Old Feb 01, 2009, 08:07 AM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Originally Posted by flyonline
Trying to think outside the box here, but a few suggestions:
1. Make the front canards fixed (i.e. no moving surfaces) and have all control in the rear "elevons" (for lack of a better word) -- Not sure if this is feasible though.
2. Have magnetic/plastic bolt attachment for the canards with a super long and easily accessible/breakable servo lead, so that a serious landing will only knock the wing off.
3. Make the canard from EPP with Burly/NS to prevent damage, and the rear wing from foam/bagged/sheeted (if you feel like it).
Looking forward to seeing the outcome.
Steve
Interesting ideals. Will make some use of them down the road. Thanks.
Geode is offline Find More Posts by Geode
Old Feb 01, 2009, 08:20 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Originally Posted by Alex.Schweig
Hey Geode:
Not sure this is really helpful, but I like to fly power models as sailplanes on CRRCsim, and there happens to be a Rutan Quickie.
It does loop well, does tight turns, but the rolls are a bit barrely. Try using a strong launch on CRRC (1.5-2.5) plus 25-30 mph wind
That's some good tools I can make use now. And thanks for the pics.
My question is how to configure the control surface of a Quickie? The original Quickie (see 1st post) seems to have full span control on front wing and half span control (near center) on the main wing. FW is used for pitch/flap (?) and MW for aileron. Just like a conventional canard.
The aileron seems small and near the center of the roll axis. Quite a different configuration
Not sure if I should configure like the "elevon" (as Steve recommends) or the conventional (with a big lifting elevator/MW)?
Geode
Old Feb 01, 2009, 11:12 AM
slopeboulder is offline
Find More Posts by slopeboulder
Boulder Sloper
slopeboulder's Avatar
United States, CO, Boulder
Joined Mar 2005
Quickie
I was thinking about the same project. I'm planning a lost foam fuse then cut blue foam wings and cover with 1/64 play. I drafted up the fuselage last spring, now I can't find the plans Mine was going to be 60" plus wing span.
Here is a few threads about the quickie that I had bookmarked. the second thread show picture of full size with CG marked on it.
http://www.rcgroups.com/forums/showthread.php?t=115579
http://www.rcgroups.com/forums/attac...hmentid=209341
http://www.rcgroups.com/forums/showthread.php?t=219569
Good luck with project.
slopeboulder is offline Find More Posts by slopeboulder
Old Feb 01, 2009, 12:30 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
slopeboulder, thanks for the links. Will take a harder look.
Lost fuselage plan? I can scale it to any sizes you like. Let's me know if you're interested.
Geode
Old Feb 01, 2009, 01:43 PM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
Originally Posted by Geode
I use Rhino. Recently, I found "Blender" (http://www.blender.org/). Seems to be a power tool with great features and community support.
Thank you. I didn't know Blender. I recently came across Modo, but haven't tried it yet.
http://www.luxology.com/
P-51
F-104
Prop-er is offline Find More Posts by Prop-er
Old Feb 01, 2009, 10:27 PM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
United States, AZ, Tucson
Joined Jan 2007
In 90'or 91' I was out at the airport at Mojave and peered inside one of Rutan's hangar's and think I saw both the ARES and the Pond racer and they were awesome. You can see the ARES fly in the movie Iron Eagle III and I got a hoot out of the German pilot saying "It's the Me-" something or other "it survived the war." Supposedly was 75% more mannuverable than an A-10, and it was also the first totally composite A/C to fire a Gatling gun, I wonder if that guy In Fla. still has the mold's?
prodjx is offline Find More Posts by prodjx
Old Feb 01, 2009, 10:45 PM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
K&A makes an EDF ARES kit - I was eyeing it a while back but decided to try something else. Ken Williams' glasswork is fantastic, I'm sure it could be a nice PSS model if it can be built light.
edit: I think it was TFLG who told me once that someone built an ARES for one of the PSS festivals too.
Somewhere in my shop I have two lost foam fuses for a Boomerang, but they came out so heavy it would not have been practical to finish the build. Someday I'll redo them with a little more thought given to weight reduction.
The Quickie/Q2 seems like it's well-suited to the slope if you can make it withstand the landings.
Nauga,
and a matched set of fiberglass baseball bats.
nauga is offline Find More Posts by nauga
Old Feb 01, 2009, 10:47 PM
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
Originally Posted by prodjx
You can see the ARES fly in the movie Iron Eagle III...
No I can't, the forks in my eyes would get in the way.
Nauga,
one of those who stayed away in droves
Old Feb 02, 2009, 01:35 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Thanks to Alex recommendation, I also test fly the Quickie on FMS. The model is about ~1.6 m (60in) span and weight 1.2Kg (42 oz). A pretty challenge aircraft to fly as compared to other virtue aircrafts.
I'm playing with the .PAR file, hopefully can tame it a little bit before I kick-off the actual design.
Geode
Old Feb 02, 2009, 01:52 AM
flyzwell is offline
Find More Posts by flyzwell
flyzwell's Avatar
So Cal
Joined May 2008
Do you have a link for the FMS download?
flyzwell is offline Find More Posts by flyzwell
Old Feb 02, 2009, 09:58 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Try here - http://www.flying-model-simulator.com/
I fly the Quickie in "Switzerland_Slope" with lots of bubbles ....
Old Feb 02, 2009, 12:09 PM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
I have FMS. I was wondering if there is a download for the Quickie.
I see you're tweaking the (.PAR) so I'm guessing you made it yourself.
Old Feb 02, 2009, 10:30 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Have you download the latest FMS 'BETA" version from the above link. Quickie is one of the model from that package.
In .PAR file, I could modify the flight characteristics. This will help me set the target weight, wing loading etc., ....
Old Feb 02, 2009, 10:44 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
A few Quickies on Youtube ....
Quickie ..... always a scratch build aircraft.
No matter it's a small RC airplane
RC Airplane - Burt Rutan Quickie (4 min 0 sec)
or a full scale one
A Real Quickie (0 min 38 sec)
Hope you enjoy,
Geode
Old Feb 02, 2009, 11:06 PM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
Got it. Time to play.
trying to find CG for burt rutan quickie aaronredbaron Modeling Science 31 Jun 01, 2012 02:00 PM
A good Axis project. Stuart Warne Scale Kit/Scratch Built 57 Apr 27, 2005 06:27 AM
WTB: St. Croix Burt Rutan Quickie Matt Chester Aircraft - Fuel - Airplanes (FS/W) 0 Apr 19, 2004 12:19 PM
Info needed on the Rutan Quickie Mike Hall Modeling Science 12 Apr 16, 2004 05:21 AM
Scale PSS Project Mr B.... Slope 10 Jun 12, 2003 12:13 AM
