Old Feb 12, 2009, 12:38 PM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
Originally Posted by Thomas B
Even a very short thrust tube to neck down the aft end of the fan would help...I think you could do one that is 1"-1.5" long
I was under the impression that it was counter-productive to choke down the exhuast diameter too suddenly (over too short a distance), but I could well be wrong about that.
Socomon is offline Find More Posts by Socomon
Old Feb 12, 2009, 01:40 PM
JIMinKENTUCKY is offline
Find More Posts by JIMinKENTUCKY
United States, GA, Columbus
Joined Mar 2002
As I recall, I think you will see a thrust increase and an amp draw decrease with a proper inlet lip. Also, without the lip, the fan will be prone to cavitation at moderate angles of attack, due to the sharp lip of the bare fan housing. If you do some searching around here, you will see the results of inlet lip tests.
The benefits of the inlet lip were described in one of your previous threads by seeveral people:
http://www.rcgroups.com/forums/showt...ight=inlet+lip
Adding a short thurst tube with a smaller exit area will increase efflux and also slightly increase amp draw.
Thanks, I do recall that thread. Normally on all my ducted fans I do use a thrust tube with the correct exit diameter. I hadn't really planned on using inlet lip or thrust tube on this plane (although beneficial) as no one was really using it on the small world models version. Maybe that plane was just so small and light that it really didn't need it.
Thanks for you input.
Flyboytha1, Will you be using inlet lip and thrust tube?
James
JIMinKENTUCKY is offline Find More Posts by JIMinKENTUCKY
Old Feb 12, 2009, 11:51 PM
Lithonion is offline
Find More Posts by Lithonion
Have you seen my nut?
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Hey guys. Been reading along as the thread builds. Looks like I might have my Extra 300 sold so I can get this bird. Can't wait to here a flight report. And find an answer to the CG Chinese Instructions Mystery.
I had the World Models Unijet and loved it for the 1 flight I had it. Note to self....range check every model before maiden.
So, anyone else reading along that is thinking of getting this plane, dont. Cause I dont have one yet and dont want to see...OUT OF STOCK!.
Lithonion is offline Find More Posts by Lithonion
Old Feb 13, 2009, 03:30 AM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
Jim I"ve Just Open Up The Box Everythings Looking Good Have Started Building It Yet But Will Have Video Updates Here Soon
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Feb 13, 2009, 08:59 AM
Sniper.308 is offline
Find More Posts by Sniper.308
I'm a lead farmer Mother ^%$^%
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
<-----Anxiously awaiting mailman to finish my darn plane for Sunday.
Sniper.308 is offline Find More Posts by Sniper.308
Old Feb 13, 2009, 09:03 AM
FlyBoyTha1's Avatar
Joined Sep 2008
James
I'm Unsure Yet Got One Video Done Working On Second One Now, Almost On The Electronic Now.
Old Feb 13, 2009, 06:22 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Here's Part 1 Build Video.
Nitro Planes 100mm Fan Trainer Build Part 1 (3 min 23 sec)
Old Feb 13, 2009, 08:19 PM
Socomon is offline
Joined May 2006
Would you have to modify anything to use a Midi fan?
Old Feb 13, 2009, 10:35 PM
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
A midifan should be able to fit with minimal mods. I would drill the holes for the Himaxx fan and then use a spacer between the fuse and the fan side and then a bolt down clamp type thing on the mounting fin to secure it.
Old Feb 13, 2009, 11:08 PM
Joined Mar 2002
Canopy and interior.
Old Feb 14, 2009, 05:15 AM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Hey Jim,
Where did you get that nice hatch release at??
Old Feb 14, 2009, 06:41 AM
CRASH_Jim is offline
Find More Posts by CRASH_Jim
Silent but deadly
CRASH_Jim's Avatar
Cataula, Ga
Joined Mar 2005
I can answer that one for him... Hobby City, Hobby King, what ever they are now. I have a bunch of them also. They are nice as long as you don't putt too much preasure on the release from the side. The plastic will break off. I've been using them for about 2 years now.
http://www.hobbycity.com/hobbycity/s...py_Lock_30x8mm
CRASH_Jim is offline Find More Posts by CRASH_Jim
Old Feb 14, 2009, 09:45 AM
Joined Mar 2002
Yes, they will break easy. I am going to clip the release handle to make it short so less risk of breaking it.
edit: too late I just broke it Oh well, I have another.
James
Old Feb 14, 2009, 03:40 PM
Joined Mar 2002
Video
Static test run and taxi test.
http://www.rcgroups.com/forums/showt...7#post11584224
As mentioned the manual states 2 CoG. 50mm back from LE and 90mm back.
90mm back is too far. 50mm makes more sense.
The plane will balance at 50mm back with 2-3s 3300 packs but just barely. It could use a little more weight in the nose so 3s 3500's would be perfect up to about 3s 4000's in series.
James
Old Feb 14, 2009, 03:56 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Looking Good Over There My Man, Looking Good, I'm Just About To Install My Motor Here's Video Part 2 Of The Fan Trainer, I'm Running The Himaxx 96mm Set Up With A 6 Cell 3850 Thunderpower Lipo On This Bad Boy, These Are The Readings I Pulled Of My Watts Up Meter. Looks Pretty Quick
Nitro Planes 100mm Fan Trainer Build Part 2 (9 min 55 sec)
Cool pictures of fan flying off EDF-50 unit. hsuusa Parkflyers 1 Jul 08, 2002 03:43 AM
Fan-fold foam EDF Vincent Electric Ducted Fan Jet Talk 8 Jun 19, 2002 06:20 PM
My new jet trainer for EDF 300 kwan Electric Ducted Fan Jet Talk 3 Jun 26, 2001 06:54 AM
Where's the Fan Trainer by Steve Neil? rcdude Electric Ducted Fan Jet Talk 11 Jun 06, 2001 02:42 AM
