Old Jan 31, 2009, 02:25 AM
USA, CA, Selma
Joined Sep 2004
"Nibbio" SAM old time R/C glider
Thanks to a VERY generous GianFranco Lusso in Switzerland I now have a very detailed (would you believe 19 very intricately lightened fuselage formers ) full size set of plans for the 3 meter 1945 Italian towline glider (Silvano Macera's "Nibbio") . It appears to be a copy of the original plan and boy is it big (the plan itself is two 3'X6' sheets!).
The original structure is quite modern for a 1945 model so I only plan to make a couple of minor structural changes other than the ones required to allow the use of R/C.
The changes I am planning are as follows:
1. Increase the size of the center section spruce spars from 3mmX10mm (1/8"x13/32") to 3/16"X1/2" on top and 1/8"X1/2"on the bottom, decreasing the sizes towards the tip.
2. Adding spar webbing.
3. Replacing the alumininum blade wing joiner with one made of carbon fiber.
Attached is a drawing of the plane, and photo of GianFranco's 2.5 meter version.
Time to clear the bench.
John
Oian is offline Find More Posts by Oian
Discussion Have Old Time R/C Airplanes For Sale Misskitty Vintage & Old-Timer Designs 14 Aug 22, 2007 10:47 PM
Old School R/C Zipper Kits Now available Paul Susbauer Vendor Talk 0 Nov 05, 2002 03:08 AM
Pietenpol from Old School R/C J Bergsmith Scale Electric Planes 59 Jun 14, 2002 12:42 AM
LiteFILM available from Old School R/C for online ordering Oldschoolrc Aircraft - Electric - Airplanes (FS/W) 2 May 22, 2002 10:27 AM
Pietenpol from Old School R/C J Bergsmith Parkflyers 2 Apr 07, 2002 03:38 PM
