:47 AM
skyrock is offline
skyrock's Avatar
Joined Nov 2009
@Udo
In God's free country the answer to this question is always : Yws, we can !
Juergen
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
