Old Apr 25, 2011, 05:04 PM
PaulB is offline
Find More Posts by PaulB
Mike's Ma Maaaaaaaaan
Paderborn DE
Spring blues.
Well I am back in the air after the winter break. 2 Out of 4 packs have a cell gone 'Man Down' despite storing at 3.8 Volts I will send them back to the importer and see how good they are
BUT, my tail shake/ wobble/ vibration is back Checked play, oiled the ball joints and put another layer of mirror tape under the Gyro, Align 750, no improvement!! Oh well, my Baby flies like a dream and you always have to have something to work on
PaulB is offline Find More Posts by PaulB
Old Apr 25, 2011, 05:39 PM
anton831 is offline
Find More Posts by anton831
Joined Sep 2009
good to hear from you paul.
In the video at 2:40 what exactly is going on with the head on that trex 500 it looks ready to fall off
anton831 is offline Find More Posts by anton831
Old Apr 30, 2011, 05:48 PM
anton831 is offline
Joined Sep 2009
Fusuno canopy for Exi 500
I could not resist plus there on sale cheap i have plenty of swashplate room and lipo space and they are flexible as advertised.
Old Apr 30, 2011, 05:59 PM
RobDog is offline
Find More Posts by RobDog
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
Ok, 4S is out for anything but standard sport flying. However, I have to say, on a 4S 2200 I'm getting about 6 minutes of flight and nothing gets even close to hot. Didn't have an amp meter yet....
So, next up is 5s.
Also, I'm working on replacing the plastic tail with metal so I won't be "as" afraid of 6s...
Thanks again for all your advice and I'll keep you updated,
Rob
Originally Posted by rocketscience View Post
IMO in the LONG run it may just be more economical to stick with higher V batteries. You don't need the high C ratings that way. Maybe a direct comparison between using your current motor and buying new larger capacity high current 4S or 5S batteries vs using your current batteries or even higher voltage (8S?!) and lower capacity, 25C batteries - and getting a new HC motor (1600kv or 1300kv).
RobDog is offline Find More Posts by RobDog
Old Apr 30, 2011, 08:42 PM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Why not stay plastic? You'll need a whole lot less tail servo torque. If quality is suspect, Align has the plastic tail grips with hub/bearings for $12.00
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Apr 30, 2011, 09:17 PM
RobDog is offline
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
Honestly, I'm not sure why I wouldn't stay plastic. I'm just scared because of the insane headspeed, the tail must be ballistic. I've taken it apart and greased the bearings etc, and it seems to be quality enough to handle the stress.... I guess I'm just being to cautious.
Rob
Old May 01, 2011, 01:18 AM
MolokaiBoy is offline
Find More Posts by MolokaiBoy
United States, HI, Lahaina
I have the plastic version and have been running the stock plastic tail on 6s lipos and 11T/13T pinions and they've been doing quite well. The tail worked great for me on 6s and an 11T pinion (fixed endpoints and around 2500-2600HS).
I have just recently put in a 13T pinion and a CC Ice 75 and have been messing around with the governor. Seems to fly well at 2500, I have also been trying to figure out the best PWM for my Typhoon 500, I tried outrunner mode, will try 8/12khz and see what happens.
I ripped a ball link out of my upper mixing arm, so will need to get me some parts before I can fly again.
Aloha,
Les
MolokaiBoy is offline Find More Posts by MolokaiBoy
Old May 01, 2011, 01:26 AM
RobDog is offline
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
Ok, I'm convinced to try it out. Tomorrow I'm going to run full tilt on 6S and ignore my worries. Wish me luck,
Rob
Old May 01, 2011, 08:11 AM
Redjestird Youser
Joined Jan 2009
While the plastic grips are several grams lighter, it is unknown how much strength those Skya supplied grip assembly screws actually have. The metal grip tails have been known to launch grips at higher rpm with the supplied screws...did you change the grip assembly screws as part of the build?
Old May 01, 2011, 05:06 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
tail screws that hold the grips to the hub are 2mm x6mm long.
I replaced those on mine after a crash.
I built an Align 500 2 years ago and the Align supplied screws SNAPPED when I unscrewed it. So even on an Align, I recommend replacing those tail grip screws.
I got mine from rtlfasteners.com
Melnic is offline Find More Posts by Melnic
Old May 04, 2011, 01:58 PM
Mac Carter is offline
Find More Posts by Mac Carter
Mac Carter
Mac Carter's Avatar
North Carolina
Joined Aug 2005
5cell working well.
I had posted a while back about my EXI500 bending tale shafts like melted butter. I tried a 5cell and it seems to have fixed the problem. I was running a Hobbymate 1700Kv/12t/6cell which seemed to work for a while but always seemed noisey like something was about to go, I put in the Turnigy Typhoon and it would just kill everything. I am going to try the Typhoon again with the 5cell and see how that works. Were are you guys getting the 11t pinions? The 5cell flies great, I only have 20c so pitch pumps are a little hard on it. Oh well, just thought this might help out someone else that was having similar issues at me.
Mac
Mac Carter is offline Find More Posts by Mac Carter
Old May 05, 2011, 08:05 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
11T I got at ready heli.
I see the link on post #1 is messed up for the Revco so I just fixed it.
http://www.readyheli.com/RevCo-Hard-...e_p_33777.html
If your running too hight an RPM are you able to tach it?
Droid app?
Optical tach on the ground?
Old May 06, 2011, 11:02 AM
thunderfrog is offline
Find More Posts by thunderfrog
thunderfrog's Avatar
Joined Nov 2009
I know this has been answered a dozen times. But Im to lazy to read back and find it.
But what is the best budget (gyro, rudder servo) combo.
I have enough exi spare parts to build another heli. So I may as well.
thunderfrog is offline Find More Posts by thunderfrog
Old May 07, 2011, 08:29 PM
anton831 is offline
Joined Sep 2009
Thought ill ask before i spend hours surfing the web
im using a futaba 401 gyro and spectrum ds520 servo on my tail, I upgraded to a torque tube but when i used the belt the gyro combo work very good but now with the tt i dont get tail wag unless im at mid stick and on the ground not lifted off yet ,when i get into a hover my tail is slow in one direction and semi fast in the other and my tail is centered but will drift opposite of wind direction. i switched and tryied 3 different gyros and the same effect i was going to try the tail servo until i saw the wag on the ground any idea's whats going on im also using the dx8 and im still getting use to it. any help greatlly appreciated
Old May 07, 2011, 09:32 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
how much do you have to spend?
The Power HD servo from value hobby is popular.
Less than $20, use a GY48V
around $100, try to find a good GY401 by futaba used.
$120-$150 GY520 or Quark.
I myself have had BAD luck with Align Gyros.
New Product EXI 500 Carbon Edition RC Helicopter & 450/500 Fiberglass Canopies starting $12.95 xheli XHeli 2 Oct 06, 2009 05:03 PM
Discussion Official Trex 500 Thread? learninginverted Electric Heli Talk 0 Mar 17, 2008 11:57 PM
