Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old Mar 12, 2003, 10:13 AM   #1
Zagi 400X run times
I just received a 400x as a gift and was wondering what kind of run times I can expect. It came with a 1700 nicad. I have flown it 3 times and each time the run time has improved. This morning I got about 15 min. with throttle management. Is this about the average time and is there a replacement battery for longer times? Thanks for the info.
grizzowner is offline Find More Posts by grizzowner   Reply With Quote
Old Mar 12, 2003, 10:16 AM   #2
Check out www.myzagi.com for all kinds of great info. The Zagi has a cult following and there is all kinds of good info out there for it.
ChodeMan is offline Find More Posts by ChodeMan   Reply With Quote
Old Mar 12, 2003, 10:56 AM   #3
Live to ride... and fly!
Tres Wright's Avatar
Hey J.R.-
15 minutes is about right. I usually get around that on my 1700 pack or 12 minutes on the 1400 packs. Or at least I used to, I swapped a 480 motor in there and my run times went down about 30%!
We need to get together and fly Zagis, I haven't flown mine in months. Are you liking it OK?
Tres Wright is offline Find More Posts by Tres Wright   Reply With Quote
Old Mar 12, 2003, 11:05 AM   #4
Stress Be Gone
GBR2's Avatar
Send a message via ICQ to GBR2
You should try a pack of the 1700 H4/5AUP NIMH cells. You will get the same run time as the 1400AE's but with a significant increase in rpm and speed. My 1400 pack was my zippy pack till I tried the 4/5 pack the first time. I was kind of shocked that there was such a significant difference in performance. Plus the pack did not drop off much at all from start to finish. This is definitely my zippy pack now.
GBR2 is offline Find More Posts by GBR2   Reply With Quote
Old Mar 12, 2003, 11:08 AM   #5
Hey Tres, I am back in the state of Texas! I maidened it Mon. evening and ran the whole pack and landed it right in my hand! It is really a blast to fly and flys fast. The sound it makes also gives enjoyment while zipping around at about 3 feet. The rolls are somewhat sloppy but I don't know if that is due to the design of the wing or the throws on the servos. A very fun flyer!
Old Mar 12, 2003, 11:11 AM   #6
Thanks for the info GBR2! Did you have to rebalance after installing the new pack? I know the cg is pretty touchy on these things.
Old Mar 12, 2003, 11:26 AM   #7
==The rolls are somewhat sloppy but I don't know if that is due to the design of the wing or the throws on the servos. ==
Mike sets them up with pretty tame throws, so that's probably hurting the roll rate. I increased the throws on mine after flying it a few times, but you have to be careful because it'll increase the stall tendencies too.
==I know the cg is pretty touchy on these things.==
It is, if you get the CG too far back than the dreaded Death Spiral will become your new landing method Luckily Zagis can survive the death spiral pretty well.
Old Mar 12, 2003, 03:10 PM   #8
Stress Be Gone
GBR2's Avatar
No I didn't have to rebalance or anything. I just put the front of the pack in the same location that I have the front of either the 1700Au (standard zagi pack) or the 1400AE. I didn't notice any difference in how it flew or glided except for the increase in performance. Got my pack from Diversity Model Aircraft.
Zagi 400X loss of signal cclap Beginner Training Area (Aircraft-Electric) 5 Sep 07, 2001 09:30 PM
Help with zagi 400X billyboy Beginner Training Area (Aircraft-Electric) 4 Jul 13, 2001 12:02 AM
inverted flight with Zagi 400X stock setup? 177ichael Electric Plane Talk 10 Jun 25, 2001 09:18 PM
zagi 400x construction nybpete Beginner Training Area (Aircraft-Electric) 4 Jun 22, 2001 01:24 AM
Battery charger quesion for a Zagi 400X? Josh C Beginner Training Area (Aircraft-Electric) 8 Jun 07, 2001 01:36 AM
Congratulations SimpleM!
