Old Feb 01, 2009, 01:59 PM
butch4u is offline
Find More Posts by butch4u
FLYGUY
butch4u's Avatar
USA, FL, Punta Gorda
Joined Sep 2003
2.4 module for Hitec Eclipse 7
A while back I saw an ad for a module to replace the Spectra module on an Eclipse 7 to convert it ti 2.4. Anyone know who sells it ? Dan
butch4u is offline Find More Posts by butch4u
Old Feb 01, 2009, 02:03 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Hobbycity carries the ASSAN X8 system. About 90.00 for a TX, a 6ch and a 7 chan RX.
Use the FUTABA module for Hitec conversions (Eclipse and Optic radios)
JimNM is offline Find More Posts by JimNM
Old Feb 01, 2009, 02:11 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Xtremepowersystems.net
4*60 is offline Find More Posts by 4*60
Old Feb 01, 2009, 02:19 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
^^ ASSAN receivers run from $20 to $35 for 4 to 7 channels. The 8,9 and 10 channel are a littel higer.
Old Feb 01, 2009, 02:51 PM
cynjon is offline
Find More Posts by cynjon
Retired USAF
cynjon's Avatar
USA, SD, Piedmont
Joined Jul 2005
Is this the thread you saw? The Spektrum module for Futaba should work fine as JimNM said. $109 WITH an AR7000 RX is a steal!
cynjon is offline Find More Posts by cynjon
Old Feb 01, 2009, 02:57 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
^^*^^ The ASSAN module is the one that I am using... their unit fits both FUTABA and Hitec - or you can get the JR version...
http://www.hobbycity.com/hobbycity/s...W/_Module_&_RX
Old Feb 01, 2009, 03:06 PM
butch4u is offline
FLYGUY
butch4u's Avatar
Joined Sep 2003
Thanks guys I knew you would know. Dan
Old Feb 01, 2009, 03:23 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
I suggest that you will want to get one of these to go with it...
9.00 for an extended antenna that will move the antenna to the top of your radio...
http://www.himodel.com/radios/Extend...RF_Module.html
Himodel also carries the ASSAN stuff - but I tend to order from HobyCity more often. To fit the 2.4 antenna to the top of the Eclipse...
1 - remove the 72 mhz antenna
2 - dremel cut a slot up the back of plastic turtleneck 72 mhz antenna holder
3 - Smear a good size glob of goop around the base of the 2.4 antenna holder and insert into the slightly larger 72 mhz antenna hole.
It looks a little red-neck, but I'm not ever going back to 72 mhz and the fix is good enough for me AND the number 1 reason - I'll never worry about the antenna/tx module interface vs. the ground.
If you need more info - just shoot me a pm.
JimNM
Old Feb 01, 2009, 05:22 PM
butch4u is offline
FLYGUY
butch4u's Avatar
Joined Sep 2003
JimNM
Thanks again. Dan
Old Feb 04, 2009, 10:55 AM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
http://www.rcgroups.com/forums/showp...postcount=2714
Photos of the installation
Old Feb 04, 2009, 11:52 AM
br@m is offline
Find More Posts by br@m
The Netherlands
Joined Oct 2006
New Hi-tec 2.4GHz solution
Hi-tec will introduce their own 2.4GHz system at the Nürnberg Toy Fair.
It's called AFHSS Adaptive Frequency Hopping Spread Spektrum
http://www.hitecrc.de/store/news.php
br@m is offline Find More Posts by br@m
Old Feb 04, 2009, 11:54 AM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
As eluded to here: http://www.rcgroups.com/forums/showthread.php?t=995220 the Hitec 2.4Ghz system does exist and will be available in the near future.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Feb 04, 2009, 12:16 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Mike.
Since it is so late to the game, I hope it is 100% bullet proof when it comes out. Even the Jeti system has been found to have some significant flaws. If the engineers have been reading the posts, they should have had an extremely well detailed feature list and I hope it hits the ground with receivers from 2 grams and larger.
village_idiot is offline Find More Posts by village_idiot
Old Feb 04, 2009, 12:59 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Hitec's track record for version 1.0 bugs is not really very good so I'd advise folks to sit on the fence for a few months and see what kind of experience the early-adopters have before forking out for this new system.
eg: (but not a complete list)
Electron 6 heat issues
Fusion 9 vibration issues
Digital servo lock-up issues
Digital servo compatibility issues
Optic 6 firmware issues (AAA bug)
Optic 6/Spektrum case-fit issues (many crashed models)
QPCM receiver resolution issues
etc, etc.
Hitec (eventually) make really good stuff -- but they do seem to need a good beta-test program to avoid these stuff-ups.
XJet is offline Find More Posts by XJet
Question Spektrum 2.4 module for Hitec Eclipse radio? hotwheels Radios 5 Dec 29, 2008 09:34 PM
Found WTB: Spectra module for Hitec Eclipse 7 kookboy Aircraft - Electric - Helis (FS/W) 3 Jan 20, 2006 04:01 PM
WTB 6ch. or more RX for hitec eclipse 7 FiremanJoe Aircraft - General - Radio Equipment (FS/W) 2 Apr 05, 2005 09:27 PM
where to find 35Mhz spectra module for hitec eclipse ? oded mazor Electric Plane Talk 3 Dec 28, 2004 09:56 AM
Charger for Hitec Eclipse 7 tx dimple Radios 1 Jun 16, 2003 02:36 AM
