Old Dec 05, 2009, 10:15 AM
vhoward1122 is offline
Find More Posts by vhoward1122
AMA # L576
vhoward1122's Avatar
United States, OR, North Bend
Joined Sep 2006
Originally Posted by le fou View Post
Hi,
I am looking at the Aurora. I was wondering if somebody can tell me if there are logical switch such as AND & OR function. For instance can I link two conditions and if they are both true or one of them is true, then an assigned command switch is activated. For instance if the fight mode "landing" is selected then the landing gears as well as the flaps are automatically lowered even if I don't activate a control switch for it.
Le fou
You can program 8 different flight conditions into this radio. Each flight condition can have any combination of actions that are activated in each flight condition without having to flip any extra switches.
vhoward1122 is offline Find More Posts by vhoward1122
Old Dec 05, 2009, 11:25 AM
skyrock is offline
Find More Posts by skyrock
The truth will prevail
skyrock's Avatar
Westbury, NY
Joined Nov 2009
@Carlos
Think, we all lost you!
If you want to set "Fail Safe" at your receiver you have to do the following :
- switch transmitter on
- switch receiver on
- press button on the receiver only!!! for 6 seconds
- now blue and red LED on receiver will blink rapidly
- now you have 5 seconds to bring all sticks and channels to your fail safe positon at your transmitter
- switch receiver off
- switch transmitter off
- test fail safe by e.g. pushing your gas stick to full throttle and switch transmitter off
- your gas servo should now move to your fail safe position
regards
Juergen
skyrock is offline Find More Posts by skyrock
Old Dec 05, 2009, 12:07 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Here's a video from a user that shows how the flight conditions can be used and that higher numbers have higher priority. Note: he replaced some of the two position switches with push buttons.
Aurora 9 Switch Mod (2 min 4 sec)
MikeMayberry is offline Find More Posts by MikeMayberry
Old Dec 05, 2009, 12:38 PM
carlos 123456 is offline
Find More Posts by carlos 123456
Joined Dec 2007
Hello friends I still have my problem, I have successfully paired normal mode receiver and transmitter in my "Parkmaster" connecting only the BEC and a servo, but my problem comes when I connect all the servos. Linking all the servos and turn on the transmitter and the receiver after they start moving (all) if I remove a servo's the same but after a few seconds is focused, if you remove other even better serve anyone can help me?.
carlos 123456 is offline Find More Posts by carlos 123456
Old Dec 05, 2009, 12:51 PM
Hitec/Multiplex USA
Joined Sep 2000
If you lose the connection when moving all the servos then the BEC is not powerful enough, and you are experiencing a brown out. You can verify this by observing the telemetry reading of the RX voltage on the TX.
You can solve this by using the SPC connection. The best way to do this is to solder a servo lead (+/-) to the battery plug on the ESC and then remove the jumper from the SPC and plug this connection into it. This will power the RX independantly and the BEC will power the servos.
Old Dec 05, 2009, 01:11 PM
Joined Dec 2007
I think it is right, but, can you explain better what of the BEC?
Old Dec 05, 2009, 01:13 PM
Hitec/Multiplex USA
Joined Sep 2000
If the BEC is not powerful enough then the load from the servos and RX can allow the voltage to sag and fall below the minimum operating voltage (3.5v) of the RX.
Mike,
Old Dec 05, 2009, 01:21 PM
Joined Dec 2007
Mike,
I understand, then how can I solve this?
Old Dec 05, 2009, 01:27 PM
Hitec/Multiplex USA
Joined Sep 2000
I just posted how to solve it (post#1550)... use the SPC to power the RX.
Old Dec 05, 2009, 01:31 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Optima Receiver - "Brownout" apparent servo failure causes & cures
Refer Mike's post #15500 above
also
Optima RX - SPC Cable and use
Extended explanation regarding BEC problems:
Electronic Speed Control - Why BEC and LVC cause most EP RX problems
see also: Aurora A9 Undocumented Features - Mixes, Setups, Tips.
(includes Spectra Pro and Optima RX features. {frequently updated}
Regards
Alan T.
A.T. is offline Find More Posts by A.T.
Old Dec 05, 2009, 01:33 PM
Joined Dec 2007
Connect the 11.1 v lipo directly to SPC, but do not burn the servos?
Old Dec 05, 2009, 01:37 PM
pbrantuas is offline
Find More Posts by pbrantuas
pbrantuas's Avatar
San Diego, CA USA
Joined Nov 2003
Along with other top of the line features, I just love the fact that the Aurora 9 lets me know what the voltage is on my receiver pack.
pbrantuas is offline Find More Posts by pbrantuas
Old Dec 05, 2009, 01:49 PM
Joined Dec 2007
Does not burn the servos?
Old Dec 05, 2009, 01:52 PM
Hitec/Multiplex USA
Joined Sep 2000
The SPC does not power the servos, the BEC will still do that. The SPC can handle up to 35v. All this info is in the manual.
Mike.
Old Dec 05, 2009, 01:57 PM
Joined Dec 2007
Mike.
So if I connect a cable from the BEC to the SPC will reach 11.1 V and servos do not burn?, I think I understand everything, I'm going to try this trick, it seems very good idea, so if I connect to 35V in spc, which comes to power the servos?
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
