Old Feb 04, 2009, 10:11 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Doc Austin is online now Find More Posts by Doc Austin
Old Feb 04, 2009, 10:32 AM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Originally Posted by Andrew Jesky
Ben,
One note I want to make is that if you plane to fly on an A30-28s with a 12x6 please make sure you purchase the hacker X-40 or similar. While testing this model I have found that flying these models very hard will cause a shut down and in some cases fire. Just a word of warning.
12x6 on a A30-28S...Wow...that must be for bursts only
JimTMich is offline Find More Posts by JimTMich
Old Feb 04, 2009, 10:40 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
3D is basically that...for sustained full-throttle flying, a smaller prop is in order.
blucor basher is offline Find More Posts by blucor basher
Old Feb 04, 2009, 11:46 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
I wish this had been available when I purchased my 51". Smaller planes go better with my condo and my C240. May have to put the 51" on the block...
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Feb 04, 2009, 11:59 AM
pootman is online now
Find More Posts by pootman
pootman's Avatar
Goleta, CA
Joined Mar 2006
Originally Posted by chribrian
This Scorpion motor looks very good!!
Scorpion 3008-28
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ............................. 8.0 mm (0.315 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 14
Motor Wind ........................................... 28 Turn Delta
Motor Wire ...................... 10-Strand 0.19mm (32 AWG)
Motor Kv ........................................... 1253 RPM / Volt
No-Load Current (Io) ................................. 1.53 Amps
Motor Resistance (Rm) ............................. 0.072 Ohms
Max Continuous Current ............................... 30 Amps
Max Continuous Power ................................ 400 Watts
Weight ........................................ 85.5 Grams (3.02 oz)
Outside Diameter ......................... 37.50 mm (1.476 in)
Shaft Diameter .............................. 4.97 mm (0.197 in)
Body Length .................................. 25.9 mm (1.019 in)
Overall Shaft Length ....................... 64.5 mm (2.539 in)
http://www.innov8tivedesigns.com/pro...products_id=72
That's a sweet motor. My buddy used it place of a Hacker A30-28S and it was awesome. The motor does weigh about .5 oz more than the Hacker but the power more than made up for it. It also ran very cool.
pootman is online now Find More Posts by pootman
Old Feb 04, 2009, 03:16 PM
flyinghigh is offline
Find More Posts by flyinghigh
TDI Abuser
flyinghigh's Avatar
Joined Sep 2002
So a 16M should be a more proper motor for this one ? Im wondering cause if you need a 40 on the 28s the efficiency must be going way downhill with that 12x6 ?
I run a X35 on my 16M with no issues , gets me thinking you know .
flyinghigh is offline Find More Posts by flyinghigh
Old Feb 04, 2009, 04:04 PM
Joined Jun 2003
16M is over 100g...too big. We don't have any problems with the A30-28S, we've just had problems with the smaller ESCs.
Old Feb 04, 2009, 04:11 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
A30-16M seems like a little too much to me......the A30-28S pulls right around 34-37amps & 370-380watts @ WOT on an APC 12x6, depending on the pack. It drops down around 30amps+/- quickly when you get just a click or two off of WOT. The motor seems to handle a quick 5-10 second burst just fine, doesn't really seem to get hot at all.
The A30-28S is about 71grams, while the A30-16M is about 105grams, a big weight increase.
EDIT - Ben beat me
Fliprob17 is offline Find More Posts by Fliprob17
Old Feb 04, 2009, 05:39 PM
3D-Flyer Kevin is offline
Find More Posts by 3D-Flyer Kevin
3D-Flyer Kevin's Avatar
Joined May 2007
WOAH! This could be just the plane that I have been looking for. I have a Scorpion 3008-28 that needs a good home.
3D-Flyer Kevin is offline Find More Posts by 3D-Flyer Kevin
Old Feb 04, 2009, 05:53 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Looks like a really fun plane!
bighead93 is offline Find More Posts by bighead93
Old Feb 04, 2009, 06:37 PM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
I just ordered a GR-25, (On Sale), to get ready for this plane. (In Yellow).
George
refugeefromcalif is offline Find More Posts by refugeefromcalif
Old Feb 04, 2009, 06:39 PM
TDI Abuser
flyinghigh's Avatar
Joined Sep 2002
Ok thanks , I was just wondering as I have both motors but been using them at lower Amps/wattages for years . I guess its just the old school thinking with them as the 28s was originally only rated for around 15a continuous and 25a burst .
Thanks . looks like I have everything already then .
Old Feb 05, 2009, 08:49 AM
Captain Norway is offline
Find More Posts by Captain Norway
Captain Norway's Avatar
United States, TX, Houston
Joined Oct 2007
Originally Posted by The Reaper
hey guys
we have a design for one but in this economy i dont think i will be putting it into production , if you guy want them i would have to do a private preorder and make a limited run of 50 pieces so i would need 50 guys to get together to order them ahead of time. We may end up doing the same thing on the GR60XL
scott
I personally think the GR25 on 3s and 12x6 is more than enough for the 40" Edge, and should do fine in the 42 size as well.
If the GR60XL will work on 7s for the 70ish size planes, I will join in on that.
Captain Norway is offline Find More Posts by Captain Norway
Old Feb 05, 2009, 04:31 PM
flapsdown is offline
Find More Posts by flapsdown
Joined Mar 2007
wooooooooowwwwwwwww.damn I didnt need to see this sweet beauty.I cant believe it flies so well on on the park 480.My 480 is just laying in a box and a speed control to go with it.I have instantly decided I want a 42 inch slick.it's the perfect size and affordable!!!nice going AJ and Ben! yes doc this looks awesome ..so sweeeetttttttt
flapsdown is offline Find More Posts by flapsdown
Old Feb 05, 2009, 04:56 PM
nickflyer is offline
Find More Posts by nickflyer
Monday? Not again...
nickflyer's Avatar
UC Berkeley
Joined Jul 2006
I have a A30-28S on my Groove, but I'm running a 10x5 APC. Will that not quite the omph for this plane? Looks really cool, I might have to forego a SHP and just take the stuff out of the Groove.
nick
nickflyer is offline Find More Posts by nickflyer
Video 3DHS 51" AJ Slick - Cow pasture 3D blucor basher Electric Plane Talk 33 Dec 04, 2010 07:52 PM
Video 3DHS 89" AJ Slick Electric blucor basher Electric Plane Talk 28 Dec 04, 2010 04:31 PM
Sold 3DHS AJ Slick NIB trade for trex 450v2 hairymuffin Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2008 08:39 PM
Video 3dhs AJ Slick harrier machine FlopGun Electric Plane Talk 3 Oct 08, 2008 11:04 PM
