Old Jan 29, 2009, 02:19 AM
v.sabarish is offline
Find More Posts by v.sabarish
Joined Jan 2009
Variable pitch propellers
Hello ppl, I'm new here and this is my first post. I'm planning to build a variable pitch prop.... Anyone here trying to do the same thing or anyone having any links or ideas regarding this.. plz reply here..... I need a variable pitch prop to fly a twin engined plane weighing about 9-10kg.... first I'm going to make a small model of the prop and test it and then go for the final one...
v.sabarish is offline Find More Posts by v.sabarish
Old Jan 29, 2009, 07:38 AM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Is it to be adjustable only on the ground or while airborne?
If airborne as well make it constant speed.
A very interesting challenge to be patented.
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 29, 2009, 10:47 AM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
Just in case you didn't know, it's out there already. Changing pitch while in flight. Do a search for "4d propeller"
Guz is offline Find More Posts by Guz
Old Jan 29, 2009, 11:34 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Sorry, I was considering a variable pitch propeller for a model airplane with an engine. Something like a model of a full size airplane.
Old Jan 29, 2009, 12:45 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Will your model be electric or fuel engine powered? As Guz posted, there is a variable pitch prop on the market, but it's meant for electric motors.
Information also needed is *when* you want the prop to change pitch (the *how* will have to be worked out after the *when* question is answered).
"Variable pitch" can mean to be able to change the pitch of the prop blades and secure them in place, and it can also mean that you can change the pitch of the prop blades while the motor (or engine) is operating.
It sounds like a fun project, but I just gotta ask: *why*?
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 30, 2009, 05:26 AM
Joined Jan 2009
I'm sorry people, may be I wasn't too good with my question. Actually, we're going to make a variable pitch prop that can change pitch when it's airborne and it's for an IC engine.
I've done some googling, but I didn't find any satisfactory results.. I found a few.. but when I read abt the details, i found that those props are for very small aircrafts.. weighing not more than 400g or so...
Old Jan 30, 2009, 05:31 AM
Joined Jan 2009
Our plane would be weighing some 8-10 kg.... and we want to use IC engines, just bcoz they are more difficult to operate
@ EJWash
I've just want to make a twin engined plane.. and we wanna use VPPs.... that's it.....
Old Jan 30, 2009, 05:32 AM
Joined Jan 2009
If any1's made any variable pitch props.. or if any1 has any links regarding making one, plz do send them to me...
Old Jan 30, 2009, 08:20 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I don't think I have ever come across a variable pitch propeller for a model size IC engine that could be changed in flight. Electric yes, IC no, other than pitch change on the ground when stationary.
The major advantage with electric is you can run a hollow drive shaft for the pitch change mechanism to run through.
I suppose a model helicopter head could be modified to do something similar, but then most model fliers would ask why bother, The throttle works probably as good, (though some efficiency may be lost).
Now if it was a military contract..................money is no problem, someone will make anything you want, (at a price ).
eflightray is online now Find More Posts by eflightray
Old Jan 30, 2009, 08:42 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Have a look/read of this site - Scale Warbird Prop Drive, though this is a constant speed variable pitch prop.
Old Jan 30, 2009, 08:53 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
You think of it, somebody has done it. I was thinking and asking about VP props for high speed models here on RCG before. I made an adjustable prop and is still working on a VP prop for my purposes. And no, the existing props will not work for me, and I looked at eggbeater parts, it does not work for a plank.
Here is an example of a VP prop for a DA twin engine.
rebell is offline Find More Posts by rebell
Old Jan 30, 2009, 08:56 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Some people do amazing piece of engineering, the picture(s) show it best.
From the The Joe Martin Foundation Museum site scroll down to item #145, JT 1800 9-Cylinder Radial Model Airplane Engine, .......'It sports his custom designed hydraulic controlled variable pitch propeller'.
Now if you have a good machine shop..............
Old Jan 30, 2009, 08:58 AM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
O, I forgot to mention, the one I work on will be a folder prop as well. The picture I posted is not mine, I found it on the net.
Old Jan 30, 2009, 11:53 AM
Joined Jan 2009
And I'm just a beginner. I never built any plane myself before... I'm just about to start...
right now, we wanna build a VP Prop....... that's the reason I've been asking about that....
Old Jan 30, 2009, 01:44 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
From the [URL=http://www.craftsmanshipmuseum.com/KnappCol.htm]
WOW!!!
Thank you for posting this link eflightray. Each is a work of art, to be sure.
EJWash
variable pitch propellers Romano Scale Boats 19 Apr 13, 2009 08:53 PM
variable pitch propellers Paranoia Electric Plane Talk 6 Jun 02, 2005 09:13 AM
Micro Variable pitch Edf/Propellers aerogel Scratchbuilt Indoor and Micro Models 9 Oct 01, 2004 04:21 PM
Low pitch propellers as a replacement for gear drives? Paul Power Systems 6 Dec 20, 2001 01:01 AM
Fully automatic variable pitch control? Giacomo Power Systems 15 Jul 02, 2001 03:52 AM
