Old Jan 30, 2009, 11:19 AM
Rishelman is offline
Find More Posts by Rishelman
Knobbs
Friday Harbor, WA -San Juan Island
Joined Aug 2008
Help!
Evo 9 Dual Elev Servos-Mix w/rudd help
Hi all, I've been doing the best I can to learn this radio theory, the Multiplex thought process. I've learned a lot from Joedy's tutorial, but there is one thing has me stumped. Here goes:
Giant scale Yak- Two elevator servos
One normal direction, one reversed
Plugged in to separate channels on Rx
Elev works great until...
I built a mixer to add elevator while knife edge (rudder)
It works as far as the percentages of travel, but, the servos for separate elev halves go in opposite directions. Well I haven't looked if the SERVOS actually go in opposite directions--not the point--control serfaces go in opposite directions.
So---how come the mixer does not maintain the direction to keep that one servo reversed? Do I need TWO mixers for one simple elev/rudd mix?
Please help>> Thanks Rishelman
Rishelman is offline Find More Posts by Rishelman
Old Jan 31, 2009, 04:03 AM
GlowFly is offline
Find More Posts by GlowFly
GlowFly's Avatar
Midlands, UK
Joined Jun 2004
Did you add 'Rudder' or 'Rudd -Tr' to your ELEVATR+ mixer?
Steve
GlowFly is offline Find More Posts by GlowFly
Old Jan 31, 2009, 06:44 AM
Joedy is offline
Find More Posts by Joedy
My other TX is a P4000.
Joedy's Avatar
USA, VA, Raphine
Joined Sep 2002
I would suggest two mixers in this case.
By default, most elevator servos are intended to work in tandem, not in opposite like aileron servos are.
-joedy
Joedy is offline Find More Posts by Joedy
Old Feb 01, 2009, 02:39 PM
Knobbs
Joined Aug 2008
Steve
I added 'Rudder'. Not real clear on what purpose the 'without trim' function serves. Educate me please.
Thanks. Rishelman
Old Feb 01, 2009, 02:41 PM
Knobbs
Joined Aug 2008
-joedy
I was afraid of that, just hoping to not burn two mixer slots for one mix.
Thanks. Rishelman.
Old Feb 02, 2009, 11:02 AM
outssider is offline
Find More Posts by outssider
Joined Apr 2004
to control pitch coupling(elevator) you only need one mixer not a different mixer for each elevator half. You can get different values for both left to right knifedge and right to left.
to control roll coupling you may need two mixers, one for left wing and one for the right wing. If you need to compensate different amounts for both left to right knifedge and right to left then you will need two mixers. I am only using one mixer for aileron also !! I use the same percentages from left to right and right to left. You will never get it perfect anyway so i get it close and compensate with my flying skills to clean it up.
outssider is offline Find More Posts by outssider
Old Feb 02, 2009, 03:00 PM
GlowFly is offline
GlowFly's Avatar
Midlands, UK
Joined Jun 2004
It means that as you adjust the Rudder trim with the trim buttons, it won't also affect any mixer that uses it - like Elevator in your case. The normal Rudder input includes the trim offset - that may not be your intention.
The reason I asked which you used is that from memory the two are treated differently within the Evo as far as left/right coupling is concerned. I can't test it at the moment since I upgraded to Pro which behaves differently.
Steve
Discussion Funtana 90 Dual ELEV servos w/ optic6 help DbleX 3D / Fun Fly Fuel Planes 6 Feb 23, 2006 08:30 PM
Hangar 9 edge 540 dual elavator servos? idealer Giant Scale Airplanes 0 Jun 27, 2004 05:18 PM
Alert Help: EVO 9 Very Cool, yet doesn't work!!! ShamelessMale Radios 17 Jun 11, 2004 10:12 PM
Royal Evo 9 w/Rx etc. tomv36 Aircraft - Sailplanes (FS/W) 0 Apr 07, 2004 01:55 PM
Dual elevator servos w/ Eclipse 7 Arthur_GA Hitec/Multiplex USA 3 Mar 10, 2004 02:38 PM
