We've waited long enough. Are they here yet?
Latest blog entry: Extreme Aviation Has A New Home
The Thrust 30 looks pretty good....might be a bit heavy
Motor specs Outside Diameter 37.2mm Length 37mm Weight (gr/oz) 105gr / 3.7oz Motor Shaft Dia. 5.0mm Mounting Bolts Dia. M3 Max efficiency Current A * 18-28A Peak current A (15 sec)* 39A Battery pack range ** 2~4 LiPo / 6-12 NiCd Poles 14 KV rpm/V 905 Recommended ESC PA Quantum 40 Peak Watts 420 watts |
From the subsonicplanes.com site: MAX CURRENT 32A VOLTAGE 7.4 TO 11.1 NON-LOAD CURRENT 1.36A EFFICIENCY 87.4% RESISTANCE 0.029 OHMS WEIGHT 88 GRAMS BATTERY 2-3 LIPO NOMINAL POWER 230 WATTS PROP RANGE 10X5 TO 12X6 SUGGESTED ESC FM30A |
This Scorpion motor looks very good!!
Scorpion 3008-28 Stator Diameter ............................ 30.0 mm (1.181 in) Stator Thickness ............................. 8.0 mm (0.315 in) No. of Stator Arms ................................................ 12 No. of Magnet Poles ............................................... 14 Motor Wind ........................................... 28 Turn Delta Motor Wire ...................... 10-Strand 0.19mm (32 AWG) Motor Kv ........................................... 1253 RPM / Volt No-Load Current (Io) ................................. 1.53 Amps Motor Resistance (Rm) ............................. 0.072 Ohms Max Continuous Current ............................... 30 Amps Max Continuous Power ................................ 400 Watts Weight ........................................ 85.5 Grams (3.02 oz) Outside Diameter ......................... 37.50 mm (1.476 in) Shaft Diameter .............................. 4.97 mm (0.197 in) Body Length .................................. 25.9 mm (1.019 in) Overall Shaft Length ....................... 64.5 mm (2.539 in) http://www.innov8tivedesigns.com/pro...products_id=72 |
| Thread Tools | |
| Video 3DHS 51" AJ Slick - Cow pasture 3D | blucor basher | Electric Plane Talk | 33 | Dec 04, 2010 07:52 PM |
| Video 3DHS 89" AJ Slick Electric | blucor basher | Electric Plane Talk | 28 | Dec 04, 2010 04:31 PM |
| Sold 3DHS AJ Slick NIB trade for trex 450v2 | hairymuffin | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 11, 2008 08:39 PM |
| Video 3dhs AJ Slick harrier machine | FlopGun | Electric Plane Talk | 3 | Oct 08, 2008 11:04 PM |
