Old Feb 14, 2009, 08:39 PM
Sniper.308 is offline
Find More Posts by Sniper.308
I'm a lead farmer Mother ^%$^%
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
I am leary about doing that. Would rather be a little heavy than forget to set timer and rx die. Only less than 2oz anyway for security.
Sniper.308 is offline Find More Posts by Sniper.308
Old Feb 14, 2009, 10:05 PM
JIMinKENTUCKY is offline
Find More Posts by JIMinKENTUCKY
United States, GA, Columbus
Joined Mar 2002
Originally Posted by FlyBoyTha1
One Last Thing Are You Running A High Volt Speed Controller, I'm Wonder If I Could Use This Castle Creation 80Amp I Have Laying Around
I am using a Turnigy 80 Plush good up to 6s. I am using the same controller on 2 other 6s 90mm EDF's at 1500 watts and 70 amps and it is rock solid.
If the Turnigy can, I see no trouble with the CC 80.
I have the BEC disabled on the Turnigy and using a Castle Creations BEC.
Weight 5.33 lbs no batteries
Weight with 2-3s 3300 packs = 6.55 lbs
Weight with 2-3s 4000 packs = 6.95lbs
James
JIMinKENTUCKY is offline Find More Posts by JIMinKENTUCKY
Old Feb 15, 2009, 02:31 AM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
Cool, I Might Get To Maiden Her In The Morning Then
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Feb 15, 2009, 10:19 AM
nieves50 is offline
Find More Posts by nieves50
nananabooboo!!
nieves50's Avatar
United States, OK, Oklahoma City
Joined Mar 2003
This model might get me back into airplanes......
Subscribed
nieves50 is offline Find More Posts by nieves50
Old Feb 15, 2009, 10:32 AM
Joined Mar 2002
Great. Report back if you do.
James
Old Feb 15, 2009, 11:56 AM
Lithonion is offline
Find More Posts by Lithonion
Have you seen my nut?
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Great thread, great videos. Love the sound of your EDF James. Looks like its got plenty of power to push your car out.....
Lithonion is offline Find More Posts by Lithonion
Old Feb 15, 2009, 03:11 PM
FlyBoyTha1's Avatar
Joined Sep 2008
James
Ok I'm Finsh James, My Total Weight Right Now With 6 Cell Battery Is 6.4lbs It Balanced On The CG Balancer Up Side Down At 90mm From The Leading Edge, But Not Sitting Up Right I'm Going To Have To Add Weight To The Nose, I Will Let You Know How Much, After I've Added Weight.
Old Feb 15, 2009, 03:14 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Originally Posted by Sniper.308
Well, mines done, but I'm at 7lbs 5oz's with a 6S1P 4800mah main battery and a 1500mah 2S BEC battery. Everything is balanced at 50mm so I'll find out tomorrow if that's to heavy. Anyone else have a weight yet?
Also, after using a screw on the front of the wings to the fuse I dabbed some clear seal silicone to the trailing edge for structural stability. I don't have the side slats on mine because of weight. Since they don't offer anything but blocking the fan I will try leisure flying for this one.
Where Did You Guys Get 50mm From? My Book Reads 90mm From The Leading Edge.
Old Feb 15, 2009, 03:19 PM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
My wife just ordered the plane for me... Now to sell some things I dont use and get the fan and motor...
Old Feb 15, 2009, 04:18 PM
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
Flew mine today with great success. 50mm back from LE wingjoint at fuse is perfect CG. I had no problems but I usually make mine about a 3-4 degree nose heavy at CG point. Flew it at first with 6S1P 3500mAh 30C packs that weigh 311grm's per pack times 2. Did good but need more Kv mines 16xxkv supposedly. Will try my 1400kv on 9S next time. But may just get and 1800kv motor and be done with it.
Picture in my manual show's 50mm but written as "IDEAL" CG at 90mm. I flew mine twice at 50mm and it flew great, but I always list mine nose heavy by a couple of degrees. It did tilt back once on the way out to the flight line but I was going a little up hill and the ass squated. Again, I don't have the side fins on mine as I didn't want the exhaust airflow blocked more than it already is.
Jason
Old Feb 15, 2009, 04:20 PM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
Was it slow? How agile?
Socomon is offline Find More Posts by Socomon
Old Feb 15, 2009, 04:27 PM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Grats on the Maiden. I want to see how this performs on the Himaxx plug and play fan/motor combo. That is the direction I am leaning.
Old Feb 15, 2009, 04:33 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
The difference between 50mm and 90mm is not something to treat lightly. When in doubt I use the following on-line program and it has worked perfect for me.
http://adamone.rchomepage.com/cg_calc.htm
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old Feb 15, 2009, 04:35 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Jason
Jason What's The Weight Of Yours?
And What's The Different In You Motor That The Readings I'm Getting On My Watts Up Meter? See Below.
One Last Qestion Bro How Fast Do You Thing You Where Pushing?
Old Feb 15, 2009, 04:46 PM
FlyBoyTha1's Avatar
Joined Sep 2008
If He's Looking For The 1800KV Motor Thats The Himaxx Set Up At 1850kv With 5 TO 6lbs Of Thurst On 6 Cells See Below.
Cool pictures of fan flying off EDF-50 unit. hsuusa Parkflyers 1 Jul 08, 2002 03:43 AM
Fan-fold foam EDF Vincent Electric Ducted Fan Jet Talk 8 Jun 19, 2002 06:20 PM
My new jet trainer for EDF 300 kwan Electric Ducted Fan Jet Talk 3 Jun 26, 2001 06:54 AM
Where's the Fan Trainer by Steve Neil? rcdude Electric Ducted Fan Jet Talk 11 Jun 06, 2001 02:42 AM
