Old Jan 29, 2009, 10:59 PM
JIMinKENTUCKY is offline
Find More Posts by JIMinKENTUCKY
United States, GA, Columbus
Joined Mar 2002
NitroPlanes Fan Trainer 100mm EDF
Edit: Video here:
http://www.rcgroups.com/forums/showt...3#post12348112
I just noticed these are available and hadn't seen one posted here.
I couldn't resist and had to order one. Practically the same price as the small World Models version.
http://www.nitroplanes.com/edf-trainer.html
Specifications:
Wing span: 51 in / 1300 mm
Wing Area: 390 sq in / 25.2 sq dm
Flying weight: 6.6lbs / 3000g
Fuselage length:49.2 in / 1250 mm
Requirements:
EDF : 101mm / 4.0 in x 1pcs
Radio Required: 4channels, 5servos
Brushless Motor : D36 x L 50 mm x 1pcs ; 1900kv - 2200 kv
Speed Controller : 22.2 v ; 85A ; 25C ;
Li-poly Battery : 4000mAh ; 25 C .
James
JIMinKENTUCKY is offline Find More Posts by JIMinKENTUCKY
Old Jan 29, 2009, 11:12 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Looks Good!
Bob
bruff is online now Find More Posts by bruff
Old Jan 29, 2009, 11:33 PM
hagraw is offline
Find More Posts by hagraw
eThekwini South Africa
Joined Jul 2004
Hi Jim in K
Can you please post some pictures of your kit, I'm looking at getting a few kits from the manufacturer, they have quite a few interesting models in their range at amaizingly low prices, I'm keen to get an indication of the quality.
Many thanks
Les
hagraw is offline Find More Posts by hagraw
Old Jan 29, 2009, 11:47 PM
mickydee is online now
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi guys,
Looks good, but 6.6 pounds on less than 400 square inches of wing seems kinda heavy.
Mickydee
mickydee is online now Find More Posts by mickydee
Old Jan 30, 2009, 12:42 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
true but least it's 400 inches of straight out! lol and would be a static hound so on tap shouldnt be a prob. I still love these fan trainers, and that cheap! tough to beat. I'd do it on a nice midi though myself, or super light it with a mini.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Feb 11, 2009, 12:05 AM
Joined Mar 2002
Originally Posted by hagraw
Hi Jim in K
Many thanks
Les
Here are some pics of the fan trainer that I just completed today.
I am using the RTR Himax 96mm which is a perfect fit for this jet.
Quality and workmanship of the kit is excellent.
No complaints on the hardware included although I did add larger wheels as seen in pics for better handling on grass.
I dont have any numbers yet from the wattmeter but I did test the fan on a 4s 3700 pack and it runs smooth. I will be using a 6s 3500 or 6s 4000 pack for flight.
For servos, I am using 3 standard size for rudder, nosegear, and elevator.
I am using digital mini metal gear servos for ailerons to save some weight.
Turnigy 80 ESC
Castle Creations BEC
Futaba Fasst 7ch receiver
James
Old Feb 11, 2009, 12:07 AM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
I am looking forward to your flight report Jim! Also, anxious to hear how many watts the power system is putting out on that one.
Bajora is offline Find More Posts by Bajora
Old Feb 11, 2009, 12:27 AM
Joined Mar 2002
I will checks the watts and amps tomorrow on 6s as well as weight of the plane.
I hope to maiden this weekend or sooner.
I tested 2 3s zippy 20-30c 3300 packs in series for 6s 3300.
1280 watts at 58 amps.
James
Old Feb 11, 2009, 03:29 AM
jamie_duff is offline
Find More Posts by jamie_duff
Aberdeen, Scotland
Joined Apr 2008
Is it just me or is the tailplane and elevator fitted wonky onto the fin?
jamie_duff is offline Find More Posts by jamie_duff
Old Feb 11, 2009, 03:56 AM
Volunteer is offline
Find More Posts by Volunteer
Volunteer's Avatar
United States, TN, Chattanooga
Joined Mar 2006
Yeah, looks a little wonky. Of course wonkiness is is often associated with Nitro models equipment
Volunteer is offline Find More Posts by Volunteer
Old Feb 11, 2009, 08:01 AM
CRASH_Jim is offline
Find More Posts by CRASH_Jim
Silent but deadly
CRASH_Jim's Avatar
Cataula, Ga
Joined Mar 2005
Jim... You are a busy one!!! Looks good. Can't wait to see that one in person.
CRASH_Jim is offline Find More Posts by CRASH_Jim
Old Feb 11, 2009, 08:37 AM
hagraw is offline
Joined Jul 2004
Hi Jim
Thanks for the pictures, hoping the test flight is uneventful.
Les
Old Feb 11, 2009, 09:30 AM
Joined Mar 2002
It does look a little different but I thought the same thing of the World Models version but it flew nicely.
Old Feb 11, 2009, 12:52 PM
Kwesdog is offline
Find More Posts by Kwesdog
I fly Army UAVs!
Kwesdog's Avatar
West Saint Paul, MN
Joined Aug 2002
What is your AUW for this aircraft?
I have the UCAV and the specified weight is 6.6 lbs but you would be hard pressed to get it down to that weight without mods to have a bird that still flies fast and safe. Hopefully this airframe is different but at how cheap they are I have a hard time believing so unless there are some real world numbers posted.
Harry
Kwesdog is offline Find More Posts by Kwesdog
Old Feb 11, 2009, 02:07 PM
Joined Mar 2002
The specified weight (6.6 lbs) for the plane is with a 6s pack (22.2 volts).
My plane before batteries weighs 5.33 lbs.
AUW with 2-3s 3300 20-30c packs in series is 6.55lbs which is probably the pack I will maiden it on.
AUW with 2-3s 4000 in series is 6.95lbs which should still be fine.
Weights would be a little lower if using one pack instead of 2 in series.
James
Cool pictures of fan flying off EDF-50 unit. hsuusa Parkflyers 1 Jul 08, 2002 03:43 AM
Fan-fold foam EDF Vincent Electric Ducted Fan Jet Talk 8 Jun 19, 2002 06:20 PM
My new jet trainer for EDF 300 kwan Electric Ducted Fan Jet Talk 3 Jun 26, 2001 06:54 AM
Where's the Fan Trainer by Steve Neil? rcdude Electric Ducted Fan Jet Talk 11 Jun 06, 2001 02:42 AM
