Old Feb 28, 2009, 09:22 PM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Originally Posted by Andrew Jesky
This plane did balance with the servo in the tail. I think we are going to have the option in there but most will run pull pull. With the rudder in the tail the battery sits about 3/4 of the way under the motorbox.
Andrew
With the rudder servo in the tail and battery 3/4 of the way under the motor box. Were you using a prolite 2200 3s pack or a similar weight pack. I was thinking of trying some 1800mah packs. In that case I am guessing the pull/pull would be preferred.
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Feb 28, 2009, 10:37 PM
rballz is offline
Find More Posts by rballz
I butcher foam
rballz's Avatar
Springfield, MO
Joined Jun 2008
Am I out of my mind for loving to setup pull/pull systems? If I have a choice I'll choose pull/pull any day of the week.
Interesting to see 40" airframes that fly big.
Where's the 3DHS 17" Slick on 1s?
rballz is offline Find More Posts by rballz
Old Feb 28, 2009, 10:43 PM
pootman is offline
Find More Posts by pootman
pootman's Avatar
Goleta, CA
Joined Mar 2006
That would be awesome. 3Ding in the living room, HA!!!
pootman is offline Find More Posts by pootman
Old Feb 28, 2009, 10:46 PM
Andrew Jesky is offline
Find More Posts by Andrew Jesky
Andrew Jesky's Avatar
United States, UT, Tooele
Joined Oct 2002
With a lighter setup your going to want to run pull pull.
As far as push pull over pull pull I will take push pull any day. When you can have a direct linkage hooked up to the aircraft there will be no torque being lost via the pull pull cables. I have noticed a huge difference in my large airplanes, with pull pull I use 3 rudder servos with push pull only 2 in the tail. With all that said it all works and just go with what you like. When I get the production model I'll be doing a build and will see what we can come up with for CG and weights. Depending on weather maybe tomorrow I'll get some action shots in the air.
Andrew
Andrew Jesky is offline Find More Posts by Andrew Jesky
Old Feb 28, 2009, 10:48 PM
rballz is offline
I butcher foam
rballz's Avatar
Springfield, MO
Joined Jun 2008
poot have you seen the Raptor GS over in the micro section? Living room 3D
If you watch the videos everything happens so fast though. I ordered one on 2S which should be in next week.
It's an EPP profile with 16.5" wingspan and 28 grams on 1S (won't power my AR6300 rc) and add about 6g more for 2S (WILL power my AR6300)
I'm suspecting, as the videos show, you can hover in the living room but harries would probably be 200mph.
In short it's REALLY cool, but everything is so fast that I believe you're approaching a level of 3D that's very difficult and overall not a lot of fun (outside of hovering or getting it outside on a calm day).
20-30" foamies and 40"'ish balsa jobs seem to be about as small as we can go right now without things being ridiculous?
Old Feb 28, 2009, 10:49 PM
jadamian75's Avatar
Joined Oct 2007
Andrew
Action Video would be better.
Old Feb 28, 2009, 10:58 PM
Joined Oct 2002
I'll see what I can do but that might take Tim to do that. Looking at the weather tomorrow doesn't look good at all 28 degrees with 18 MPH winds.
Old Feb 28, 2009, 11:02 PM
rballz is offline
I butcher foam
rballz's Avatar
Springfield, MO
Joined Jun 2008
Same weather we have here - and it's snowing. Day before? 65 degrees.
Old Mar 01, 2009, 02:09 PM
major3d is offline
Find More Posts by major3d
major3d's Avatar
United States, TX, Fort Worth
Joined Nov 2008
What is the wing area?
Seems it might be heavy. The 49" sukhoi has a larger wing but, weighs the same.
major3d is offline Find More Posts by major3d
Old Mar 01, 2009, 02:12 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Major, the 49" Sukhoi is a high-40's ounce airframe RTF. The 42" Slick is around 30 oz.
The weight range for both aircraft is in the first post of each of their threads. There's about a pound difference between them.
blucor basher is offline Find More Posts by blucor basher
Old Mar 01, 2009, 02:27 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
The 42in slick looks to have a lighter wingloading than the 40in edge. I take it that it will float a little more?
losifanatic is offline Find More Posts by losifanatic
Old Mar 01, 2009, 02:30 PM
Joined Jun 2003
It floats very nicely, but as on all of these aircraft, component choice has a great deal to do with AUW. For me, the basic setup - 72gram motor and TP2100 prolite - is a perfect balance of float and power.
Old Mar 01, 2009, 02:39 PM
Sippin the Koolaid!
Joined Oct 2007
Wow thats one light battery! Mine are about 15grams heavier. As for the motor are you talking about your new omega motor? When will that motor be avalible? I might have to get 2 of them , one for the slick and one to replace the heavy park 480 thats in the edge. (I took another ounce out of the edge and it made a noticable difference, Im sure another oz from the motor will help)
Old Mar 01, 2009, 02:44 PM
Joined Jun 2003
About a week on the motor availability.
Old Mar 01, 2009, 02:47 PM
Sippin the Koolaid!
Joined Oct 2007
Did I tell you that you are my hero! I think my wife hates you though
Video 3DHS 51" AJ Slick - Cow pasture 3D blucor basher Electric Plane Talk 33 Dec 04, 2010 07:52 PM
Video 3DHS 89" AJ Slick Electric blucor basher Electric Plane Talk 28 Dec 04, 2010 04:31 PM
Sold 3DHS AJ Slick NIB trade for trex 450v2 hairymuffin Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2008 08:39 PM
Video 3dhs AJ Slick harrier machine FlopGun Electric Plane Talk 3 Oct 08, 2008 11:04 PM
