Old Feb 16, 2009, 11:08 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Wow,Geode!
How could I miss this thread.Awesome!
You are lucky one with CNC cutter,in my world everything done by hands.
Subscribed.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Feb 18, 2009, 12:34 AM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Hi Yuri, You're a very good builder to create your glider with hand.
The failure rate of my hand cut wing core is just too high. In the long run, CNC foam cutter is a better investment for me.
And I don't have to inhale the fumes as much .......
Some more foam core cut .....
Geode is offline Find More Posts by Geode
Old Feb 18, 2009, 05:59 AM
r/c junkie is offline
Find More Posts by r/c junkie
TEAM OZSKUNKWORX
r/c junkie's Avatar
KORUMBURRA IN THE BOONDOCS
Joined Jan 2006
Geode great build on an interesting project.
Shane
r/c junkie is offline Find More Posts by r/c junkie
Old Feb 18, 2009, 07:26 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Wow, those are some thin wings! Have you said how you will construct them?
Sleedo is offline Find More Posts by Sleedo
Old Feb 18, 2009, 09:59 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Looks like conventional tape/covering is not going to work for this thin MG06 airfoil.
Will be doing vacuum bagging EPP instead.
I was thinking about CF spar with 1.5oz FG. After cutting the wing, I think I need to beef up the layup a little bit. Especially for the front wing which also serves as landing gear.
May be adding more CF and additional Kevlar doubler 1 inch after LE, so I can have a soft LE (1.5 oz FG) and stiffer wing and aileron (1.5 oz FG+Kevlar). Let me know if you think this scheme will work or not. Thanks in advance.
Geode
Old Feb 18, 2009, 10:18 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Vacuum bagging EPP
BTW, here is an example of bagged EPP vertical tail with 1.5 oz FG and CF tow.
Almost as smooth as mylar, stiffer and still bounce back after compression.
Old Feb 18, 2009, 10:49 AM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
Here is a technik I learned how to finish EPP fuses,You probably know it Yourself.
Sand as good as You can ,fill with Light Spackle putty/Home Depot/dry and sand again.Then spray 3M 77 light and cover with 3/4 oz cloth.
Soak this with Thin CA,/drops from a bottle/then dry,fine sand and paint.
I can finish a fuse in one hour from scratch.Quality is amaizing and smooth like molded .Does not gain any weight.Feels like an egg shell.
I did even a set of small wings once,but You have to be careful and secure wings before spreading CA as CA warps wing while drying.
Yuri.
Old Feb 18, 2009, 11:57 AM
MicroRotors is offline
Find More Posts by MicroRotors
3D Toy Designer
MicroRotors's Avatar
USA, CA, Hesperia
Joined May 2001
Holy Mackerel,
You are haulin-butt on this build!
Bill
Envy of your speed ....
MicroRotors is offline Find More Posts by MicroRotors
Latest blog entry: My New Toy!
Old Feb 18, 2009, 01:08 PM
glasairIII is offline
Find More Posts by glasairIII
Lover of fast slope gliders!
glasairIII's Avatar
United States, AZ, Goodyear
Joined Apr 2004
Two words. "new stuff" Plenty of torsional strength.
glasairIII is offline Find More Posts by glasairIII
Old Feb 18, 2009, 09:22 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Yuri.
Thanks for the info. I was scratching my head to decide if I want to bag the fuselage like the wing. Looks like I have an alternative.
I probably will do just like what you did except using epoxy instead of CA. Is that fuse for your scratch build Alula? Look very sweet.
Geode
Old Feb 18, 2009, 09:23 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Originally Posted by MicroRotors
Holy Mackerel,
Bill
It's suppose to be a Quickie. Isn't it?
Old Feb 18, 2009, 09:24 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Like to get some NS to try it out someday. Thanks.
Geode
still have 100 x 50 ft2 of FG to digest.
Old Feb 18, 2009, 09:26 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Some desk top test fly ......
Old Feb 18, 2009, 11:43 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
Goede,just try a small piece of EPP foam with CA /on fresh air/.I bet You are going to love it better ,cause there in not as much weight as with resin and instant results./This is Quickie ,right ? /
No this fuse from Orbus I am finishing mold for Alulas fuse next week.Being working too much lately.
Yuri
trying to find CG for burt rutan quickie aaronredbaron Modeling Science 31 Jun 01, 2012 02:00 PM
A good Axis project. Stuart Warne Scale Kit/Scratch Built 57 Apr 27, 2005 06:27 AM
WTB: St. Croix Burt Rutan Quickie Matt Chester Aircraft - Fuel - Airplanes (FS/W) 0 Apr 19, 2004 12:19 PM
Info needed on the Rutan Quickie Mike Hall Modeling Science 12 Apr 16, 2004 05:21 AM
Scale PSS Project Mr B.... Slope 10 Jun 12, 2003 12:13 AM
