This thread is privately moderated by tele1974, who may elect to delete unwanted replies.
Old Feb 04, 2009, 02:26 PM
tele1974 is offline
Find More Posts by tele1974
tele1974's Avatar
USA, OH, Olmsted Falls
Joined Feb 2007
Formosa II
Stilling working on my Formosa II. I plan on installing a 42-40 1000kv motor. I have the motor mount fabricated and just waiting for the opportunity to install and do some wattage testing. I had to cut back the fuse to move the esc and I opened up the air flow. Should work just fine. I will post some pictures of the mount soon.
tele1974 is offline Find More Posts by tele1974
Old Feb 05, 2009, 08:10 AM
AMT is offline
AMT
Find More Posts by AMT
AMT
Utah
Joined Mar 2003
My motor mount
I am using a Scorpion Motors S-3014-18 with a Hyperion Z30 motor mount. I am hoping it will balance with all that weight forward. The mount is attached to some light ply and there is also a stick glued in that the ply is attached to.
AMT is offline Find More Posts by AMT
Old Feb 07, 2009, 05:32 AM
tele1974 is offline
tele1974's Avatar
Joined Feb 2007
Testing
I ran up the Formosa yesterday. 44 amps and 645 watts on 4s. With the motor mount is sounds like my Acromaster. The wood mount resonates sound through the foam. Just a little annoying. But - Crazy power. Motor mount looks good AMT.
Old Aug 28, 2009, 04:07 AM
tele1974 is offline
tele1974's Avatar
Joined Feb 2007
That is a sweet motor mount. I would like to mount my Thrust 30 in the formosa next. I had a turnigy 42-40A 1050kv. Too heavy. So I mounted the TGY AerodriveXp SK Series 35-30 11 and on my test flight it began to cog and I had to dead stick it. I throttle back thinking the motor or esc needed to reset. It didn't and came in pretty hard bending my aluminum landing gear back. I have nylon bolt running through the aft portion of the main wing through the front part of the battery bay with plastic plates and epoxy to secure the bolt hole. It held up will and just the landing gear bent. I was running a 4 cell battery so at this point I am not sure what happened.
Old Aug 28, 2009, 04:08 AM
tele1974 is offline
tele1974's Avatar
Joined Feb 2007
Ahh I know the Aerodrive was only rated for 3s. I must have fried it.
Discussion Formosa II GWS4CEO GWS (Grand Wing Servo) 67 Apr 28, 2004 06:41 AM
Formosa II Price and Release Date ihug007 GWS (Grand Wing Servo) 0 Jan 28, 2004 06:16 PM
Formosa II - Is it on the market yet ? edkoz Parkflyers 2 Jan 21, 2004 08:25 PM
Discussion GWS Formosa-II GWS4CEO 3D Flying 8 Jan 15, 2004 03:31 AM
Cool GWS Formosa II proto type test GWS4CEO Parkflyers 10 Jan 01, 2004 02:09 PM
