Old Feb 18, 2013, 12:58 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
well, must be because all my planes are quite nose heavy if not neutral...
rimaarts is offline Find More Posts by rimaarts
Old Feb 18, 2013, 01:01 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I fly neutral... inverted hands off to slightly forward CG.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 18, 2013, 08:52 PM
AK Flyer 76 is offline
Find More Posts by AK Flyer 76
United States, CO, Colorado Springs
Joined Jan 2012
Originally Posted by bryansifsof44 View Post
I flew a Futaba 7C and have had this mix setup before but I honestly can't remember what the mixes were (+or-). Your just going to have to play with the mix and get Rudder (master) to Elevator (slave) to go up in both directions... you will be able to see the elevator move and if it moves in the wrong direction go to the other end (ie: from + to - or - to +). On my DX8 one direction is plus and the other is minus, this was the same with my Aurora 9.
And that's what I was saying that is confusing.... Yes whether it be + or - I don't remember, but one goes up, and the other down. But one mix does allow both to go up or down when I rudder left or right... Maybe I set up separate mixes for rud left, and another mix for rud right?
My Xmitter (Futaba 6c), only has two mixes available. I am considering a radio upgrade, esp, if I need more mix options....
So the question I have now, do you set separate mixes for left and right rudder? And if not, mine goes....say, up elev on right rud., and down elev on left rud, in the mix.
I apologize for my ignorance on the subject, like I said...new to 3d flying still, and have never worked with mixes before....
AK Flyer 76 is offline Find More Posts by AK Flyer 76
Old Feb 18, 2013, 08:56 PM
racerboy65 is offline
Find More Posts by racerboy65
United States, WI, Fond du Lac
Joined Sep 2011
It all depends on what your bird is doing which in turn will dictate which way u mix in you elevator. Go to bone docs video on knife edge mixing
racerboy65 is offline Find More Posts by racerboy65
Old Feb 19, 2013, 03:07 AM
rimaarts is offline
Joined Jul 2011
im flying dx8 and i can input both sided mix on a rudder... i think one of the reasons why i upgraded from dx6 was to get a bit more mixes... (i THINK on dx6 i also had to set up separate mixing) dx8-no such problem (i assume any radio on dx8 level would be the same)
Old Feb 25, 2013, 07:19 AM
jamesrini is offline
Find More Posts by jamesrini
USA, NJ, West Paterson
Joined Feb 2008
Sub'd
jamesrini is offline Find More Posts by jamesrini
Old Feb 26, 2013, 04:03 PM
Helldiver is online now
Find More Posts by Helldiver
my Head is Spinning!!!
Helldiver's Avatar
Joined Aug 2012
Hi Guys,
I just got a 42 slick V1. I am using a Eflite Power 10 HS65MG for rudder and elevator and HS65HB for the ailerons.
Is it okay to use a Eflite 60 amp ESC? the only other ESC i have is the Eflite 40amp. Are there any drawbacks with going with th 60 amp other than weight. Its only a 2gram difference in weight.
Thanks...I just need to attach my control lonkages and my Slick is ready for the maiden. Any suggestions advice?
Helldiver is online now Find More Posts by Helldiver
Old Feb 26, 2013, 04:07 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Originally Posted by Helldiver View Post
Hi Guys,
20 amps
2 grams
jsmith285 is offline Find More Posts by jsmith285
Old Feb 26, 2013, 04:16 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Nope no drawbacks at all other than weight.
Hi Guys,
IndyMatt is offline Find More Posts by IndyMatt
Old Feb 26, 2013, 04:25 PM
Joined Oct 2011
2g isn't a deal breaker, but a light 42 definitely performs better then the heavier 42 post stall.
Old Feb 26, 2013, 05:19 PM
Helldiver's Avatar
Joined Aug 2012
^ thanks for the responses. I am on schedule for a maiden on Saturday morning.
What I have....depends on how she flies this weekend, these are my options
my power 10 is 122grams swinging a 12x6
eventually I hope to get the Omega 103g
Esc is the 60 Eflite ESC is 66 grams
the other 40 Eflite ESC i have is 64 grams....
eventually get a Castle Lite
...yes my setup is kinda on the heavy side
Old Feb 26, 2013, 06:45 PM
Joined Oct 2011
It is... I liked 160g batts or less with a 100g motor and a 50g speed controller... Anything heavier added negative results for me.
Old Feb 28, 2013, 09:21 AM
Jeep_Angler is offline
Find More Posts by Jeep_Angler
Do it upside down
Jeep_Angler's Avatar
Michigan
Joined Jul 2007
Hey there Slick 42 experts...
I am looking at a used (new in the box) 3DHS Slick 42 that's for sale and I am trying to figure out how to tell which version it is. The guy I'm talking to says hes had it for about a year and never even had it out of the box. From what I have read, the canopy is different and the landing gear. Are there more differences? How can I tell from looking at pics?
Sorry for my noobness, but I have never owned a 3DHS plane (or balsa plane for that matter) and I am looking to purchase my first.
Thanks for your help,
Greg
Jeep_Angler is offline Find More Posts by Jeep_Angler
Old Feb 28, 2013, 09:30 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Greg
You can tell by the color scheme
DaaBears is offline Find More Posts by DaaBears
Old Feb 28, 2013, 09:33 AM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
Red or orange with big star on the fuse and wings is new, yellow or red white blue and yellow is old. Old has two piece lg, New has one.
Video 3DHS 51" AJ Slick - Cow pasture 3D blucor basher Electric Plane Talk 33 Dec 04, 2010 07:52 PM
Video 3DHS 89" AJ Slick Electric blucor basher Electric Plane Talk 28 Dec 04, 2010 04:31 PM
Sold 3DHS AJ Slick NIB trade for trex 450v2 hairymuffin Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2008 08:39 PM
Video 3dhs AJ Slick harrier machine FlopGun Electric Plane Talk 3 Oct 08, 2008 11:04 PM
