Old Jan 30, 2009, 07:49 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Build Log
Low cost DIY XBee/GPS plane locator
Due to many email requests I've put together plans for a low cost XBee/GPS interconnect circuit that lets you know where your plane is even when it goes out of sight. Parts only cost a couple bucks and take a few minutes to assemble. A wiring diagram is shown below. Four components are required: regulator, two caps, and a resistor. The LEDs are optional but help show power, RF link status, and GPS lock.
The idea is to connect output from a low cost Globalsat GPS receiver to input of an XBee 2.4ghz radio module. GPS and RF modules can be had for as low as $20 each. A ground tracking station consists of any laptop with serial or USB ports and another XBee module. I found the best software to track position of the plane is Delorme Street Atlas but many prefer Google Earth.
The GPS receiver is used as-is but the XBee requires some configuring so it will have the same baud rate as the GPS. This is done by connecting to a PC and using so called AT modem commands as follows:
+++ (put in command mode)
ATCTFFFF (set max command timeout)
ATBD2 (sets baud rate to 4800)
ATAC (apply changes)
ATWR (write to non-volatile memory)
ATCTFFFF is not absolutely necessary but makes it easier to enter commands so you don't have to hurry.
Attached is a picture of the assembled unit and Delorme screen capture of a test flight of my Solar UAV. Let me know if you see any errors or have questions.
rich smith is offline Find More Posts by rich smith
Old Jan 30, 2009, 08:38 PM
VasMan is offline
Find More Posts by VasMan
VasMan's Avatar
@Home
Joined Jan 2007
Do you know where they can be found for around $20 each? I looked up the EM406 module and the lowest price I found was $48.
Vas
VasMan is offline Find More Posts by VasMan
Old Jan 31, 2009, 12:01 AM
Jappa_Indy is offline
Find More Posts by Jappa_Indy
Indianapolis
Joined Jul 2006
Yea, tell us where we can get them for $20!!!
Jappa_Indy is offline Find More Posts by Jappa_Indy
Old Jan 31, 2009, 12:10 PM
rich smith's Avatar
Joined Dec 2006
About 5 yrs ago I bought up couple dozen Trimble 502 from BG Micro for $11 shipped. They're only 4ch and a bit heavy but work. More recently I got a dozen or so Globalsat BU353 units on Fleabay for $22 ea that had USB em4xx easy to convert to RS232. Last year a fellow was selling em410? here on RCG pretty cheap but don't remember exactly how much. A client I did the autopilot for purchases em406 in quantity for about $12 ea on a slow boat from China. Sometimes I piggyback. Couple months ago on black friday Boost i425 cel phones were on sale for $10 w/rebate so I picked up a bunch of those, pulled the GPS, and used the included time for my cel. Sparkfun charges $60 for em406 so they make a hefty profit but have excellent service.
The deals are around if you shop. FWIW $48 don't sound too bad considering commercial tracking systems like this cost hundreds or even thousands.
Old Feb 02, 2009, 10:45 AM
rich smith's Avatar
Joined Dec 2006
In another thread more info was requested on the PC end of the link so I updated the schematic to include a low cost interface. It's pretty much the same as the one for the plane but with N-FET inverters instead of the GPS. Note that the XBee eval kit (Digikey) and a modified FTDI adapter can also be used.
I also got requests for more on the Trimble 502 GPS units so will try to dig up that soon.
Old Feb 02, 2009, 11:23 AM
Kadath is offline
Find More Posts by Kadath
Kadath's Avatar
Quebec, Canada
Joined Apr 2008
Is this 2.4 GHz application compatible with Spektrum DSM2 radios?
Kadath is offline Find More Posts by Kadath
Old Feb 02, 2009, 11:51 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
What sort of range are you getting out of that Rich??
I think one of the magazines like Radio Control Models and Electronics, the UK one http://www.modelflying.co.uk would love to run a how to with this.
Cheers
G
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Feb 03, 2009, 12:57 PM
rich smith's Avatar
Joined Dec 2006
Yes, there is no frequency conflict. Last summer while testing Spectrum with 6200 RX the plane went out of TX range and went down about 2/3 mile from launch. We still got GPS track w/Delorme which made it real easy to find the plane on the ground. So XBee range is longer than that.
At first I though XBee was interfering w/RX because they were both 2.4ghz but tests w/o the XBee showed that was the limit for Spectrum in the area. I think trees cut the signal. We switched back to 72mhz for longer range.
Old Feb 03, 2009, 08:11 PM
dellarb is offline
Find More Posts by dellarb
Joined Feb 2009
May seem a silly question.
But what software do you use to get the received data from the ZigBee to your computer?
dellarb is offline Find More Posts by dellarb
Old Feb 04, 2009, 12:06 PM
rich smith's Avatar
Joined Dec 2006
I get about 1/2 mile with standard antennas and a little over 1.5 mile with MR RCCAMs $1 patch antenna. Depends on conditions/geography, actually got over 2 miles at one site. "Better than idea conditions" like they say in the commercial.
Magazine article would certainly reach a wider audience. If anyone else builds one of these it will tell us if there's any bugs in the docs.
Cheers
G
Old Feb 04, 2009, 12:10 PM
rich smith's Avatar
Joined Dec 2006
Originally Posted by dellarb
May seem a silly question. But what software do you use to get the received data from the ZigBee to your computer?
No software at all. GPS connects directly to XBee.
I use either Procomm under DOS or Hyperterm under WINDOWS to capture GPS data and Delorme Street Atlas to show maps. Google Earth works too.
Old Feb 05, 2009, 12:06 PM
rich smith's Avatar
Joined Dec 2006
Paul and Razor,
Per your request here is more info on the $20 Trimble model SVee-Six-CM3. Here's a link to one person who used it as a mobile GPS:
http://juliepalooza.8m.com/sl/trimble.htm
Attached is the software I used to set up for NMEA and a pdf with wiring. Note that the MAX232 chip is not needed to talk to the Xbee which has inverted serial.
Old Feb 05, 2009, 12:26 PM
Indianapolis
Joined Jul 2006
What GPS module is in the i425?
Old Feb 05, 2009, 05:01 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Very cool. I was thinking of something like this but for a different purpose - locating my son when he runs away at the shopping malls, theme parks etc. Do you think it would have the resolution and accuracy? Is it possible to connect it to say a handheld and have realtime updates?
I work in product development, and we had a client come to us and ask if we could develop a device which you clipped onto your child's clothes, sewed into his pants or whatever, however there is a plethora of patents preventing us/him from doing it, but for an individual non-commercial application it's wide open. We never went any further than an IP search, but it would be a cool thing to have if you have a child who is difficult to keep close at hand (like my son!), nothing more scary than realising you can't see him in the crowd any more, terrifying, actually.
Stu.
stumax is offline Find More Posts by stumax
Old Feb 05, 2009, 05:14 PM
Indianapolis
Joined Jul 2006
Stu.
The limit with this GPS device is you are limited to the range of the Xbee module. It does no logging in itself. However it would not be hard to use a PIC or something to interface an SD card for logging. There are examples out there.
Discussion Low Cost Auto Pilot Using Fma Autopilot And Gps FAKHREALAM UAV - Unmanned Aerial Vehicles 420 Dec 09, 2011 01:02 PM
Idea Low-Cost UAV using 'Inherently Stable' airframe, GPS, and Altimeter AnthonyRC DIY Electronics 7 Apr 20, 2005 03:56 PM
Dreaming of a low cost, ROG small EDF plane Will-MO Electric Ducted Fan Jet Talk 3 Jul 03, 2003 02:38 PM
