Old Jan 30, 2009, 05:21 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Team30 Micro EDF FW-35A Lighting II
This is my latest project where I will be testing the Team30 EDF units in a real environment. The plans were from parkjets.com scaled down to around 70% to give a 15" wingspan. Initial flight testing will be on 3S.
I did the build just as Mr. Boogie did. Fuse first. Formers and motor in.
Then the forward fuse sides and bottom.
I closed the rear fuse up after installing the servo's and esc and running the wiring.
Next, the rear fuse top and vertical fins ( I added a tailpipe too).
The wing is 2 sheets of depron with depron ribs. Each also has a 1.5mm CF rod extending into the fuse.
Both wings now on and installed the first taileron. I used Teflon hinges as there was barely any 'meat' to use for hinge area. Using the Teflon hinge assures rigid, strong mounts.
The other taileron installed. I also used filler to smooth out any sharp joins as I went along. I gave the model a light sanding all over to smooth surfaces.
I wasn't going to paint it before maiden but decided to splash some grey on top and white on the bottom to help with orientation.
I have to now make a canopy area. I will be carving a foam block for this. I was going to vacform one but this will be faster for the moment. Once on, I can see where the lipo needs to go for correct CG and will cut a hatch in the right spot.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 30, 2009, 06:27 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Wow, looks great Nitro! What thickness Depron?
mcross is offline Find More Posts by mcross
Old Jan 30, 2009, 07:14 PM
Zackmd1 is offline
Find More Posts by Zackmd1
Joined Jan 2009
Looks nice! what is the auw?
Zackmd1 is offline Find More Posts by Zackmd1
Old Jan 30, 2009, 07:43 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Thanks Mike.
I used ~1.5mm depron - same stock as used on the Hawk and Skyray. I am running dangerously low on it now. I think I can get one more model in (GGRN's Huckebein TA 183 is the plan) and that's it.
Must source more as FHHobbies kinda gave up on supplying it.
Also should mention that I skinned the front bottom fuse back to the servo's with tissue and 2 coats of WBPU to toughen it up.
AUW is 118g including a 360 3S 20C HC Rhino lipo.
As a comparison - the Hawk currently weighs 92g with a GP 300 2S 20C lipo (weight creep thanks to all the added mods and repairs ). The extra wing area and double the thrust I have on the F-35 will more than compensate for the extra 26g of weight.
Old Jan 30, 2009, 07:55 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
wow that is awesome! I LOVE the F-35! its my favorite new-gen fighter plane. yours looks very sweet nitro
you have got to get it on video for us all to drool over lol
derk is offline Find More Posts by derk
Old Jan 30, 2009, 08:21 PM
metroidrc is offline
Find More Posts by metroidrc
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
look at your fleet growing... congrats Nitro!
metroidrc is offline Find More Posts by metroidrc
Old Jan 31, 2009, 03:41 AM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Nitro - you are the king of scale micro edf jets, without any doubt - admiring your surgical perfection in building and finishing them, never any compromise - WOW !
relaxr is offline Find More Posts by relaxr
Old Jan 31, 2009, 04:47 AM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
Looking forward to watching the video.
Steve
stegla is offline Find More Posts by stegla
Old Jan 31, 2009, 09:06 AM
relaxr is offline
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Thats true - the vid will show it! Is there a vid about your hawk anywhere here? Thanks in advance
markus
Old Jan 31, 2009, 10:15 AM
mike3976 is offline
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
NC, When you re-sized the parkjet.com free plans, are they re-sized into a PDF?
If so, would you be so kind to post the re-sized plan? Please,please,please
mike3976 is offline Find More Posts by mike3976
Old Jan 31, 2009, 05:59 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
The things you guys have me doing on a Sunday morning....
I've created a pdf, tiled to print on A4 sized paper setting.
Old Jan 31, 2009, 06:02 PM
termite is offline
Find More Posts by termite
Utica Il.
Joined Dec 2002
You are one of the GREAT resourses here on the groups
Randy
termite is offline Find More Posts by termite
Reply With Quote  (Disabled)
Old Jan 31, 2009, 06:28 PM
mike3976 is offline
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
Well! You never know unless you ask! Thankyou Much.
Mike.
Old Jan 31, 2009, 09:19 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Relaxr:
http://www.rcgroups.com/forums/showt...53#post8964353
Old Feb 01, 2009, 02:11 AM
relaxr is offline
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Wow, thanks! Very fast, even on this large field, there seems to be no part of a second without touching the sticks, preventing it to fly out of the eyes range. Thats some real "positive stress". Did the last rounds show the slowest possible speeds with this dart ?
markus
New Product EPS Jet FW-35A Lighting II sigma_fr Foamy EDFs 1208 Jul 10, 2014 12:29 PM
Discussion Team30 Micro EDF T-45 BAE Hawk NitroCharged Micro EDF Jets and Power Systems 481 Feb 08, 2011 03:04 AM
Discussion Team30 Micro EDF 12" Douglas Skyray - Video now online! NitroCharged Micro EDF Jets and Power Systems 160 Jun 11, 2010 01:54 PM
Video Maiden Flight Of FW-35A Lightning II ray2006 Electric Plane Talk 3 Mar 25, 2010 11:41 PM
micro EDF: how much pitch? steve glass Electric Ducted Fan Jet Talk 6 Oct 17, 2002 01:00 PM
