Old Feb 14, 2009, 04:07 PM
dusmmdb34 is online now
Find More Posts by dusmmdb34
dusmmdb34's Avatar
Alexandria LA
Originally Posted by JIMinKENTUCKY
Video
Static test run and taxi test.
http://www.rcgroups.com/forums/showt...7#post11584224
As mentioned the manual states 2 CoG. 50mm back from LE and 90mm back.
90mm back is too far. 50mm makes more sense.
The plane will balance at 50mm back with 2-3s 3300 packs but just barely. It could use a little more weight in the nose so 3s 3500's would be perfect up to about 3s 4000's in series.
James
James
Looks and sounds good! You bringing that one to SEFF??
dusmmdb34 is online now Find More Posts by dusmmdb34
Old Feb 14, 2009, 04:11 PM
CRASH_Jim is offline
Find More Posts by CRASH_Jim
Silent but deadly
CRASH_Jim's Avatar
Cataula, Ga
Joined Mar 2005
Hey Jim, that thing looks like it might be a bit faster than some of your other projects. Sounds pretty good. Let me know when you want to take it out. I'll try to shoot vid for you if you want.
CRASH_Jim is offline Find More Posts by CRASH_Jim
Old Feb 14, 2009, 04:15 PM
JIMinKENTUCKY is offline
Find More Posts by JIMinKENTUCKY
United States, GA, Columbus
Joined Mar 2002
Originally Posted by FlyBoyTha1
Looking Good Over There My Man, Looking Good, I'm Just About To Install My Motor Here's Video Part 2 Of The Fan Trainer, I'm Running The Himaxx 96mm Set Up With A 6 Cell 3850 Thunderpower Lipo On This Bad Boy, These Are The Readings I Pulled Of My Watts Up Meter. Looks Pretty Quick
The battery you are using would be about perfect to balance the plane. I need a slightly larger capacity for better balance and to up my watts slightly.
Nice video, very detailed. Especially when you stress not to forget the elevator pin, that would be a nightmare to install after tailplane was already epoxied in.
James
JIMinKENTUCKY is offline Find More Posts by JIMinKENTUCKY
Old Feb 14, 2009, 04:16 PM
Joined Mar 2002
Originally Posted by dusmmdb34
James
Thanks Mike, I usually go to SEFF just to get nice video footage but I may take a few of my own planes this time.
James
Old Feb 14, 2009, 04:17 PM
Joined Mar 2002
Sounds good! It is ready to maiden, just not 100% on the CoG.
James
Old Feb 14, 2009, 05:22 PM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
James
Jim I Just Finished Installing Th EDF Unit, I Take It That You Epoxy Your Wings? I'm So Use To The Larger Ones, That I Want To Make Srew In, Even Though It Does Fit In The SUV In One Shot No Hassles
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Feb 14, 2009, 05:39 PM
Joined Mar 2002
My wings are not epoxied.
See here:
http://www.rcgroups.com/forums/showp...9&postcount=21
I have screws up front on the wings and it is very secure. I could not reach the rear of the wing to install screws there.
I may add a touch of epoxy at the rear of the wing to be safe but not so much that I couldnt cut through (from bottom side of wing) if I absolutely had to remove the wing.
James
Old Feb 14, 2009, 06:25 PM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
Here are a few images of the full-scale Fantrainer for anyone interested and video of the full-scale airplane in flight
RFB Fantrainer (0 min 53 sec)
RFB 400 Fantrainer (0 min 16 sec)
Socomon is offline Find More Posts by Socomon
Old Feb 14, 2009, 07:10 PM
ARCHER7153 is offline
Find More Posts by ARCHER7153
ARCHER7153's Avatar
West Palm Beach , FL, USA
Joined May 2001
Nice
ARCHER7153 is offline Find More Posts by ARCHER7153
Old Feb 14, 2009, 07:32 PM
FlyBoyTha1's Avatar
Joined Sep 2008
See here:
James
I Added The Screw With Just A Little Epoxy No That It Felt It Would Come Off But Depending On This Power Systen I'm Going To Run, If That Thing Weight I 5 To 6lbs I'll Be At A 1:1 Ratio Of Power.
Did You Ever Get A Total Weight On Yours?
Old Feb 14, 2009, 07:51 PM
FlyBoyTha1's Avatar
Joined Sep 2008
One Last Thing Are You Running A High Volt Speed Controller, I'm Wonder If I Could Use This Castle Creation 80Amp I Have Laying Around
Old Feb 14, 2009, 07:52 PM
Sniper.308 is offline
Find More Posts by Sniper.308
I'm a lead farmer Mother ^%$^%
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
Well, mines done, but I'm at 7lbs 5oz's with a 6S1P 4800mah main battery and a 1500mah 2S BEC battery. Everything is balanced at 50mm so I'll find out tomorrow if that's to heavy. Anyone else have a weight yet?
Also, after using a screw on the front of the wings to the fuse I dabbed some clear seal silicone to the trailing edge for structural stability. I don't have the side slats on mine because of weight. Since they don't offer anything but blocking the fan I will try leisure flying for this one.
Sniper.308 is offline Find More Posts by Sniper.308
Old Feb 14, 2009, 07:55 PM
Socomon is offline
Joined May 2006
I don't reckon it is going to be any speedster. Watch that video of the full-scale one. It wasn't any rocket either.
Old Feb 14, 2009, 08:00 PM
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
I'll be able to lose a little weight by going to my 3500mah set up, but I really need 7S on this bird, so I may change to a HV controller if the first flight goes ok. I'll start off with 2x 3S1P 3600mah for initial maiden.
Old Feb 14, 2009, 08:36 PM
FlyBoyTha1's Avatar
Joined Sep 2008
You Should Pick Power Off Your Battery And Use A Castle Creation Bec
Cool pictures of fan flying off EDF-50 unit. hsuusa Parkflyers 1 Jul 08, 2002 03:43 AM
Fan-fold foam EDF Vincent Electric Ducted Fan Jet Talk 8 Jun 19, 2002 06:20 PM
My new jet trainer for EDF 300 kwan Electric Ducted Fan Jet Talk 3 Jun 26, 2001 06:54 AM
Where's the Fan Trainer by Steve Neil? rcdude Electric Ducted Fan Jet Talk 11 Jun 06, 2001 02:42 AM
