Finally got some decent weather and was able to get a couple good flights in.
I noticed on some ones t-rex the paddles were alot bigger then my plastic ones. So Im going to get $8.00 skids tail blades paddles. Im using the dx6i with the ar6200 receiver on my second flight when I landed I noticed both light on the two receivers were flashing. They weren't flashing when I took off. Any thoughts? |
Flashing AR6100 or 6200 lights means it rebooted in flight. It could have been static or a power drop. Do you have a switching BEC supplying power? Using digital servos? |
Oxfordshire, UK
Joined Jan 2007
To avoid this ....... turn Tx on, Connect battery to heli, fly, disconnect heli battery, Tx off then on again, fit and connect new heli battery, fly, disconnect heli battery etc etc. etc. |
http://www.youtube.com/watch?v=zTI5AB-SZVo This was before i got my replacement parts from xheli. Got them in and installed. All was perfect. Boom holder and seesaw. |
http://ep.yimg.com/ca/I/yhst-9458232..._2093_20117778 |
Im not using an external bec. Im sure I turned off the transmitter after the first flight. I rebound it and going to have to keep an eye on it. I think the motor rpms dropped a little during flight, thats why I landed, then I noticed the lights flashing. |
Joined Sep 2009
[QUOTE=thunderfrog;14526345]Im using the turnigy plush 80a w/ubec and turnigy 930 servos
your having static problems thats what the 500 helis are known for. they came out with the tt for one of those reasons if you keep flying it that way its going to get a mind of its own, the simply fix is running a gound wire thats in early post if you herd the motor lose power it was going into failsafe for a split second,with helis everything happens so fast
| Thread Tools | |
| New Product EXI 500 Carbon Edition RC Helicopter & 450/500 Fiberglass Canopies starting $12.95 | xheli | XHeli | 2 | Oct 06, 2009 04:03 PM |
| Discussion Official Trex 500 Thread? | learninginverted | Electric Heli Talk | 0 | Mar 17, 2008 10:57 PM |
