Old Feb 04, 2009, 07:19 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Let's See Your Work Bench!!!
I built a new work bench that I really like!
I used a HVAC 30"X60" drain pan that cost about $39.00.
I built a frame for it and added a tray around it for my tools and to catch those little screws that always fall off the table, hit the floor and you never see them again.
I use magnets to keep everything in place. Works great!
The hight is just right when standing. No more broken backs. My stool fits great while seated.
I have my work light clamped for easy moving.
I may add some draws for more tools.
I should have painted it but after glue, paint, etc. it will have that used looked and it will be used a lot.
I could not be any more pleased with it!
Maybe others can show their work bench and share more ideas!
Dalton
DaDesign is offline Find More Posts by DaDesign
Old Feb 04, 2009, 07:26 PM
FL Knifemaker is offline
Find More Posts by FL Knifemaker
St. Boondock
FL Knifemaker's Avatar
Joined Aug 2008
Very nice Dalton!! My RC workbench is a big dining room table in my office with two ceiling tiles on it. Not very interesting I do have two nice aluminum diamond plate flourescent light fixtures over it though
FL Knifemaker is offline Find More Posts by FL Knifemaker
Old Feb 04, 2009, 07:32 PM
Crash Hancock is offline
Find More Posts by Crash Hancock
Caster Of Pods
Crash Hancock's Avatar
Waco, Texas USA
Joined Feb 2005
That's a very nice bench, DaDesign. I have thought many times of getting a work surface that is metal so that I can use magnets to facilitate building straight.
Here's a couple of shots of my bench. I have been using doors to build on for years. My bench is built so that the door recesses into it. If I ever screw up the work surface, I can just go back to Lowes and buy another for $19. These things offer a really level building surface! Some pretty good bang for the buck, I think! Also, I use a piece of tempered glass to build the smaller stuff on. The plans can go under the glass and when you get whatever glue you use all over it, you can just scrape it off with a razor.
Crash Hancock is offline Find More Posts by Crash Hancock
Latest blog entry: TheCrashCast.com - Episode 355
Old Feb 04, 2009, 07:48 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Hey Knifemaker,
I've seen your work and if I could build like that then I would use my dining table. Thanks for your comment.
Old Feb 04, 2009, 07:54 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
WOW!!! Awesome work table! I was useing a door but I have arthritis and no longer could push pins in the door so I thought the magnets would work better for me. I really like the replacement door idea. The lay out of your work space is incredible. Thanks CM
Old Feb 04, 2009, 08:37 PM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
I would post a picture of mine, but you would not be able to see it.
larryross is offline Find More Posts by larryross
Old Feb 04, 2009, 08:55 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
That's OK. Post it!! Busy mind, cluttered work space!
or is it cluttered mind, busy work space.
Old Feb 04, 2009, 09:05 PM
TJC is offline
TJC
Find More Posts by TJC
TJC
Crossweave king
TJC's Avatar
Cambridgshire in England!
Joined Jan 2007
I hav'nt seen my work bench at home for years. Too much stuff on it.
I do most of my building at work (boring night shift) on a piece of cardboard across my knees.
TJC is offline Find More Posts by TJC
Old Feb 04, 2009, 09:15 PM
larryross's Avatar
Joined Dec 2007
I know it doesn't look like it, but I really do clean at least one of them every 2 or 3 days. I work out there all day long most days.
Old Feb 05, 2009, 07:56 AM
Caster Of Pods
Waco, Texas USA
Joined Feb 2005
When I build larger models, I pull out a large acoustic ceiling tile to build on. The T-pins go very easily into the backside of it and the tile is very flat when it sits atop my workbench. I got this 2 x 4 tile when the company I worked for was remodeling. Free is the best!
Old Feb 05, 2009, 08:03 AM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
That's a good idea. I knew that I would learn from this. I could have done the ceiling tile thing. I have plenty of them at work.
I can remove the drain pan very easy, I have a wood top under it and I still could do the ceiling tile trick also. Best of all worlds!!!
Old Feb 06, 2009, 08:12 PM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
One of three benches I have for building, etc.
Xanadu is offline Find More Posts by Xanadu
Old Feb 06, 2009, 11:51 PM
Cdr.Instigator is offline
Find More Posts by Cdr.Instigator
Tom Bass Park RC Nonconformist
Cdr.Instigator's Avatar
USA, TX, Houston
Joined Dec 2007
Cdr.Instigator is offline Find More Posts by Cdr.Instigator
Gallery Let's see your boats flailing Scale Boats 350 May 26, 2016 07:47 AM
Let's see your peanuts flailing Free Flight 115 Aug 03, 2011 11:41 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
