rocketscience:
The Align T-Rex 500 manual calls for 16-16.5mm distance from center to ball on the cyclic servos. Unless I missed it there is no spec in the manual for the rudder servo. For my 450's it's always been as close to center as possible. That's where I plan to start for the rudder on this bird too. I'm working on mine right now and am seeing the same issue with the flybar on my CF version. I loosened up all 4 bolts on the flybar cage and then pushed the flybar through. I tightened up the bolts and all seems OK now. Joe |
I was able the get the flybar in, but it does not want to tilt because it rubs pretty hard against the head block. No choice but to file it down. |
The HS-225 is capable of 180 degrees of travel but only if the TX is capable or if you use the 180 degree servo stretcher. Under normal circumstances it should operate as any normal servo.
Joe |
Joe |
Joined Sep 2009
hopefully i can fly in the little snow today to get a test flight but here are some pics of what worked for me on my heli,
i finally got a new camera yea
Joined Sep 2009
Oh almost forgot i was thinking about what you guys were saying about the 16mm that the align manual says your all right , but i believe with the stand off of the 225 it changes the "how should i say this" the distance making it shorter on the 225 due to the stand off of the servo its not a straight line but a slanted one. i might be wrong but thats what i was thinking
Joined Sep 2009
Sorry about the video quality i was setting up the 500 with the new motor i thought i did good with the 13t pinion i am setting my gyro gain and throttle curve. this motor is a winner |
I DID have to resort to using my old exi500 CF main gear assembly. I just couldn't file down the shim enough.. not sure how everyone is sanding these. I was able to get the gear in the frame but when I screwed the Jesus bolt in the owb gets very difficult to turn. The old EXI assembly went in fine. very odd. Like something in the factory changed these dimensions. |
I filed my shim down using the file on my Leatherman knife as it was the only file I had in the shop I was in at the time. I used my fingers to slide it back and forth for probably close to 15 minutes while constantly checking thickness with a caliper. It was a p.i.t.a. and my fingerprints are gone but it worked for me. The gears operate completely smooth now. I've been finishing everything up today and came to the conclusion that all the balls and ball links are going to get scrapped in favor of Align parts. Even before sizing the links they come off too easy for my liking. I'm not even going to spool it up until they're replaced. I know it seems kinda anal but I'm in no big hurry. Hopefully the hobby shop will have them in stock and I'll get them on the way to work tomorrow. Joe |
Also I just mounted the tail servo on the plastic servo tabs. Holy flex batman. Def need to upgrade that at least to the GF servo mount. |
| Thread Tools | |
| New Product EXI 500 Carbon Edition RC Helicopter & 450/500 Fiberglass Canopies starting $12.95 | xheli | XHeli | 2 | Oct 06, 2009 04:03 PM |
| Discussion Official Trex 500 Thread? | learninginverted | Electric Heli Talk | 0 | Mar 17, 2008 10:57 PM |
