This thread is privately moderated by fly_boy99, who may elect to delete unwanted replies.
Old Feb 04, 2009, 06:17 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
The fast and fun Funjet!!!
Well I took some video of my newly glassed funjet and put a nice powerplant in here. I have heard comments at the field like holy and bat outta hell so I decided to doppler it and see what the dealio was.
Video is here:
http://www.rcgroups.com/forums/showthread.php?t=995950
I get:
Pass 1: 145mph
Pass 2: 145mph
Pass 3: 150mph
I'm sure if I had more time and my camera wouldn't auto shutdown at 3mins I could easily get to 155mph. As well, I can always go up another cell and add some more power!!! After a short cool down run all components came down pretty cool. What a great all around setup!
Enjoy!
Bryan
fly_boy99 is offline Find More Posts by fly_boy99
Old Feb 04, 2009, 06:48 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
That link is weird, Bryan?
What battery and # cells was that speed obtained with?
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 04, 2009, 07:07 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Yeah it is
bildo baggins is offline Find More Posts by bildo baggins
Old Feb 04, 2009, 08:03 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
Nice!!!
What was the volts under static load? What rpm?
Keep up the good work!
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Feb 04, 2009, 08:14 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
Heres the vid
Old Feb 04, 2009, 10:45 PM
fly_boy99's Avatar
Link is fixed.
Thanks getboosted...
Phil - I set the LVC at 12V and it never hit it. I believe its hitting around 13.5V and doing about 1kW. I need to Eagletree this setup and post it up.
B
Old Feb 05, 2009, 12:29 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
fly_boy99,
My MOTOCALC simulation shows the same 1000W for your 4S 2800KV setup in static condition (on ground)....nice.
According to that simulation; Due to the diameter to pitch ratio of that 6X4 prop it will lose (unload) roughly 1/3 of the watts by about 115 MPH.
What is your level flight speed approximately?
I'm sure there is a lot of speed to gain with a better prop.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Feb 05, 2009, 12:36 AM
teresa is offline
Find More Posts by teresa
Joined Jan 2009
Come on. you will do it well.
teresa is offline Find More Posts by teresa
Old Feb 05, 2009, 01:18 AM
fly_boy99's Avatar
The first two runs were pretty level and I had to go out pretty far and avoid a heli flying at the other end of the field.
My thoughts are that the 6x4 sport prop isn't really 6x4 because if you calc it you would be alot slower but hey video doesn't lie.
B
p.s. CK also did a video with the 36" Lightning with the same power system and went about the same speed or a little faster.
Originally Posted by GryphonRCU
fly_boy99,
Gryphon
Old Feb 05, 2009, 08:59 AM
Fred Sanford is offline
Find More Posts by Fred Sanford
Fred Sanford's Avatar
United States, FL, Punta Gorda
Joined May 2003
FunJet Motor
Bryan,
What motor,ESC,prop and battery are you using? Thanks!
Fred Sanford is offline Find More Posts by Fred Sanford
Old Feb 05, 2009, 02:36 PM
fly_boy99's Avatar
It's all listed at the beginning of the video but I'll post it again:
ARC 28-47-1.5 (with Heat Sink)
Suppo 100A ESC (programmed accordingly)
5A BEC running at 6V
6 x 4 APC Sport Prop (balanced)
4S 3250mah lipo (25C rated)
add your favorite RX and go fly!!!
This setup pulls anywhere from 70-85A depending on your pack. It's typically right around 1kW (that's 1000 Watts) and I typically only launch at 1/2 throttle.
B
Old Feb 05, 2009, 02:48 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
what settings do you use with the 1.5 and suppo? my setups always have issues during startup.
Old Feb 05, 2009, 03:44 PM
fly_boy99's Avatar
My setup currently:
4S cutoff
Auto Throttle
Soft Brake
Normal Direction
1 Degree
16Khz
B
Wanted fast airframe...projeti, funjet, wings, pylon planes...where to get one?? SrCrashAlot Aircraft - Electric - Airplanes (FS/W) 8 Jan 07, 2008 05:36 AM
Wanted F5D pylon racer , or something else fast and fun wanted GyroRon Aircraft - Electric - Airplanes (FS/W) 11 Oct 04, 2007 08:44 PM
Sold Wattage Reno Racer FAST, Cheap, Fun! Tommy D Aircraft - Electric - Airplanes (FS/W) 7 Jun 08, 2005 07:31 AM
Mini HotSpot EDF project.. small.. fast & fun eliotwebb Electric Ducted Fan Jet Talk 8 Feb 09, 2005 04:17 PM
Park flyer looking for fast and fun plane Mac8 High Performance 13 May 08, 2004 10:54 AM
