Old Feb 27, 2009, 10:17 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Uhhh......20T and 22T may work for an extreme lightweight 40" EDGE, but it is still low on the power end, I mean you woud really, really have to go lightweight.
Fliprob17 is offline Find More Posts by Fliprob17
Old Feb 27, 2009, 10:28 PM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
I actually have been considering doing an ultra lightweight 40" EDGE. The one I have now is all up at 28oz. and is one of the best, if not the best plane I have flown. Just fantastic. So I have been crunching numbers and figure I can get around 24oz. all up with the 20T-1030 I have laying around. So that's 1.5lbs x 150 watts per pound = 225 watts potentially required on a vertical. That would be pushing the 185watt rated motor, but might be possible.
Old Feb 27, 2009, 10:48 PM
XXLBMXER is offline
Find More Posts by XXLBMXER
Team 3DHS
XXLBMXER's Avatar
Los Alamos CA .
Joined Jan 2009
Man Im glad we can let guys like you and Ben crunch numbers, when I do stuff like that I crunch planes Thanks again Rob for the sweet vinyl.
XXLBMXER is offline Find More Posts by XXLBMXER
Old Feb 27, 2009, 11:15 PM
rballz is offline
Find More Posts by rballz
I butcher foam
rballz's Avatar
Springfield, MO
Joined Jun 2008
200-205 watts if you're as good as AJ
rballz is offline Find More Posts by rballz
Old Feb 28, 2009, 12:14 AM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Originally Posted by losifanatic
. Any help would be greatly appreciated. Sorry to keep hounding you all on this but I just want to make sure I am going to have a really great setup in this thing(and I dont want to buy something and it not have enough power and then I have to buy another) I have done that tooooo many times
Go with whatever 3D Hobbyshop recommends and you should be happy. I have 4 of there recommended setups and have plenty of power on all of them. I am going with a Hacker a30-28s with an airboss 35 esc.
jadamian75 is offline Find More Posts by jadamian75
Old Feb 28, 2009, 11:07 AM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
I actually have been considering doing an ultra lightweight 40" EDGE...
FWIW - with the 12x6E I don't think my Himax/Cobri is putting out much more than 200 watts and my power is fine (mine is just under 27 ounces).
jfv61 is offline Find More Posts by jfv61
Old Feb 28, 2009, 07:01 PM
Andrew Jesky is offline
Find More Posts by Andrew Jesky
Andrew Jesky's Avatar
United States, UT, Tooele
Joined Oct 2002
Guys,
Here are some pictures of the 42" Slick. You will also notice that there is a different color motor in there right now. I have been doing a little bit of testing on a new Omega motor for Ben. This motor is a 72 gram motor and will be priced really well. So far its working really well.
I put this motor on a 12x6 prop and hooked it up to a 3dhobbyshop 3s 2200 pack and here are the results. The motor was making 350 watts at 30-35 amps. The pack is an older pack that was flown a bunch at SEFF and a bunch this summer. I think i could go down to a 11x5.5 and get a little less performance but it still will be really good. I went out tonight and put a flight on the plane and it seemed to be really nicely setup even though it was 25 outside.
NOTE: This model has been changed to check a few things on the aircraft. For example this airplane has the rudder servo in the tail. I did this to check and see how it would work out back there. The rudder Pull pull setup will be right where the receiver sits. I also hogged out the motorbox to see what really could be gotten away with.
Andrew Jesky is offline Find More Posts by Andrew Jesky
Old Feb 28, 2009, 07:15 PM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
Nice, nice, nice
Sounds like good power from the 72g
Old Feb 28, 2009, 07:26 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Doc Austin is online now Find More Posts by Doc Austin
Old Feb 28, 2009, 07:36 PM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Awesome pics. Thanks Andrew!
Bigster is online now Find More Posts by Bigster
Old Feb 28, 2009, 07:41 PM
jadamian75's Avatar
Joined Oct 2007
Originally Posted by Doc Austin
Will the plane balance ok with the rudder servo in the tail? If I have a choice I generally like pushrod.
+1 for pushrod rudder if it balances OK. Much faster to setup and does not require as much maintenance.
Old Feb 28, 2009, 08:12 PM
DG40 is offline
Find More Posts by DG40
Sam Adams Fan
DG40's Avatar
USA, PA, Honesdale
Joined May 2008
Screws in the wing tip. Experimenting with SFG's?
DG40 is offline Find More Posts by DG40
Old Feb 28, 2009, 08:47 PM
Joined Oct 2002
This plane did balance with the servo in the tail. I think we are going to have the option in there but most will run pull pull. With the rudder in the tail the battery sits about 3/4 of the way under the motorbox.
DG,
Your correct, I was messing with SFG's to see how they would work but I found that they make little difference. I'm really looking forward to going out tomorrow and putting a few more flights on the plane. I have a few lighter packs that I want to try and see how it handles it.
Andrew
Old Feb 28, 2009, 09:14 PM
losifanatic is online now
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
AJ Thanks for the info, I just cant wait for this little thing to be avalible! Wow a 72gram motor thats putting out 350watts(now thats what Im talking about!!!!)
Man I am always wanting time to slow down b/c it seems to fly by so fast(my kids are growing up so quick & im getting older) but when you get news like this it seem to creap by and it wont go by fast enough. Ahhh its messing with my head(will the end of march get here all ready)
losifanatic is online now Find More Posts by losifanatic
Old Feb 28, 2009, 09:15 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Here's the vid of you 40" Edge JFV
3DHS 40" Edge Excitement ! (9 min 29 sec)
Lonelasso is offline Find More Posts by Lonelasso
Video 3DHS 51" AJ Slick - Cow pasture 3D blucor basher Electric Plane Talk 33 Dec 04, 2010 07:52 PM
Video 3DHS 89" AJ Slick Electric blucor basher Electric Plane Talk 28 Dec 04, 2010 04:31 PM
Sold 3DHS AJ Slick NIB trade for trex 450v2 hairymuffin Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2008 08:39 PM
Video 3dhs AJ Slick harrier machine FlopGun Electric Plane Talk 3 Oct 08, 2008 11:04 PM
